Previous in Forum: Security Device   Next in Forum: Excess Fuel Consumption - Volvo 960
42 comments
Nissan Micra 1.4 - Annoying Whine
08/03/2009 3:31 AM
My Nissan Micra 1.4 automatic, has developed an annoying resonant whine that seems to be road speed related. I was hoping that new tyres on the back might reduce it, but no joy. I've jacked up each corner and spun the back wheels, and driven each front one...cant locate it...no obvious exhaust leak, inlet seems ok, I even taped up the plastic air intake which was loose (thought it might be vibrating).
Hard to tell where it's coming from, sounds like the back...
It makes a noise like an electric train pulling away from a station...and it's driving me nuts.
I'm thinking maybe rear wheel bearing, or some horrible final drive noise. There is no play in wheels or steering. Applying the brakes or hand brake doesn't kill it, cornering doesn't effect it. Cloves of garlic on the dash are also ineffective.
And before anyone asks...no, it's not passenger squeal from Mrs Cat.
I'm loath to take it into a garage, as I don't think they are any smarter than me these days (that's not ego, that's just my experience with garages)
Any thoughts? Automatic transmissions are new to me, so whadda thing guys eh eh?
Re: Annoying Whine
08/03/2009 4:19 AM
It's a common fault on mk1 models of the KrisDelTM Time Machine, indicating sloppy bearings on the input shaft to the flux capacitor. Get it up above 88mph (not possible around junction 27 of the M25 these days) and the problem will disappear.
Re: Annoying Whine
08/03/2009 6:00 AM
So it doesn't come from the front passenger seat, then?
Re: Annoying Whine
08/03/2009 6:09 AM
C'mon play the game, I covered that possibility in the OP.
These people who don't read the posts carefully, I don't know...
Yeah, where's PlbMak he kno about veeehicles?
Good Answers: 38
Re: Annoying Whine
08/03/2009 8:30 AM
How about during the time that you stop accelerating and start to coast. Or when you gently remove your foot from the gas. Does it change pitch, cycle on and off or appear to maybe be coming from the drive gears. Any leaks by the axles? Possibly changing the gear oil! (Just like the litter box it's nice to change once in a while) Or at least check the level. These sound like dumb suggestions considering what I know of you, but sometimes we overlook the little crap and end up slapping ourselves in the forhead.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Annoying Whine
08/03/2009 1:48 PM
If I stick it in N it's still there, even shifting down, but it could be the final drive...seems road speed related.
No prob when stationary.
Location: BUNDABERG - Queensland - Australia (That big Island just above Tasmania)...
Re: Annoying Whine
08/04/2009 12:19 AM
G'day Del the Cat...
Did the noise come in quickly or has it just appeared out of the blue?
Tyre noises usually, (I mean usually, not always..) come in slowly as tyres get worn or sometimes the rubber compound starts to harden. I had some 4x4 tyres that did the hardening thing some time ago.. man did they whine like crazy...
It could also be the exhaust resignating thru the chassis. If the exhaust mounts are getting a little weak or has a 'bit' of a smack on some of these bloody speed humps or gutters etc; this can create a whinning noise too... I'm not sure, but are the mirca's front wheel drive?.. You may have a CV joint starting to go & the vibration from this could be causing the whole vehicle to vibrate. Like you say it is difficult to pin point...
Anyway, that is all I have for now.. good luck in your quest to solve this mystery..
Cheers for now
LOWIQJO
Be the best you can offer..... Be yourself.... by LOWIQJO
Re: Annoying Whine
08/03/2009 8:26 AM
"It makes a noise like an electric train pulling away from a station...and it's driving me nuts." Too late
Have you looked at the belts? I know the noise seems to come from behind but you never know. If there is no change when you have stopped it stands to reason that it's something that continues to move/rotate when the car is stopped.
This is just a shot in the dark, I know nothing about cars,I have trouble remembering where the key goes.
CARPE CRUSTULORUM!
Re: Annoying Whine
08/03/2009 8:29 AM
We don't have them here, but assuming it's one of those little buggers with FWD - the 2 rears are sway-mounted.....seems like if a bearing is suspect you could jack the rears up again and take hold of each wheel to see if there is play in them when you try to "twist" the wheel back & forth...if it's a bearing, your going to have some play.
Another thing to do while it is up, is to grab each wheel & push/pull back & forth to see if there is any play there also....another indicator of a bad bearing if you have travel when doing either of the above
The sound is only when your rolling, correct?
