Previous in Forum: single phase induction motor   Next in Forum: Induction motor
10 comments
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Speed control
05/01/2010 2:00 AM
What are the speed control methods of 3phase induction motor,which method is popular in industries for heavy operations upto 5 HP?
Re: Speed control
05/01/2010 2:58 AM
VFD (variable frequency drive).
Re: Speed control
05/01/2010 4:20 AM
But in an old plant we are using resistors in rotor I said it improve torque not speed, we should use VFD OR EMF injuction method.The industry have lot of 5 HP indn. Motors. The industry is always overburdened of electricity bills.Can i make a drastic change in electricity bill by implimenting VFD.
Re: Speed control
05/04/2010 3:12 AM
The mechanical load determines the torque the motor experiences.
Re: Speed control
05/04/2010 8:56 AM
<...Can i make a drastic change in electricity bill by implimenting VFD....>
It depends upon the tariff charged.
Re: Speed control
05/01/2010 5:29 AM
VFD and two sinding speed motor
Re: Speed control
05/01/2010 5:40 AM
Sir, sinding speed motor ? VFD how much it cost for 5 HP motor we want an efficient solution for speed and torque proportional as in vehicle gears.
Re: Speed control
05/01/2010 1:08 PM
Sir, Give me a solution for control of induction motor as 4 gears in a car ( speed and torque ). We are using resistance cutting step by step inorder to get speed and torque. 1st gear less speed maximum torque and in 4th maximum speed less torque. I can shine for a new idea. 5HP 3PH INDUCTION M.
Good Answers: 119
Re: Speed control
05/01/2010 4:36 PM
A 5HP VFD can provide full rated motor torque from basically 0 RPM up to full rated RPM and maximum HP rating. The drive can also run the motor above rated speed (at reduced torque and HP). In all cases, motor temperature rise must not exceed maximum rating or damage will occur.
There are many online sources for Variable Frequency Drives and I can see several 5 HP 220V (or 440V) 3 phase GE drives starting at US $220. This will be the easiest and most efficient way to fully control your motor.
Good luck with your project.
Re: Speed control
05/04/2010 7:32 AM
Give me a solution for control of induction motor as 4 gears in a car .
VFD with regeneration for maximum system efficiency. That you must be looking on for your project.
Some Idea is here as I quickly scanned net. But you have to do a bit more research before you solidify your idea. After all that's why the projects are put into curriculum .
BTW: 5HP is a small end motor for industries.
Re: Speed control
05/09/2010 11:31 AM
A senior electrician said only squirrel cage induction motor can be VFD controlled not slip ring is it true?
Register to Reply 10 comments
Anonymous Poster (2); hithuanand (4); mjb1962853 (1); PWSlack (2); Tornado (1)
