Greetings and even though I should maybe know the answer, I don't.
For some years I have wondered why there are so many types (variations) of the oil filters used on auto / truck engines. Not the particular Brand, but the different sizes, configurations, etc. every time a new model rolls out of the factory. Air filters I can understand, as you have way more variables when under the hood design takes place with options, etc....BUT
Why does there have to be so many variables? If you have say a range of 350 CI - 400 CI (OR, 3.5L - 4.0L) why the different sizes between vehicle Mfg'rs.? why would there not be one optimum size/design to satisfy the engine block size requirements?
Is it:
a) volume required, or amount of filter media
b) inflow for line pressure (not all screw studs are the same on engine blocks)
c) Different Day / Different Engineer
d) these filter companies need to take up a lot of shelf space?
So, anyone in the know about this - what initiates the design of a new oil filter?
TIA & good day!