Re: Annoying Whine
08/03/2009 1:46 PM
I've pulled, pushed, twisted, rocked and spun the wheels, no sign of play...
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Annoying Whine
08/03/2009 8:52 AM
...annoying resonant whine that seems to be road speed related...
Just to confirm that you mean what I think you mean - the pitch of the whine increases with road speed and is independent of being in Drive or Neutral (can you you knock an auto into neutral whilst in motion? I've never tried). Is it still there if you cut the engine and coast?*
How old is the car?
Have you put Mrs Cat in the back so she can crawl around and locate it? (Or let her drive and you do the crawling?). Make sure you're equipped with a screwdriver and piece of rubber tube - both can be used as "stethoscopes" to locate the sound direction and source.
Can it be heard be a bystander?
Is your turbo pipe connected and snuggly attached (one of my recent problems)
You've covered all the obvious causes. Without hearing it I can't think of anything else (no guarantee that I would if I did!)
Last suggestion - have someone follow your car and check for joy-riding squirrels hanging on the rear bumper going Wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee !!!!!
*this test should only be carried out by trained professionals on closed test tracks. Children: do not try this at home.
Chaos always wins because it's better organised.
Re: Annoying Whine
08/03/2009 1:51 PM
I had wondered about taping some pvc tube to various areas and leading them through a window so that I (or Mrs Cat) can listen while I drive...we have lots of 5mm bore pvc tube at work.
It's due for MOT soon, I might see if they will let me sit in it when it's on the rolling road for the brake test.
Del (BTW I removed the extraneous squirrels first thing)
Good Answers: 97
Re: Annoying Whine
08/03/2009 11:05 PM
An intake/inter-cooler leak was my first inclination too...wrap connections with plastic cling-wrap then check after spin.
Re: Annoying Whine
08/03/2009 9:57 AM
<...it's driving me nuts....>
So this chap wanders into a bar with a steering wheel hanging out of his flies and asks for a pint of beer.
The barman pours the pint and gives it to the man, noticing the steering wheel hanging out of his flies and asks, "Excuse me, Sir, but do you know there's a steering wheel hanging out of your flies?"
The man replies, "Yes, I know, and it's driving me nuts."
Re: Annoying Whine
08/03/2009 1:52 PM
<groan...>
I'm PM'ing CL to get you banned from this thread
Re: Annoying Whine
08/04/2009 3:10 AM
Re: Annoying Whine
08/03/2009 2:58 PM
Torque converters make a whine when going out. Then the car owners do when they get the estimate. Although it seems like torque converter problems would be more engine speed related than road speed like you said. Does the ATF smell wrong or burnt? Do you see any sparkley (is that a word) bits in it?
Everything I know about opera I learned from Bugs Bunny
Re: Annoying Whine
08/03/2009 3:53 PM
Dunno, maybe I'll have a look...although the AT box doesn't have a damn dipstick I can look at, it has some electronc level sensor instead...arrrgh <slaps furry head with paw>
Maybe it's nature's way of tellin' me to PX the damn thing...mind it's omly got 35k on the clock!!!???
Re: Annoying Whine
08/04/2009 6:26 AM
Is it old enough to qualify for the £2K scrappage allowance?
Re: Nissan Micra 1.4 - Annoying Whine
08/03/2009 5:07 PM
Might be off the beam, but have you checked the speedometer cable? That would still be rotating (with road speed), even in neutral. Just disconnect from the transmission for a test.
Good Answers: 120
08/03/2009 11:28 PM
might be the constant velocity joints beginning to fail. look for a torn boot. loss of lube, full of grit etc
http://www.nissan.ic-auto.co.za/Specifications/nissan_micra_1_4_acenta_5-door_%282006%29.aspx
Per Ardua Ad Astra
Good Answers: 22
08/03/2009 11:30 PM
C'mon man, it's a Nissan. Whaddya expect? How many miles?
08/04/2009 3:00 AM
I had a similiar problem with camper van, there was a whine related to road speed which started suddenly.
I had fitted new mud flaps and the end of one of them was touching the tyre. It was'nt happening when I jacked up vehicle as it came away from it.
murphyc1
Good Answers: 97
08/04/2009 3:48 AM
Feed the trunk monkey...
Probably a CV joint going south...You think from rear but bearing grumble not whine...not a alternator bearing...nah...garage would have you up a tree
Good Answers: 75
08/04/2009 4:27 AM
At least then he'd have the Squirrel for company!
