Previous in Forum: A Question for Real Engineers from a Self-Taught One   Next in Forum: Industrial Water Chiller Conversion
23 comments
Steam Turbine Won't Rotate
11/13/2009 2:01 PM
its question for all my friends five year before we did shut down a steam turbine with out using turning gear after five year we want to start the turbine but that is not rotating turbine 6.2 mw condencing type 14 stages brown bovery make 1975 please tel me how can we rotate it
Re: Steam Turbine Won't Rotate
11/13/2009 8:07 PM
You need to take it apart and clean it out. It is probably full of corrosion or debris.
11/13/2009 10:44 PM
And after five years you are supposed to check for balance. You are most likely to have the rotor sagged.
What happened to basic procedure of regularly rotating the rotor ? We ask even the spare rotor (un assembled) to be rotated periodically in its supports.
Engineering Fields - Nuclear Engineering - New Member Engineering Fields - Power Engineering - New Member
Location: From going to and fro on the peninsula and walking up and down on it
11/14/2009 8:40 AM
Former Navy snipes I have worked with have told me that regarding the prop shaft that on the Midway they had to manually rotate the shaft back and forth to prevent damage on start up due to shaft sag ( you wouldn't believe how much spam I get offering to rectify that problem) and on the nukes they have to leave the shaft slowly rotating while in port.
Does the unit have a separate input that would allow the application of rotational force, independent of the steam motive force?
Or the lack of lubricating during shutdown has allowed the bearing to come into contact with the rotating surface and has stuck from either developing a "suction" or a reaction between the dissimilar materials creating a thin, congealed lubricant/corrosion product "glue".
oderint dum metuant
11/14/2009 5:40 AM
My guess is also that it has sagged and now its so bad that there is contact between the rotor and the stator (if thats the right name) blades.
It needs to be taken down/apart and a new shaft installed (assuming that it has not also rusted solid in the 5 years.......new bearings if ball type or similar.
Basically it must be fully reconditioned.......by the maker is often the best way....
Even if it had run up, it would probably have shaken itself apart within a few minutes.....maybe killed a few bystanders at the same time!!!
11/14/2009 7:03 AM
stator usually guide vanes . Rotor are the blades.
11/14/2009 9:52 AM
The rotor I (we all) knew, but you haven't improved on stator, which would have been nice.....
What does one call the fixed part of a turbine where all the little pieces are mounted to turn the gas or steam through 180°?, well almost!!
Reply Off Topic (Score 6)
11/16/2009 6:20 AM
Westinghouse: stationary blade rings.
General Electric: diaphrams.
How can you be two places at once when you're actually nowhere at all?
11/14/2009 7:14 AM
start your oil pump, check oil flow and engage the turning gear. Does it turn it? Measure the turning gear motor current. Crack steam open and heat the turbine slowly.
If turning gear turns it then minimum you need to inspect the bearings before starting.
11/14/2009 12:00 PM
Hello,
Frankly speaking I would be very surprised if the rotor rotated.
After 5 years, there is a lot of rust inside the turbine which is especially danger for these places where the clearances are very tight - the steam glands, the labyrinth seals between stages, etc. It has to be clear that proper clearances are kept. So I think that this turbine should be inspected including casings opening. After "fact finding" activities will be known what is necessary to be done further. Fact finding should consist of NDT examination for entire turbine, control of vital clearances (bearings included), control of rotors alignment, etc.
The 5 years affected the rotor geometry without any doubts, so run measurement is needed. I do not think that rotor is bent in such way that is impossible to make it straight again. The rotor straightening is cheaper than buying new rotor and lasts shorter if the new or used rotor is available in months.
Certainly, it is possible to do what G.M. wrote but only under turbine owner responsibility. None of external companies specialized in steam turbines will not take responsibility and will not give a warranty for proper turbine work, I suppose
11/14/2009 1:05 PM
absolutely.
12/08/2009 4:45 AM
my dear turbine rotor is rotating in its housing an producing power with out opening the turbine casing thanks for consultation
12/08/2009 6:33 AM
Thank you for an update. Could you be so nice and briefly describe works done before machine start up?
We know that rotor was lifted by 0.2 mm. Is it all what you did?
