Previous in Forum: What Metal Can Resist Hbr 50%?   Next in Forum: Are Canadian Hockey Sticks Better?
11 comments
MOL Resistant Material
03/01/2010 1:54 AM
Hey folks. Hope life's good.
I needed some suggestions with regards to material suitable for pumps that circulate MOL (milk of lime). My industry currently uses a grade of CI for the purpose but the casing fails after about two months or so. So there is a constant hassle of changing these pumps.
Could anyone suggest some material or coating if its possible that is cost effective and would give better life.
Pathfinder Tags: MOL resistant material
Re: MOL resistant material
03/01/2010 4:01 AM
According to this, cast iron has excellent corrosion compatibility with calcium hydroxide.
So the mechanism of failure needs to be examined in greater depth.
03/02/2010 4:27 AM
Thanks . Well I was thinking on the lines that maybe a particular grade of CI is more effective. It does look like that the failure is due to errosion at spots where the vortises are formed!
03/01/2010 4:20 AM
Titanium also looked good, but I don't know the availability of pumps made with it. If the flow and pressure are moderate, maybe a plastic pump would work?
(Subsequent edit: A search on "titanium pumps" turned up some links, so probably worth investigating. Also answers a recent HBr question.)
03/02/2010 4:29 AM
But wont titanium go way out of budget! Plus there are availability issues with it, not to mention casting issues later!! :(
Re: MOL Resistant Material
03/02/2010 3:34 AM
Location: I come from the deep south but currently reside in the land of ice and snow, midnight sun and all that crap
03/03/2010 5:31 AM
We have successfilly used Sulzer model WPP pumps with casing material A747CB7Cu-2 and impellers of A532 IIIA for pumping MOL.
Hope this helps.
03/04/2010 1:34 AM
Hey thanks man!
So after how long do you guys need to replace the pumps now? And do these pumps run on a perpetual duty or is it intermediate running sort?
03/04/2010 2:07 AM
The pumps (one running, other installed spare) have been running 24/7 since first of April 2009 with no known problems. What concentration of MOL are you circulating?
03/04/2010 6:43 AM
Man its266kg per meter cube of water. The temperature is 92 C.
So the material and its performance sounds pretty good. How long did the original material last?
03/04/2010 6:51 AM
We don't know yet...it is a new pulp mill installation but this material has been successfully used in other slurry applications and we typically get 5 years or so life out of the pumps, many of them are in applications where we have up to 35% solids on a weight basis so you should be good to go.
03/04/2010 7:49 AM
Ahan.
Well its not pure MOL that we have at our place either. Part of teh problem is because of the errosion caused by grit. Its a CA(OH)2 producing site from CAO. Some of the stones don dissolve to we get perfect pump nightmare situation!
Register to Reply 11 comments
Pulpmillguy (3); PWSlack (1); Randall (1); Rediah (5); Tornado (1)