Good Answers: 94
08/04/2009 4:51 AM
This found after Googling "Nissan Micra 1.4 automatic, whine"
The autobox is a CVT affair,runs on rubber bands. More problems than a manual sadly,prone to slipping & whining noises but better than the competition (Fiesta/Punto/Clio/Corsa).
It seems to be a recurring comment on Micra reviews.
08/04/2009 6:08 AM
I don't think it CVT, you can feel it shift between ratios and drop it from D to 2 or turn off the overdrive.
Ive popped it into the garage that does th MOt for me near where I work, he's going to run it around the block and offer an opinion. (Don't both with the matter of a pinion, gearbox jokes...)
Good Answers: 94
08/04/2009 6:17 AM
Damn, jokes preempted
08/04/2009 5:49 AM
Assuming front wheel drive, jack up the front end and run it, if this does not produce the noise, consider swapping the front tyres/wheels out.....
UPDATE!
08/04/2009 6:29 AM
Just heard from garage, he reckons rear wheel bearings, both sides.
Probably all those wretched speed bumps and pot holes around Harlow.
I'll let him do 'em and tell you all how it goes..
<exciting isn't it>
Re: UPDATE!
08/04/2009 6:37 AM
Rear wheel bearings are easy enough, Del. Given the youth of the vehicle mileage-wise, it's worth fixing if the aim is to keep it and run it "into the ground".
Re: UPDATE!
08/04/2009 6:48 AM
I'd have done 'em myself when I was a kitten...but I'll wave the magic plastic and let him do 'em while they are there.
Hopefully it will cure it and I'll have one less thing to stress about....
The down side is, I can't pop home for lunch today..
Athough there is a greasy spoon around the corner...mmmm cholesteroltastic.
Re: UPDATE!
08/04/2009 7:35 AM
No problem:
(usual disclaimer).
Re: UPDATE!
08/04/2009 9:13 AM
Is your rail picture one of a high speed rail on a curve? I've never seen one (railhead) that was not symetrical. Thanks
Re: UPDATE!
08/04/2009 10:28 AM
They don't stay symmetrical for long: the outer rail starts side-cutting and the inner one gets head-flattened.
There is a Wikipedia article on this topic for the interested reader.
Please consider registering a username for CR4, Guest!
Good Answers: 15
08/04/2009 7:37 AM
Does this car have an antenna. My truck was suddenly making a funny noise last month. Couldn't figure out what it was. Then one day I was replacing the wiper blades and noticed the antenna some how came lose. After I tightened it the strange noise went away. Guess the air flow as I was driving down the road across the lose antenna was making the funny noise because I haven't heard it since.
scotchdrnkr
WOO HOO!
08/04/2009 12:24 PM
Yup, new read wheel bearings has done the job!
...blimey it's quiet as that forrest where they go to clap with one hand whilst felling a tree to see if anyone can hear it .
Excelent... £186 , I s'pose that's not too bad these days, and I didn't have to book it in or aything.
You can all relax now.
Let's hear it for Ed's Autos.
Good Answers: 123
Re: WOO HOO!
08/05/2009 12:30 AM
It appears that I am too late to make any bad jokes at your expense. Damn it.
I will try to offer two suggestions for future use. 1) drive the car next to a wall. or a long building with the window open. Noises that are muffled or distorted, may sound much clearer when the noise is bounced off of something. 2) If the wheels have dust caps, pulling them off will usually show tiny metallic flakes present when a wheel bearing is going away.
Best wishes.
Bob
Good Answers: 94
Re: WOO HOO!
08/05/2009 4:09 AM
£186
That's more than I paid for the car I've been driving for the past 2½ years!!!
Re: WOO HOO!
08/05/2009 4:35 AM
Yeah, there was a time I'd have done it myself...I'll have to make a couple of bows to sell to pay for it...
Good Answers: 75
Re: WOO HOO!
08/05/2009 9:45 AM
Hoorah!!
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: WOO HOO!
08/10/2009 11:31 AM
I'll 'ave it off yer when yer done wiv it. My one leaks.
<Splutter>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 94
Re: WOO HOO!
08/10/2009 12:07 PM
It's not as good looking as yours Pete,
Register to Reply 42 comments
Andy Germany (1); Anonymous Poster (1); aurizon (1); bob c (1); bwire (2); charsley99 (1); CUTiger (1); DaveB (1); Doogleass (1); English Rose (3); Kilowatt0 (1); LOWIQJO (1); murphyc1 (1); Nigh (4); not so smart (1); PWSlack (8); scotchdrnkr (1); Stinky Pete (1); user-deleted-1105 (11)
You might be interested in: Noise Standards, RF Noise Meters
