Previous in Forum: Concrete: Rebar or Fiberglass?   Next in Forum: Support Beam Question
35 comments
Quick Gate Question
04/12/2010 4:48 AM
Hello all,
I have a quick question from the other side of the world (New Zealand). Please bear with me as I am a Chemist not a engineer.
My Partner and I are building a driveway gate and arguing over details.
It is a simple picket gate with a brace a bit like this.
Question is the height of the gate (i.e. the distance between the horizontal bracing beams) make a difference to the gate.
I want to make this distance greater (about 3-4 feet apart) to give the gate more strength. She wants them smaller about (>2 feet apart) for aesthetic reasons.
Will this difference between braces affect the strength or usability of the gate? The gate will span a 4 meter gap (not sure what that is in feet say 13 and a bit feet)
Cheers very much for your help here
Regards Rocknroll
rocknroll99
5
Re: Quick Gate Question
04/12/2010 8:57 AM
Silly boy,
This has nothing to do with engineering. This question has only one solution and it should be obvious even to a bookish chemist such as yourself.
Let me explain. There are two words here that say it all, and will relieve you of any blame in the future. Those words are: "She wants"
No amount of scientific data, reasoned explanations from experts nor graphs and pictures will ever overcome "She wants".
She knows what she wants, and that's all there is to it.
">2 feet apart" and that's it.
04/12/2010 11:06 PM
I thought the two words were going to be 'yes dear'. That's usually how it works at my house.
J B
04/13/2010 9:00 AM
The actual words aren't critical, as long as you understand who's really in control.
04/13/2010 9:11 AM
Yes, that's so true. I can't wait to show her this thread...she'll get a kick out of it.
J B
04/14/2010 10:34 AM
Make sure the Client signs-off the "for approval" drawings......
Good Answers: 60
04/12/2010 9:33 AM
what are you on about, its a fence, not a support structure for a bridge, just ask her what she wants and build it, as thingy said she wants.
dont forget women are from a different world where women gets no matter how strange.
04/12/2010 11:08 PM
Please change your picture, you look like an IRA bomber.
04/13/2010 11:59 AM
how's this.....
04/14/2010 10:35 AM
Women also reserve the right to get extremely upset if they don't get what they didn't ask for....
Wood. One can't stick a bit on with welding rods. So, make them bigger than needed, and cut bits off until the Client accepts them.
04/14/2010 10:58 AM
But be very careful how you phrase this idea to a woman. Resizing and reshaping some wood can get very painful.
Good Answers: 179
04/12/2010 10:11 AM
Dear Rocknroll99,
Grow a set of big ones, and then tell her that the closer the diagonal strut pieces are to 45 degrees, the stronger and stiffer the gate leafs will be, even if this increases the horizontal spacing distance between the two backer boards.
Blame me if you have to....even show here this post. Ask here what is more important here: longevity, stiffness, and strength or pretty? From the street side, you're seeing mostly the vertical pickets and not much of the backer boards and diagonal stiffeners.
As an alternative to the wooden stiffeners in each gate leaf, use 1/4-inch threaded stainless steel rod with a turnbuckle located in the center and anchorage hoops at the ends for the wood screws......then paint it white like the rest of the picket fence. You'll hardly notice the diagonals then!!!!
Important tip! When installing the SS diagonal rods or wood struts, make sure the lower end is at the bottom where the gate leafs come together, and they end up at the upper backer board and leaf hinge. This arrangement will induce tensile loads in the diagonals and will permit turnbuckle adjustments up and down of the leafs where they meet!
I have these arrangements at all of the wooden fence gates on my property...one gate is 12'foot wide.......soon (next week) I'll be replacing the 550 feet of 6' wooded stockade fence that's nearly 20 years old and will be employing this very gate design in several locations for access to the back yard.
Good luck growing a set of brass BB's and convincing your "Better Half" my friend! LOL
===Signed,
CaptMoosie, Structural Engineer/ LPE
04/13/2010 11:32 AM
Ignoring the marital advice, I agree with this comment. Here are three suggestions to deal with the technical issues. I am not going to distribute marital advice. After 25 years of marriage I still haven't figured it out.
If you add additional fasteners at all the connections of fence pickets to horizontal braces, and space these fasteners apart at each connection, they will help resist the moment caused by the hanging gate.
