Previous in Forum: genset   Next in Forum: 11-kV Connection to 11-kV Grid
Boom Crane
11/09/2009 7:33 AM
hi all,
please i need your technical assistant:
there is problem with telescopic crane TEREX RT780. the problem is that the boom lenght is not showing on the screen, when the boom is retracted, the screen shows 12.1 meter but when the i extend the boom, the length is not changing ''increasing''. after the boom is extended for about one meter, the length reading disappear and the alarm is on showing full load on the bargraph meter. there is 5kohm potentiometer on the boom to sense the change of the boom length. i tested it and its working fine, the signal is reaching the module.
will this problem be with the computer software or its wrong setting?
i know that i should contact the manufacturer, i did but maybe the address which i sent to was not right. i have operator manual but it doeas not tell much.
i am just asking you guys in case some of you had worked or has an idea how this crane works.
thanks
Re: boom crane
11/09/2009 7:56 AM
Given the potential liability issues should the crane become the leading agent in an accident that involves damage to property, injury or death, contacting the manufacturer immediately for a service call-out is the only sensible way to go, and may even be a requirement for insurance indemnity cover on the crane.
  • Prohibit the use of the crane until the manufacturer's appointed local service agents have carried out the repair, and there is a document from them saying that this repair has been completed and tested to be working correctly.
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Boom Crane
11/09/2009 10:33 PM
Hi Guest
Not withstanding PW's reply which is absolutly correct, try looking for a 'wire pull transducer' usually threaded up the inside of the boom. If the wire has become dirty or the 'snubbing gromit' that allows the wire to return to the drum is grooved, the transducer will give erratic readings (or if the wire has broken, a static reading). This is a relatively cheap component and should not be ignored on cost grounds.
Good luck with it!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Re: Boom Crane
11/10/2009 10:36 AM
Ok, just to satisfy your curiosity:
1.-Try retracting the boom completely and measure the voltage across the pot (ends only, not wiper).
2.-Disengage the pot mechanically from the boom, find the negative side of the pot and measure the wiper against it, as you turn it fully ccw and then cw.
3.- You should read from 0% to 100% of the voltage across the pot ends. (keep an eye on the crane's display).
4a.-If the voltage increases smoothly and you have a proportional readout on the crane's display from Min. to Max. lenght, then you have a problem with the mechanical linkage to the pot.
4b.-If you have "bumpy" voltage readouts, then you have a bad pot.
4c.-If you have smooth voltage changes as you rotate the pot, but your cranes's display shows erratic measured lenghts, then the module receiving the signal has a problem.
Once you isolate the problem, have a certified service contractor to fix it. (You don't want liability issues).
Let us know how you finally got it up and running.
Yahlasit
Re: Boom Crane
11/11/2009 6:01 AM
hi,
i did test the voltage received on the module, its changing as the potentiomater turning, but there is no change on the display readings. when i turn the potentiometer and it reach some point, the display show dashes and alarm is on. when i turn the potentiometer opposite way, the display shows back the 12.1 meters, the lenght of the boom.
in other words, the display shows either 12.1 or dashes! no thing else!
Re: Boom Crane
11/11/2009 9:48 AM
It sounds to me like a saturated ADC (analog to digital converter), if you are willing to troubleshoot it yourself (which I don't advise) take out the board, identify the signal input components and gunshoot 'em all (replace them all without detailed testing), this is also called "the bulldozer technique". Just make sure you don't replace any programmable chips, (unless you have new blank chips, the software + the hardawre to "burn them" and the source code).
BUT before you embark on this adventure, why don't you call a friendly competitor? ask him to lend you the module, or have a service company to replace it as a "diagnostic" procedure. And if it is the culprit, buy a new one.
Keep us informed
Yahlasit
Good Answers: 88
Re: Boom Crane
11/12/2009 9:43 AM
Test if at fully redrawn boom your screen shows the right length. If yes it's pre A/D input cirquitry (probably an op amp) gain problem. There must be pots to adjust. If not it's pre A/D input cirquitry biasing problem. There should be pots for this also. If there aren't pots meaning calibration is done digitally just forget the project and seak manufacturer help. Any changes/servicing done recently on the crane? (e.g boom pot changing etc)
Anonymous Poster (3); Beej50 (1); PWSlack (1); SimpleMind (1)
