Previous in Forum: Programs and Sound   Next in Forum: Video Sharing Software
QJ71C24N Module Gets Hung
07/10/2009 3:21 AM
Hi,
I've Q02H CPU & one serial interface module (QJ71C24N) to communicate with the Barcode reader.
Application is Barcode reader will read the 8 characters from the Barcode & send it to QJ71C24N module & from module I'm taking into the PLC logic. this application work sometime 1 hour, 3 hour or full day without any error but sometimes this module get's hang, means not at all trying to receive the data in to it's buffer memory area.
no any error shown on the module & in it's diagonstic also. after switch Off & On PLC module start's functioning as usual but don't no how much time it wil work.
This is new module & it's working one. Barcode reader also sending data (onfirm on Laptop Hyperlink), cable also used proer & routed.
I don't know why it's happening???? can anybody help me...
Pathfinder Tags: QJ71C24N
Good Answers: 97
Re: QJ71C24N Module Getting Hang
07/10/2009 8:25 AM
If the scanner miss just 1 bit the process will keep on looping forever.
You should include a watchdog timer around the reading process.
Therefore it should exit the loop when the process spends too much time in the loop,
07/13/2009 4:43 AM
Dear Sir,
can I send you my logic on u'r mail ID.
watchdog already is there in the plc file for 200 ms.
Register to Reply 2 comments
You might be interested in: Bar Code Decoders, PCI Products, Machine Vision Systems