Another option is to forego the wooden brace (which as previously stated is in compression) and add a wire element from the top of the gate near the post to the bottom of the gate at the edge that contacts with the other gate. This arrangement will put the wire in tension. Wire in tension is much stronger than wood in compression. If you add a threaded coupler to the wire, then it is also adjustable. So over the years when the gate sags you can tighten the coupler and lift the fence back up. With the wooden brace, all future adjustments have to be made by removing the brace and repositioning it. This wire element can be (should be) painted white. If the angle is low that is okay because wire in tension is so much stronger than wood. You will want to make sure the wire to wood connections at either end of the wire are sturdy.
If you like the wooden brace but find the length of the gate is not conducive to installing the wooden brace at an angle that will resist sag due to moment (i.e ratio of height of gate to length of gate is relatively small) you can add two or more braces to the same gate. That is, connect a brace from the bottom of the gate near the post to the top of the gate near midspan. Then connect another brace at the bottom of the gate near midspan to the top of the gate at the edge where the gate contacts the other gate. This creates sort of a truss. Wish I could draw this to explain it.
Anyways, I hope these ideas assist you.
04/12/2010 11:03 AM
If and only if you've already fabricated the gate the way you thought was correct do you have any argument at all. But you will still lose this argument. I recommend that you ask her to help you fabricate the gate the way she wants the gate built. This way she will be working with you. As complications happen in this fabrication, she'll be there to decide how to resolve the complications. The only way you might win this aesthetic discussion (argument is too confrontational ) is if her preferred design falls apart. If this happens you want her to have been with you during design and fabrication process.
Your actual problem is not a structural design, chemistry or any other engineering problem. The problem is an ancient societal problem that happens at times between any two people (living?) together of any combination of sexes. She was upset enough with your approach that she mentioned her displeasure. DO NOT DISMISS THIS COMPLAINT.
Good Answers: 74
04/12/2010 12:39 PM
rocknroll99,
I will confine my comments to engineering aspects of the problem as I am not an expert in 'de man and de woman' aspects.
If each leaf of the gate weighs 'W' and has length 'd', the moment on the support post is Wd/2. If the supporting hinges are centered on the horizontal boards and are separated by height 'h', the horizontal reaction top and bottom, 'H' is H = W*d/(2*h).
If the diagonal brace makes an angle β with the horizontal, the compression 'C' in the brace is C = W/(2sinβ).
If the weight of the gate leaf is carried equally by the top and bottom board, the vertical reaction at the post will be W/4 on the top hinge and 3W/4 on the bottom hinge.
As the gate is opening and closing frequently, perhaps being slammed periodically, it may be wise to multiply all hinge forces by a factor of 5 when designing the fasteners.
Bruce
Good Answers: 266
04/12/2010 1:18 PM
For aesthetic reason wouldn't it be better if the horizontal cross member match the rest of the fence as close as possible.
04/12/2010 5:39 PM
Thank you guys for your responses.
I guess your right, "What she wants" is probably the best answer. I could win the battle but I will allways loose the war.
I have spent the last 10 minutes laughting at the responses. You guys are great. Thanks for your time and I will try and "grow a pair"
Rocknroll
rocknroll99
04/13/2010 6:12 PM
Hi,
I am glad that you realized that you really had only two choices, either do it now or do it all over again later ... you are right, winning a battle might have meant losing the war.
Good luck, J.
All of us could take a lesson from the weather. It pays no attention to criticism.
Good Answers: 213
04/12/2010 10:32 PM
PS. The diagonals are oriented incorrectly. The low end of the diagonal should be on the unsupported side of the gate, with the upper end of the diagonal nearest the hinge.
04/12/2010 10:56 PM
If I understood this properly, doest this mean the diagonal bracing beam should be oppersite to the one in the photo?
I would of thought way in the photo was the correct way to put the diagonal brace in.
rocknroll99
Good Answers: 213
04/12/2010 11:09 PM
The way the bracing is done in the photo, there is no support for the free end. With the bracing diagonal from the upper hinge, the gate will sag less with time.
04/13/2010 1:14 PM
You forget, he is in New Zeland, everything works backwards even the water swirls backwards down under...
04/13/2010 1:19 PM
I really doubt that she works backwards.
04/13/2010 5:29 PM
Not with a wooden gate. You are asking for a design in tension. If the item is nailed together (as is most common with wood as nails are easier to hide and cost less.) then he will have a problem with them pulling out with usage. Place all wooden supports in compression.
As far as the question at hand. With a little bit of notching on the upper and lower horizontal members that the diagonal brace can be set in and fitting the joints tightly I see no problems with the gates themselves as each will only be two meters long. Also the pickets (vertical members) should be attached to the diagonal brace which will eliminate bowing.
