Previous in Forum: How to Print Word Documents Without Opening Them   Next in Forum: converting software
38 comments
JPEG Wierdness
01/13/2010 3:28 PM
I decided that we needed some nice posters for our offices and lab. I went to the NASA website and downloaded some very high resolution jpgs, and printed them out on our brand new HP T610 plotter, in C size. On some of the posters, there are fine lines spaced two inches apart across the image. The lines are areas of lesser ink - almost white, but not quite. They are exactly repeatable. The images that don't have the lines always print without them, and the images with the lines always print with them.
I tried all the obvious things - plenty of ink, everything is clean (brand new in fact). I search the web and called HP customer "service" which was clueless.
I tried printing the same images on our HP B&W laser printer and they show up there, too - not fine lines but kind of a wider hazy bar, in the exact same places.
Examining the images on the CRT shows no such lines.
So, here's the question - WTF is going on? Is this some sort of anti-copyright watermark or something of that sort? Has anyone ever seen this? Even better, does anyone know how to get it to go away?
Thanks
Re: need help with jpeg weirdness
01/13/2010 3:38 PM
High res.......what is your buffer memory set at?
01/13/2010 6:33 PM
I have no idea. These aren't super huge files - 3000 x 2400. Where would one find this buffer memory setting?
01/14/2010 9:01 AM
bhankiii
this sounds stupidly simple, but the manual would state how to page to the menu on the printer. This is usually how HP had done it in the past. Had something simuliar, but it was about 10 years ago.....things should have improved.
but I had problems finding it, in the manual it was'nt were it should be.
Earlier printer/plotters your would have to install extra memory. and also were able to set the memory allocations.
They could have improved on how it is done by using the slave computer to buffer the printer is connected to. I'll have to look online for at the manual.
I'll try to do it today........if you did'nt solve it already.
I'll be back.....
01/14/2010 10:02 AM
I searched the manual for "buffer" and found no reference to buffer memory.
Thanks
Re: JPEG Wierdness
01/13/2010 9:21 PM
Many of NASA's images are created from lots of small photographs stitched together. It's possible that you are seeing the edges of these individual photos.
Post links to the files so we can see for ourselves.
Re: JPEG Wierdness
01/13/2010 10:14 PM
nope -these are artist renderings of new spacecraft, not space pictures. And like I said earlier, I can zoom into see the individual pixels and there's nothing there in the image, only when I print.
Good Answers: 50
Re: JPEG Wierdness
01/13/2010 11:54 PM
What application are you using to view and print the images?
Re: JPEG Wierdness
01/14/2010 10:04 AM
I cropped and resized the images in PaintShopPro, then printed them from the Microsoft Office Picture Manager.
Good Answers: 204
Re: JPEG Wierdness
01/13/2010 11:53 PM
You have found evidence that we really didn't go to the moon, and the images have been falsified!
what application are you using to print with? I suggest the spooling algorighm is to blame... photoshop?
Re: JPEG Wierdness
01/14/2010 10:04 AM
Re: JPEG Wierdness
01/14/2010 5:27 AM
On many cameras used in the Apollo and Gemini programs, there was a fine "mesh" built into the optics.
Maybe the artist is simulating these types of pictures?
Surely its easy to see if they are regular squares or not? Your CRT may not have the resolution unless you zoom in a long way, did you try doing that?
Re: JPEG Wierdness
01/14/2010 10:14 AM
They are horizontal lines, they are not meant to be part of the image, and don't show up on the image at any level of zoom.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: JPEG Weirdness
01/14/2010 10:16 AM
Any possibility there is some kind of weird Moire pattern going on? Or, JPEG artifacts? I've seen Moire issues on my home printer, depending on the resolution of the JPEG, and how the image was created or scanned.
The old image editing software I use (Paint Shop Pro) has utilities to address both of these issues.
Just a guess.........
Tom
Re: JPEG Weirdness
01/14/2010 10:36 AM
No, I don't think so. I believe I tried printing it as a bmp also, with the same results.
Re: JPEG Wierdness
01/14/2010 10:23 AM
Here's one of the images:
http://www.nasa.gov/images/content/156336main_Orion_lunar_orbit.jpg
This one I did nothing to, just straight from the website and printed out from the Microsoft Office Picture Manager. I used high quality heavy plotter paper, and set the printer dialog box to match the paper, and selected photo quality.
When I print this in "C" size I get lines spaces 2 inches apart across the smaller dimension - which would be top to bottom in this picture, but left to right when printed since I printed it side ways. The lines appear to be areas of lessened image - not completely white. The intensity of the lines varies across the image, and the variations in the lines are exactly consisted from print to print. The lines are very fine - maybe 5 - 10 mils wide.
Good Answers: 204
Re: JPEG Wierdness
01/14/2010 2:43 PM
I'm thinking it is the inkjet printer... if you rotate the image and print you would get the same problem. I think I've seen it before, but it was always a letter size inkjet print for me and didn't matter so I never thought to try an correct it.
