Previous in Forum: DC Motors - Parallel or Serial Connections?   Next in Forum: The Three States of Cooling
12 comments
Why Three-Phase Power?
03/01/2010 11:54 PM
can anyone explain me why our power system is in only 3 -phases only?
Re: 3 ph
03/02/2010 2:10 AM
Minimum number of phases to create an balanced and hence efficient rotating magnetic field (2 phases are minimum, but they are not balanced and a bit less efficient)
Re: 3 ph
03/02/2010 2:45 AM
GA, but the system is overloaded and not accepting votes at the moment.
Re: 3 ph
03/02/2010 5:29 AM
yes but why not 4,5?
Re: 3 ph
03/02/2010 6:03 AM
Re: 3 ph
03/02/2010 6:08 AM
why there is no execeptional case used anywhere in world like 4,5 phases
Re: 3 ph
03/02/2010 11:51 PM
please go back and search in cr4 electrical engineering section, it had been discussed sometime ago.
Re: 3 ph
03/02/2010 6:04 AM
This is the second time you said that to me . I am sure you wouldn't have had I logged in .
Re: 3 ph
03/02/2010 1:17 PM
There is another important factor which is "the economic cost" of the three phase power systems, as when you design an electrical system or layout, then you take into consideration the following main factors:
- The system efficiency.
- The proper cost of the system.
Also another factor (as I think) which is "the atmospheric issues".
Thanks...............
Just live and .. Learn!!
Good Answers: 804
Re: Why Three-Phase Power?
03/02/2010 5:41 PM
My vote is that this is probably the second most asked question in this forum; maybe 50 times in the last 4 or 5 years?
03/03/2010 12:58 AM
Not sure
- 50Hz to 60Hz may be first.
- But there are other contenders
why 11KV (or x11)
What is the cable size,
(now the latest fad seems to be speed breakers)
03/04/2010 3:09 AM
There is an article in Wikipedia on three-phase power.
02/12/2012 1:31 PM
Dear Mr. Luv123,
During my 2nd year Engineering College Study days, before branching to civil, electrical, mechanical, mining and electronics, our Professor has taught that " FOR A GIVEN QUANTITY OF CONDUCTORS, POLY PHASE SYSTEM WILL CARRY or TRANSMIT/HANDLE MORE POWER than in SINGLE PHASE and HENCE LESS CURRENT and I^2R LOSS, WILL BE LESS.
The power transmitted by POLY PHASE will be N^0.5 (i.e. Sq.Root of N, where N is the number of phase used). We can have as many as 7, but and thus, Power transmitted/handled will be 7^0.5=2.645 times more than the power transmitted/handled by a single phase system. But cost will be very high and construction of alternator, motor windings will be very difficult.
Three phase is the most economical one where the power transmitted for the given material is 3^0.5 = 1.732 times more than single phase system - for the given quantity of the conductor material.
But I am a Mechanical Engineering Graduate and our other CR4 MEMBERS can give their views and answer to this subject.
Thanks,
DHAYANANDHAN.S
Register to Reply 12 comments
Ali18 (1); Anonymous Poster (5); dhayanandhan (1); JRaef (1); luv123 (2); PWSlack (1); Tornado (1)