However the hinges will be closer together which will place additional strain on them. Rabbiting out a pair of notches in a larger section of lumber (2 x 4) and placing the ends of the horizontal members in these will allow a more substantial place to anchor the hinges on the gate itself and can easily be worked into the gate design. This will also allow more latitude in hing placement or more hinges and disperse the load more appropriately.
Finally. Listen to the little lady. Which is more important? A gate for the driveway or a happy and loving wife?
Good Answers: 203
04/12/2010 11:31 PM
Several thoughts came to my mind when I first saw your post:
You must be new to the world of living with a woman. I've been married for 41 yrs and its been at least 35 yrs since I would have even considered asking such a question. The answers since then has always been "Yes Dear".
How good a cook are you? If you are a gourmet cook, eating gourmet is still lonely when by you are by yourself.
If you win with the gate you are for sure going to win the battle but lose the war.
Don't worry about the gate, she's always right! This is a female hormonal trait you can't fight.
Good Answers: 58
04/12/2010 11:40 PM
I like the diagonal the way it is. The diagonal is in compression, and a barn makers trick of setting the diagonal into a notch in the horizontal will be even stronger. All too often builders will expect fasteners to hold loads that proper engineering would put on the lumber. The wood should do the work, the fastener only keeps it from falling apart.
As far as spacing between the horizontals. if they are too close together, the pickets will warp all over the place, and the fence will not be straight along the top or bottom. The only way to win this one is to find one done her way and see if it stays straight. Once the pickets warp, the whole fence will have to be replaced.
mike k
04/12/2010 11:43 PM
04/14/2010 12:51 PM
So am I just speaking to myself hear or what? We both said the same thing.
04/14/2010 1:09 PM
You have replied to post #14: did you intend to? Your post was #28.
04/13/2010 1:20 AM
As mike k said the diagonals are correct for timber. It will only stay together when in compression. An angle of 45 deg. is optimal and can be achieved using not one but two diagonals in a long gate, plus one vertical. Both oriented so that they are in compression ( as per the photo. )
As cwarner7 11 said the diagonal should be in tension if you are using steel or as
captMoosie does threaded rod ( or wire ) and turnbuckles.
You should place the rails as close to the extremities of the pickets as is allowed by THE WAR OFFICE to stop the ends from twisting and bending to the point of ugliness.
04/13/2010 6:12 AM
Make sure you use kiln dried timber for your construction, glue and screw all joints tight, and paint it well to keep out moisture.
The biggest trouble will occur if you use unseasoned timber, for the gate frames themselves will twist and sag as the timber dries out.
The apearance of the timber sizes looks fine for a longer gate, and you could lift your top rail to match the fence on the left. This would add to the strength of the gate to resist sagging.
The most important thing to consider is the increased load on the hinge posts, which will have to carry the additional leverage and weight when the gate is open.
While the gate is closed the total length of fence will support the hinge post.
A rule of thumb we use in the fencing game is; a post 50% deeper into the ground is twice as strong to resisting sideways movement.
Also the post may need to be thicker as well.
Good Answers: 179
04/13/2010 8:09 AM
Yes, I agree that it is very important to build the gate with kiln dry wood and to paint the posts and the gate with several paint coats, otherwise the wood will swell a great amount in the presence of high humidity and bind-up. This did happen to my little picket fence in front of the house until I painted it with several coats of white oil-based paint; the white latex paint was useless in keeping the wood swelling in check.
04/13/2010 8:51 AM
From my experience with both wife #1 and wife #2 you should do whatever the voices in her head tell you to do!
Good Answers: 179
04/13/2010 9:29 AM
Isn't it strange how both of their voices start sounding the same as time goes on? In the same boat.......
04/13/2010 4:49 PM
Cheers again for all the fencing and relationship advice.
Thanks from Down under!
Rocknroll
rocknroll99
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
04/21/2010 8:26 AM
Hi rocknroll,
I noted the comments re the politics of the gate design and agreed with all. It didn't seem worthy to repeat the earlier comments but I came across this today and it may be helpful for all those future projects. Good luck!
Register to Reply 35 comments
Anonymous Poster (2); AussieBob (1); ba/ael (1); CaptMoosie (3); ccoop610 (1); crimich13 (2); cwarner7_11 (2); ddphillips (1); Jaan (1); JBTardis (2); JIMRAT (1); lyn (3); mike k (1); old salt (1); ozzb (1); peterg7lyq (1); phoenix911 (1); PWSlack (2); Randall (1); redfred (3); rocknroll99 (3); TimKI (1)
You might be interested in: Gate Valves, Gate Drive Transformers, Distance Meters
