Previous in Forum: Lightning Protection   Next in Forum: Circuit Reference Handbook
Stepper Motors
09/18/2009 9:00 AM
I need to drive the variac using stepper motor.
Can anybody advice me on this
Good Answers: 97
Re: Stepper motor
09/18/2009 11:47 AM
Do you want to select the stepped setting on a variable transformer with a stepper motor?
Re: Stepper Motors
09/18/2009 11:22 PM
If it is a large variac, use a cogged belt drive to reduce the motor size required to drive it. I built one once with a 1KVA variac. They also offer systems already set up to do this but it's been a long time and I'm not sure where to find them. Google it.
Re: Stepper Motors
09/19/2009 5:02 AM
You need to supply more detail....is it to be controlled remotely, do you need indication, should it react very fast, should it be very exact?????
Tell us everything please, then we can help.
Steppers are easy to control with a small amount of electronics. I would suggest a small motor with a small toothed pulley, driving a large toothed pulley via a toothed belt. It will run more than fast enough and will still allow fine adjustment.
A simple circuit using an NE555 or the modern equivalent will be enough to drive the stepper driver.
Even simpler, would be a switch for direction and a push button for the steps, almost no electronic chips at all (except for the stepper driver chip SL7062 or 7 would be good).....really fine adjustment......
Register to Reply 3 comments
Andy Germany (1); Hendrik (1); rcapper (1)
You might be interested in: Stepper Motors, Linear Motors, Brushless Motors
