Previous in Forum: Mouse Problem   Next in Forum: Log In Problems
Matlab Programming
04/05/2010 1:56 PM
I am now facing a problem on my programing,stuck. for example:i wish to randomly permutation on Feeders and Component,which mean feeder come first then following by the component . the result should like that: [feeder1 comp1 feeder2 comp2........] I had use the randperm command but not wat I want.i wish to random pick the data from the set of value that i had set ,not generate by rand function. who know to solve it? thanks......
Seeking .........Not regreting........
Good Answers: 97
Re: matlab programing
04/05/2010 5:08 PM
My Matlab demo expired before I had the opportunity to work with it. I find Delphi or C easer to use.
There should be a for next or a while loop available there somewhere which you can couple to a lookup table to define/set the execution sequence.
04/06/2010 1:16 AM
well, I am not really understand what you mean. May be you can interpret it by using an example.
Good Answers: 97
04/07/2010 1:40 AM
After discovering the raw power of low level programing I don't use MatLab or LabView etc.
google for "Matlab syntax" and find ForNext , Case , Function etc
There are however many alternatives to the above.
in Delphi your program may look like this :-
For counter := 1 to endvalue Do
begin
ReadFeeder (counter);
CalculateFeeder (counter);
OutputFeeder (counter);
Next counter;
Where ReadFeeder etc are subroutines designed at doing the work.
most probably having the case of if statements inside (more or less like a meat grinder - meat in mince out)
Register to Reply 3 comments
You might be interested in: Stock and Strip Feeders, Parts Feeders, Solids Feeders