Chris
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
Re: JPEG Wierdness
01/14/2010 4:42 PM
The picture is in bitmap form. Open it again in photoshop and save it as a jpg. Open again and magnify to see whether the lines were put there as a copyrite.
Keep in mind some graphics have code embedded that does not allow them to be printed.
Prophet Freddy has the answer!
Re: JPEG Wierdness
01/14/2010 4:53 PM
The lines are invisible in both the bmp and jpg images. I'm assuming that there is some sort of embedded code in the files that inserts the lines during printing. That's what I'm trying to discover here.
Good Answers: 27
Re: JPEG Wierdness
01/14/2010 5:08 PM
It's like an invisible watermark. I ran into likewise trying to print some Hubble imagery.
Must be a way around it. I wonder how one would to get into the images 'properties' ...???
I'll print it out later today and see what happens
Re: JPEG Wierdness
01/14/2010 5:16 PM
Thanks to you if you can solve the riddle. It's odd because NASA images are not copyrighted, and are public domain.
Good Answers: 27
Re: JPEG Wierdness
01/14/2010 6:36 PM
Hi bhankiii........looks ok
Done on an antique HP 932 printer (I've been refilling the same cartridge for years)
If lines are equidistant maybe your printer needs to have the belt/gears cleaned?
Re: JPEG Wierdness
01/14/2010 7:08 PM
No - it's not a mechanical problem. First of all its a brand new printer (and we went through all the cleaning and alignment steps anyway). But also, the files that have the lines always print the lines and the files that don't have the lines never print the lines, even though the images are the same size. I can print them over and over in any order and only bad files will always have the problem and the others never do.
Good Answers: 27
Re: JPEG Wierdness
01/14/2010 8:09 PM
Then I suspect it's been psp resized as opposed to resampled.
Re: JPEG Wierdness
01/14/2010 10:37 PM
just throwing this out, (I haven't read all the responses, yet) Since its a new printer, is there a possibility of noise in the communication lines/cabling to the printer? or bad connection.
I hope we can find the problem.....ya know we shoot horses that go lame
Re: JPEG Wierdness
01/15/2010 6:02 AM
Just one point, if you turn the picture through 90°, do the lines still print at the same point on the picture or the paper?
Re: JPEG Wierdness
01/15/2010 11:56 AM
I was wondering that myself. I'll have to try it and see.
Good Answers: 27
Re: JPEG Wierdness
01/15/2010 1:00 PM
I don't know about the rest of the bunch here but I'll unequivocally state the obvious....."How come I didn't think of that"....ga AG, ga!
Re: JPEG Wierdness
01/15/2010 1:11 PM
You are too kind Sir...
It took me a few days to think of it too!!!
Re: JPEG Wierdness
01/15/2010 1:23 PM
too kind, stop being modest.......a few days to think of it, and you still came in first.
I'm curious to see what the results are. ga
Re: JPEG Wierdness
01/15/2010 4:43 PM
You and me both Brother!!
Good Answers: 50
Re: JPEG Wierdness
01/14/2010 8:40 PM
I went to the URL, saved the picture to my PC, opened it in Photoshop, then printed it with my Canon i9900 printer... No lines, no artifacts.
I think it might be Picture Manager.
Re: JPEG Wierdness
01/14/2010 12:51 PM
It is your printer. I printed the image provided on our plotter and got no lines at all. It printed 16x20 inch. I did print it in black and white. If you tried to print it larger than 16x20, the lines may be a remnant of the enlarging process.
The shadow directions don't match thru out the photo so it is definitely an artists rendering.
I would contact your printer rep to see if they can tell you how to fix this, Or I would just not use the prints that don't work.
Re: JPEG Wierdness
01/14/2010 2:57 PM
It's definitely an artists rendering, seeing as how the spacecraft doesn't exist yet.
Good Answers: 61
Re: JPEG Wierdness
01/14/2010 1:33 PM
The original file size is 3000 x 2400, but resizing in PSP changes the resolution. I suspect you've turned it into a hi-rez image that the plotter is having trouble handling, especially since the T610 has a max resolution of 2400x1200.
Try resampling the original image in PSP instead of resizing. That will enlarge the image without changing the resolution.
Here's a tutorial with more info.
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
Re: JPEG Wierdness
01/14/2010 2:52 PM
The most likely problem is the paper that you are using is not designed for hi resolution "photographic" reprodution. The uniformity of photographic paper is closely monitored to ensure that ink from the printer has time to equalize and blend to ensure that no streaks, lines or bloths are produced.
A government big enough to give you everything you want, is strong enough to take everything you have.
Re: JPEG Wierdness
01/14/2010 2:56 PM
The paper we're using is specifically for high resolution photo printing.
Re: JPEG Wierdness
01/14/2010 3:43 PM
Re: JPEG Wierdness
01/14/2010 3:48 PM
Thanks, I've tried all the obvious things. It's not an ink or print head issue.
Register to Reply 38 comments
Andy Germany (4); bhankiii (15); chrisg288 (2); Duckinthepond (5); nukesub629 (2); pantaz (1); phoenix911 (4); pwr2thepeople (1); silvCrow (1); tdesmit (1); vermin (2)