11/14/2009 5:35 PM
There is no doubt that after five years the rotor has bowed (sagged). That is why you have a turning gear on this style machine. But 6.2 MW turbine will not sag enough to lock it up, enough to cause very high vibrations on startup, but not enough to lock it up.
There must be crap and corrosion in the interstage labys. You can try to force it to turn as has been suggested, and it might even work, but all that stuff has to go somewhere and it is not good for the machine.
Bottom line is you have to open it up and overhaul the turbine.
By the way, good answer squpek
11/14/2009 8:02 PM
You need to check the turbine journal bearings as well. After 5 yrs you will most likely shred the babbit in the bearings once the turbine starts to move. I agree with all of the folks above: a complete turbine overhaul is in order.
11/15/2009 3:17 AM
my dear bearings are in very good condition. and there is no wear on bearings. roter was stucked on active side of thrust bearing. now i tel you what we did? we opened the both bearings and checked the axial movement there was no axial move ment so we removed the both radial bearing and lift the turbine rotor 0.1 mm by adding shims on bottom adjusting segment. then we try to move it axially after removing thrust bearing. it moves axially 0.45mm . after that we try to turn it but failed. so we decided to lift the rotor0.1mm more. after lifting the rotor axial free float increases and now it is 1.35mm now its 10 pm. tomorrow we will try to rotate the rotor.WILL THE ROTOR ROTATE?
11/15/2009 4:31 AM
Yeah maybe, but will it also tear up when you start it? Probably. Will the vibrations be very high when you start it? Yes for sure. Will you damage it on startup? Yes very likely. Will the turbine efficiency be very low if you get it operating? I think so.
Will you then have to overhaul it? Yes definitely. So why are you wasting time?
11/15/2009 4:46 AM
I advice you to contact the OEM (BBC) or any of the expert servicing team.
You have to balance the rotor. There is I feel no choice. Along with that you have to check the health/ residual life of the components.
Just shimming to get the clearance is not enough. What was the original axial float? the increase of 0.9 by adding just 0.1 alignment shim does not look healthy.
It needs a complete check up, starting with removing the rotor from the casing, and preferably under guidance.
Forcing a rotating machine to rotate when it does not want to is asking for trouble. Don't do it.
11/15/2009 7:44 AM
If you want to know if it is possible to rotate the turbine after what you did, the answer is : probably the rotor will rotate ( it must not touch the turbine static parts) but let us know what is your intention:
- do you want to rotate the turbine or
- do you want to launch the turboset and produce the electricity
If you want the turboset to return to service, making heat or power without break downs, please think of problems we have mentioned here. Let me focus your attention on some basic problems just now:
You have lifted the rotor 0.2 mm up, so the upper clearances within steam path are by 0.2 mm less. If it is impulse turbine probably it is not critical as the gaps are bigger than 0.2 :-) but at reactions turbine please assure yourself if the rotor does not touch the blade shround in upper casings. Please check the oil seals gaps at bearing pedestals. The next thing you have to take into consideration is the rotor's misalignment you have done. I mean turbine rotor and generator rotor. Such big lack of rotors concentricity is not allowed by OEM, I suspect
Let us know any news your turbine related,
11/16/2009 10:27 AM
what type of coupling is used? Before starting it will be necessary to check radial run-out of turbine at the coupling end. You have to take coupling apart, highly important!
use stetoscope to listen for internal noises when rotating.
It may potentially cost a life... if neglected.
good luck.
11/16/2009 3:29 AM
Contact the turbine manufacturer for advice, and possibly a service visit.
11/16/2009 5:12 AM
I do not think that it is a must to contact turbine manufacturer. The OEM's services are the most expensive one, usually. I would be enough to get support from company experienced in steam turbine overhaul. It can not be possible when turbine is under OEM warranty period but it is not the case
11/28/2009 11:29 AM
Does this story have the end? Did the turbine rotate or not?
01/10/2011 11:41 AM
Dear Guest,
Even though the Turbine is in a closed condition, and stopped for 5 years, the rusting and the oil sediments around bearings might have hardened.
You have to open carefully and clean and then box up.
DHAYANANDHAN.S
Reply to Forum Thread 23 comments
Andy Germany (2); Anonymous Poster (5); dhayanandhan (1); G.M. (3); Jerry New Hampshire (1); Old Submarine Sailor (1); packrat561 (1); PWSlack (1); squpek (5); Steve S. (3)
