Previous in Forum: Transformer Protection - 'According to Impedance'   Next in Forum: Domestic Installation
Battery connection
04/30/2010 12:28 PM
hi all ,
i want to know how i connect four 12volt battery for 24volt dc.
Re: Battery connection
04/30/2010 12:35 PM
2 batteries in series and those two sets in parallel. You only need 2 batteries in series to get 24 V. Paralleling the batteries will give you double the amp-hour capacity.
Mr.Ron from South Ms.
04/30/2010 1:18 PM
you are correct , but my problem when i run motor the does not run full speed because battery power is low.
05/04/2010 3:15 AM
Is that really the case, or is its mechanical load too high for it?
05/01/2010 2:06 AM
better group the batteries for matching terminal voltages
Better not count the cent if the risk is many many dollars.
05/03/2010 5:56 AM
I will assume by your question that you are new to this so I'll try to make it as clear as possible.
Each of your 12V batteries have a positive (+) terminal and a negative (-) terminal. Place two of the batteries lengthwise so that the + of the first one is right next to the - of the second one. Now connect the + to the - with a cable. The cable should be the right thickness to handle your current requirements. Now do the exact same thing with the other two placing them alongside the first two. Now if you look down on all 4 from above you will see that one extreme will have two +'s and the other extreme will have two -'s. Connect the two +'s together along with a cable to your 24V load which might be an inverter. Connect the two -'s together the same way and then add the negative cable also to your load.
Let's suppose your load is an inverter which will draw a maximum current of 100Amps. I would suggest that you make the interbattery jumpers using #6AWG or larger and the cables from the set of batteries to the inverter a #2AWG or larger. At 100Amps the #6 jumpers would carry 50Amps each since the load is spread over 2 sets of batteries but up to the inverter you only have one cable so it must handle 100Amps, hence the use of a #2.
05/03/2010 7:08 AM
Dear Sir,
Your question is not worth answering in this forum where in we expect
something thought provoking so that all can get enlightened. Better leave the
job to an electrician telling him what you need. Let me tell one story- In an army
interview for Officers, the candidates were asked how to erect a pole that should
be truly vertical. All gave answers but the best and expected answer came from
one , He said " I will call my havildar and order him to erect the pole & that he will
get a kick in his butt if it is not vertical" . This answer got him the job!!
Manroop, Chennai.
Reply Score 2 for Off Topic
Anonymous Poster (1); Jans (1); JOHN H VAN ALLEN (1); PWSlack (1); ronseto (1); sano2009 (1)
You might be interested in: Battery Holders, DC-DC Converter Chips
