Previous in Forum: Gas Absorption Refrigerator   Next in Forum: Relay Setting
15 comments
Standard Work Procedure on MCC
08/17/2009 10:42 AM
Can anybody can tell SWP to work on MCC or is there any link about it?
Re: Standard Work Procedure on MCC
08/17/2009 10:46 AM
Are you talking about live working?
Good Answers: 97
08/17/2009 12:30 PM
This Soft Ware People @ MCC (computers) do work
08/17/2009 12:55 PM
MCC=
Manchester Community College
Mesa Community College
Monroe Community College
Millenium Challenge Corp.
Mennonite Central Committee
Mott Community College
Metropolitan Community Churches
Maui Community College
Any of these correct?
08/17/2009 1:22 PM
The standard working procedure for the Manhattan Chamber of Commerce is to do no work. That is a union job that cannot be accomplished without filling out a 1087EW permit. To acquire a 1087EW permit first submit a D145 action item request, no later than a revision J copy, by printing out the form, filling in the appropriate boxes on the form and then sending a scanned copy to your supervisor. Some one should contact you, eventually.
Canada - Member - New Member
08/17/2009 3:28 PM
Motor Control Center?
Have a Happy! ;-)
08/18/2009 11:37 AM
MCC means Motor Control Centre
Good Answers: 97
08/18/2009 11:54 AM
And SWP?
06/21/2023 7:08 AM
South West of Penzance.
08/18/2009 12:14 PM
There you go, then. Are we all good to go now? Problem solved!
But seriously; try to shut off power before repairs are made, and when doing measurements or testwork (eg: voltage, amperage, power factor etc.) wear Arc Flash PPE, such as flame resistant clothing, voltage rated tools, helmet with arc flash face shield, voltage rated gloves, Category IV instruments etc.
Of course these recommendations are contingent with the voltages and current levels that you're working with, as well as your local area workplace regulations and requirements dictate.
Most of our equipment on the MCC's in our lab are 600VAC, 3 phase, with 800 amp circuit breakers being the largest.
It's also required, and a smart idea to not work alone and have a trained safety person standing by, just in case, to shut off the juice, or get help. (worst case scenario).
Try to Google "arc flash hazards" for your part of the rock, and you might pick up some good info.
Hope this helps,
Loupy
Have a Happy! ;-)
08/18/2009 3:50 PM
Loupy,
A very good start. I would only a add few things. Lock Out Tag Out (LOTO) protocols for any and all motors that the disconnect is not in the immediate control of the repair worker. All limited motion motors have two sets of limit switches. The inner limit switches work with the software to stop motion in the direction of travel, so software can permit backing of of this limit switch. The outer limit switches disables any motion from continuing. The outer limit switches may be omitted if and only if it is impossible for the motor to damage anything at the end of travel (hard stop).
Just don't forget to fill out the paperwork.
08/17/2009 6:09 PM
Why don't you give some details? What is MCC? WE CAN"T READ YOUR MIND!
Why don't you use the internet and search some, before you come here and make a complete fool of yourself.
08/18/2009 11:55 AM
Loupy
Have a Happy! ;-)
Good Answers: 101
08/17/2009 8:00 PM
AAAAARRRRRRRRGGGGGG!
More Acronyms without any definitions!
Blast!
08/18/2009 3:14 AM
SWP:
Safe Working Pressure?
Standard Work Practice?
SoftWare Patch?
08/20/2009 5:28 AM
There is no standard SWP to work on MCC panel. All SWP is created by ecah indidual personal/engineer and the most importance aspect is the safety of the people working on the MCC pane.
Talk to your chargeman or local regulation on working with MCC panel.
Register to Reply 15 comments
Anonymous Poster (1); bhupesh_purwar (1); Calnet42 (1); Hendrik (2); JohnDG (1); Loupy (3); lyn (1); PWSlack (1); redfred (2); RVZ717 (1); Simon Wan (1)
You might be interested in: Conveyor Chain, Leaf Chain, Roller Chain
