Previous in Forum: Connecting Two Batteries (Old and New) with UPS   Next in Forum: How to Calculate Connected Loads
20 comments
Lumen Outputs from Lamps
08/13/2009 6:38 AM
helo every one,
When I was recently looking for some information about LED lighting, i found that one of the manufacturer has indicated two lumen ooutput values in his data table. One was worded as lumen (source) value 90 to 110 lumnes per watt. The other was lumen (application) value 70 to 90 lumens per watt. Can any one kindly clarify me what do we mean by these two values and which one should I reckon for my design?
I also request any one to please clarify when i mean a lamp , say metal hallide lamp of 400 watts do i mean that it is the imput power to the lamp or is it the output power from the lamp. This docubt has arisen because i found that in the LED light the catalog says "input power".
Help needed urgently please.
Ramesh.A
Pathfinder Tags: lighting design
Re: Doubts on lumen output from lamps
08/13/2009 6:51 AM
Light measurement figures are mostly bunkum and difficult to measure or comprehend.
08/13/2009 7:02 AM
Placing a luminosity measuring-device near the source will give more than double the reading than if it was placed a meter or two away.
Light intensity decays with distance.
Besides, light for application purposes is given as ambient measurement of reflected or diffused. measuring directly at the source will give an unrealistic result of measurement.
You can buy an old CDS light-meter from olf photo equipment shops, and measure and compare measurements with other lamps, in various conditions. Set the meter to the widest apperture and keep the scale at the same point - to have a steady reference point.
CDS meters require no batteries, their energy is drawn by the light you measure.
08/13/2009 7:02 AM
400W refers to the input power.
As regards the lumens, why not go for 90?
08/13/2009 7:37 AM
<....is the input power to the lamp or is it the output power from the lamp....>
It is the electrical load, the input power, for supply sizing purposes. The output power will be the same, though it will be distributed between light and heat.
<...lumens per watt...>
This is the effectiveness of the light source, i.e. the amount of light produced for each unit of electrical power consumed. In general terms, tungsten incandescent lamps have a lower effectiveness than, say, LED lighting, though there are a number of factors to consider before carrying out design selection or installation substitution. Among them are the light's "colour temperature" and its beam angle.
Re: Lumen Outputs from Lamps
08/14/2009 3:16 AM
First of all in reply to Yuval: lumens is a measure of the total light output; lux is the measure or light intensity which decreases the further you are from the light source.
Second I don't know anything about this so I'm just guessing: look at this Wikipedia article on Luminous efficacy. I suspect that the "missing" ~20 lumens is radiated outside the visible spectrum.
08/14/2009 3:36 AM
I don't see what you mean <tee hee>
08/14/2009 4:37 AM
By "Luminosity measuring device" I didn't specifically refer to "Lumen Meter", but instead to any light intensity measuring device.
My point was that
1. light has a source with given intensity
2. light intensity decays with distance
3. reflected light keep bouncing from one surface to another, which is why photographers measure ambient light with an opal (diffused) meter - to get an average all-round intensity.
So, measuring light intensity requires a definition of what exactly do you intend to measure - it is complicated, and it has wide range of specific results, according to your intended measurement.
08/14/2009 5:09 AM
I had a light meter which broke, so I bought a heavy one instead...much more sturdy
08/14/2009 5:51 AM
You have two adjacent rooms, one darkened and the other lit, and a mutual door between them.
If you open the door, the darkened room will be lit, but the lit room will not be darkened.
Why ?
08/14/2009 6:03 AM
Essentially: all our senses are logarithmic.
08/14/2009 9:08 AM
Meaning that the lit room is slightly darkened ?
08/14/2009 6:02 AM
OK.
The point is that the OP is trying to figure out how the lamp manufacturer can specify two different values for lumens/Watt.
08/14/2009 9:11 AM
If it is a straight forward manufacturer (and let's face it: some are not), they should specify the conditions in which they took their resulted measurement, so that such a question would not arise in the first place
Good Answers: 18
08/14/2009 7:24 AM
I recommend you look into IEEE Spectrum Magazine August 2009 edition. I am sure its on line somewhere. Anyway its lead story is "The LED's Dark Side" it should give you some answers and insight.
08/14/2009 6:14 PM
And throw some light on the subject?
08/14/2009 6:50 PM
Actually the article is about the non-linearity of LED's as the forward current increases, particularly the blue and white LED. It's kind of an intense (no pun intended) article about various ideas on how hole and electron pairs recombine without producing photons, but without the math. I don't think it has anything to do with the OP question. But it is a good article.
08/14/2009 9:12 AM
I suspect the two different lumen for watt values (source & application) refer to the power entering the fixture (source) and the power entering the LED lamp (application). Unlike a filament lamp, LED light sources cannot handle line voltages directly. The added losses are whatever conditioning circuitry the manufacturer has selected. But this is only a guess on my part. To find out the real answer you'll have to contact the manufacturer.
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
08/16/2009 5:23 PM
What exactly are you trying to do?
I deal with LED Lighting every day of my life, build new lights, test others, etc.
I come from a more practical point of view, that is, if it works, fine, if it doesn't, do something different..
I normally use a light meter to test the lux, or foot candles of a light source, at the point where it will be used.
Many times I find that what I learned while visiting Germany, many years ago work well. That is, move your light source closer the the area needing the light.
This way you can avoid lighting unecessary areas..
Another I have learned about LED Lighting is: The warmer the color temperature, the less lumen output you have.. which seems strange to me, because with fluorescent, it's just the opposite..
just some thoughts..
Donald
Check out our home page for specs on "Soft Neon"
08/16/2009 7:49 PM
"...warmer the color temperature, the less lumen output you have..." - It only makes sense: the shorter the wavelenght, the higher the enregy, or "penetrability"
08/18/2009 5:09 PM
I'm not sure on their exact usage of source and application, but I assume that source is the total light energy output. This is generally measured by placing the light into an integrating sphere (a sphere painted with a diffuse white coating, usually TiO2) with a light meter. The application is the light that makes it to the area where the light is pointed. The rest of the light is either absorbed by the optics, or sent out of the illuminated area. Take a look at a halogen bulb and you will see a lot of light that gets out to the side, LED's are similar. The diode emits in a cone, and the optic afterward can not send all the light to the desired area.
The watts reading as other entries have stated, is the input power. This changes depending on the input type; i.e. 120V AC will have a lower efficiency as 5V DC because electronics are needed to convert the AC to DC and drop the voltage.
hope this helps.
oh, and some terminology
The source has an intensity a given distance away, and the receiver has an irradiance. Both measured in W/cm^2, or lux and is the amount of light energy over an area; 1 Lux=0.001496 W/m^2. Where the total energy emitted is measured in Watts or lumens; 1 lumen=0.001496 W.
'Why' is not a valid question, and is more useful if restated as 'how'
Register to Reply 20 comments
Anonymous Poster (1); Campbell Lighting (1); GRAY HAIRED OLD GOAT (1); JohnDG (1); PWSlack (1); Randall (3); redfred (2); sunnycanuck@gmail.com (1); user-deleted-1105 (3); Yuval (6)
You might be interested in: Ballasts, Spectral Lamps, Heat Lamps
