So the other day I noticed a loss of pressure in my brakes. I thought I
would just need to bleed them and when I started on the front left
brakes I noticed my pads were shot, so I replaced the brake
pads...while doing so I also noticed I would need a new caliper for the
front left so I replaced that as well. Figuring that this would fix it,
I started to try and bleed it (with the help of my brother pumping the
brakes). I noticed that the front left brake was not putting out enough
pressure to squirt out the brake fluid all nice as it should. I checked
the bleeds on both the back two drums and the front right. They all
bled fine with ample pressure to squirt it out. Thinking there might be
a clog in the brake hose or the brake line I took them all off and
there were no clogs at all. I don't know what it's called I refer it to
as the "spider web" that is connected to all brake lines and the brake
master cylinder and it feels like the line I had taken off had some
pressure but not enough to push the brake fluid through. I re-installed
the brake line and hose. checked the calipers and everything to make
sure there's no gunk. Anyone have any idea what might be wrong? Still
doesnt bleed properly. Is it also possible that it's the master cylinder even though the only brake that wont bleed properly is the front left?
