Previous in Forum: What's this then (02)   Next in Forum: How Valid is the Book in Your Library?
11 comments
Looking For 12 Volt Battery Sealed Lead Acid
04/24/2009 8:56 AM
Hello All; I am in need of a 12 volt battery sealed lead acid. Parameters are as follows: 1) Small in size say 7" tall 5" wide and no more than 10" long. 2) Able to be discharged at a rate of 2 amps for 12 to 14 hours. 3) Able to recover charge, without damage, within 6 to 7 hours over two years time 4) Readily available in mass quantity ( 200 units to 500 at a time ) meaning not a solely purpose built unit for this application. 5) And of course inexpensive. Any help you could offer would be great. 407 538 2337 cmpginc@bellsouth.net Sincerely, Laurence Albrecht
Re: looking for...
04/24/2009 9:08 AM
A motorcycle electric start battery, perhaps?
Good Answers: 143
Re: Looking For 12 Volt Battery Sealed Lead Acid
04/24/2009 11:14 AM
I'm not sure about expense, but I'd look at the Panasonic batteries here:
http://www.panasonic.com/industrial/battery/oem/chem/seal/
I've had a similar pair that I have abused the dickens out of for the past fifteen years. One is still as good as new, the other is starting to show amp-hour degradation.
Good Answers: 266
04/24/2009 1:01 PM
Good Answers: 18
04/24/2009 1:55 PM
Measure some at Walmart or Advanced Auto Parts.
04/24/2009 7:56 PM
Yep. Motorcycle battery, definitely. I also thought about those batteries that go into some brands of electric fences and garage doors, but they are more like high amp in short time. 2 amps for 12 to 14 hours, we're talking about around 28 Ah minimum.
Humm... suspicious you are...
Good Answers: 25
04/24/2009 11:10 PM
http://www.interstatebatteries.com/cs_estore/Products/RT/PID-SLA1156(Other+Products).aspx?dsNavigation=Ntk~SearchGroup|12v%2024ah|3|,Ny~True,Ntpc~Disabled,Ns~product%20Type|101|1|
12V 34AH INSERT BOLT/NUT SLA OR VRLA
Product ID:SLA1156(Other Products)
Voltage:12
Termination:INSERT W/BOLT REPLACES FLAG TY
Chemistry:SLA OR VRLA VALVE REGULATED S
Weight:28.65
Width:5.12
Length:7.62
Height:6.56
Good Answers: 247
04/25/2009 1:53 AM
I'd agree that this would be a very good fit. 14 hours at 2 amps would be 28 AH. The depth of discharge should not exceed 80%, so a 35 AH battery would be recommended. This is just very slightly undersized. If the extra size could be tolerated, then a 40 AH battery would last longer -- but two years is a short time for a good battery, so this 34 ah one should work fine.
Good Answers: 25
04/25/2009 2:11 AM
Blink,
Thanks for agreeing.
The downside is that their terminals become eaten away inside after a few years.
Gotta make sure the supply is freshly manufactured.
The high tech rechargeable Lithium Ion batteries have cost and serious safety and EPA issues.
The Nickel-metal Hydrides are my favorite.
Jon
04/25/2009 4:57 AM
Good Post!
04/24/2009 11:50 PM
I am not sure of the origional use. A friend of mine used to work at cummings desiel supply wharehouse well the trucks had a seperate system onboard which had thier own 12 volt battery it was 3 in thick about 4 in wide and about 8 in tall. I adapted a charger and used it for many many experaments. it lasted what seemed like forever and woul;d fully recahrge in 3 hours look into it . it may just be what your looking for.the battery was compleatly sealed aswell
Richard Sleeth
04/25/2009 9:24 AM
Andy Germany (1); Anonymous Poster (1); bhrescobar (1); Bill (1); Blink (1); kudukdweller9 (2); ozzb (1); PWSlack (1); rdsbd01 (1); TVP45 (1)
You might be interested in: Lead Acid Batteries, Battery Holders
