Previous in Forum: Pressure Vessel Nozzle - Set In or Set On Type   Next in Forum: R Stamp Conditions
NPSHA Evaluation
07/13/2009 3:16 AM
what does NPSHA mean and how can you evaluate it for a reciprocating pump?
Re: NPSHA evaluation
07/13/2009 3:23 AM
Net Positive Suction Head evaluates whether there is enough fluid at the inlet of a pump to prime it and to make sure that the pump doesn't cavitate, i.e. pull a vacuum on the incoming fluid, making it boil. Cavitation will wreck a pump in short order.
What sort of reciprocating pump? What size? What is the fluid? What is its temperature and pressure?
Good Answers: 97
07/13/2009 3:29 AM
Net Positive Suction Head Available relies on atmospheric pressure and will change during a period. It is best calculated using the minimum value.
The pump side NPSHR (Required) will depend on the pump specs.
There must always be enough Available to Satisfy the Required.
Good Answers: 137
07/13/2009 6:06 AM
Don't forget the acceleration head! You might need a pulsation damper on the suction pipe.
Codey
Codemaster (1); Hendrik (1); PWSlack (1)
