Previous in Forum: Earth Pits   Next in Forum: Star Delta Contactor
20 comments
A Simple Question - Phase / Neutral
06/06/2010 9:48 AM
Dear friends at CR4.
I recently got cornered during a conversation due to my inept knowledge of Electrical nomenclature.
Hope you fellow engineers and electrical stalwarts can help me out.
Under normal naming in AC circuitry (1 phase): (please correct me as necessary)
a) The line at ground potential is called Neutral
b) The line with alternating polarity potential with respect to ground potential is called phase
Consider the following setup... The phase line is connected to a switch 'S1' and then connected to load 'L2' followed by Switch 'S2' and then to neutral line.
If the Switch 'S1' is closed and switch 'S2' is open then what is the connection across the switch 'S2'.
1. Is it alright to say that one end of the switch is connected to the neutral point and another end is connected to the Phase point. Or is it wrong. Or should one say that the other line is connected to the phase through the load and 'S1'. Or is there another way to state the connection across the switch 'S2'.
2. How does one express the connection across the switch S1 wherin S1 is open and S2 is closed.
3. In case both switches are open then can the following be expressed as a safe representation. One end of S1 is connected to phase and other end is open or connected to the load. also... One end of S2 is connected to the load and the other end is connected to Neutral.
Please clarify... Or if there is a specific nomenclature usage please let me know the same...
With warm regards...
vishal...
I would like to be a human in true sense one day...
India - Member - New Member
Good Answers: 164
Re: A simple question - Phase / Neutral
06/06/2010 10:11 AM
Dear vishal,
i assume you mean something like this.
i am not sure how important it is to be accurate in what you say in (1,2,3).
All that is important is, if S1 is closed,and S2 is open, therefore L2 is not active (light, fan whatever) you will get a shock if touch that red point! The impedance of the load is not going to save you.
In any case, people normally use only one switch in reality, and that will be S1. So that when it is open, nobody touching the equipment L2 should get a shock.
i wonder why the nomenclature is so important ... i have never faced this ..
06/06/2010 1:03 PM
Nice work kvsridhar, everything you mentioned is accurate but not completely the information the OP has asked. I hope you do not mind that I will reference your drawing in answering the remaining points of the OP's question. Now since this involves a disputed definition of nomenclatures and safety, my answer will be quite long to be as precise and unambiguous as possible.
First to clarify power source name designations. All electric power sources must have a source and return connection to permit power to be transferred. The most common power distribution today is AC power where sinusoidal voltage at either a 50 or 60 hertz rate appears across the source to return connections. (Most people will call this a single phase but some will insist that for this to be a phase there must be other phases available, more later.) Now if the return connection is also connected to a local earth or ground connection then this makes it a neutral connection. At no time should planned current be expected to flow through ground, with the significant exception of radio frequency transmission and receptions. The point of grounding this connection is so that if the source connection gets accidentally connected to something other than the expected load, this fault condition will likely be connecting to ground where only the wire's resistance will cause an overcurrent condition that a current interrupting device (fuse) can open the circuit preventing the overheating wires to ignite the insulation sheathing them.
Now as I mentioned, some will not consider a source voltage as a phase voltage unless there is at least one other phase somewhere. Each phase must be the same voltage, amplitude, frequency and wave shape as the other phases, what discriminates between phases is that there is a relative delay between the signals. Practically all of the delivered electric power produced today the angle between all of these phases available today will add up to the full 360° of a circle. So a three phase distribution will have phase angles 120° apart, a nine phase 20° and a two phase 180°. Since this is intended as an accurate description of nomenclature, I must point out that by IEEE standards two voltage sources 180° apart is technically considered a split phase. In a true two phase distribution, the voltages are 90° apart from each other. But to my knowledge this distribution is no longer used and split phase voltages abound with their inaccurate designation of two phases. So I prefer to consider any circuit initially designated as a two phase circuit as ambiguously defined.(Hello Andy )
Now onto safety and kvsrihar's schematic. If one had a chassis open with this schematic accurately built and both switches open, one could touch any node on the load and S2 without getting a shock, but this should not be considered safe. People should not be putting their hands inside a chassis with exposed hazardous voltages thinking that they are safe. So I will now stop using the phrase "safe to touch" and use instead at ground potential. With S2 closed and S1 open and if N really is a neutral connection then all of the previous points will be at ground potential. With S1 and S2 closed, only the nodes in contact with S2 will be at ground potential. When S1 is closed with S2 open then the red node will be at line voltage L but current limited by the impedance of the load (L2). Now depending on a variety of factors, this current limitation might make an incidental contact by a person to the red node harmless but again this should not be considered safe. The critical factors must limit the current delivered to person to at least the current level to not likely defibrulate the heart and ideally less than the current for involuntary muscle movement. This is a complex threshold that changes with the person's clothing, degree and quality of surface sweat, the contact areas to the red node and ground, and the location on the body that ground and the red node reside.
Lastly an implied but unstated question, why would S2 exist in a circuit design? Many switching supplies today can without rewiring handle all of the international AC supply voltages available. Frequently two split voltages and a ground connection is provided for power. The return is not a grounded neutral as the above schematic shows, but a grounded neutral does exist at the distribution transformer. This means that if L2 is one of these switching supplies and half voltage can enter the supply via the S1 or S2 path to ground that returns current to the neutral middle of the sourcing split voltage transformer, then one cannot turn this supply OFF by opening up just S1 or S2 alone. Also remember that because this is not a direct shorting condition, the current draw will be below any anticipated fault current trip device. So a mechanical linkage makes this a double pole switch opens or closes both of these switches.
Good Answers: 164
06/06/2010 1:13 PM
Thanks redfred, very comprehensive answer, and GA from me
06/06/2010 4:52 PM
through follow up and GA
06/07/2010 1:17 AM
Hi,
This is Vishal (vish_al210). I am replying off my desk and hence have not logged in.
Thank you very much for the explaination.
I am an Embeded electronics engineer.
Please ignore S2. That was just to reference the question.
I do understand what you have stated but my question still stands.
With S2 removed and The load connected to the neutral how can the the two ends of the switch S1 be defined when the switch is open.
Is there a proper definition for Phase and neutral.
If the return phase is not grounded can it called neutral or is it to be referenced as Phase2.
Either case how should the two points of the Switch on the circuit be referenced. Please help me here.
with regards,
Vishal....
+919940131329
Good Answers: 164
06/07/2010 2:59 AM
i am getting some faint inkling of what you want...maybe wrong, you have to tell me...
i would say
  • Terminal 1 of S1 is connected to LINE
  • Terminal 2 of S1 is connected to terminal 1 of LOAD2
  • Terminal 2 of LOAD L2 is connected to NEUTRAL (which may or may not be earthed)
S2 having been eliminated.
Is this what you mean?
06/07/2010 12:16 PM
Yes Mr. Sridhar.
You have got my question right.
I have gone through 4 years of engineering course in Electrical and Electronics (2000-2004) and I find it shameful to ask.
I do know the concepts, the safety standards and design regulations and that if the potential at any point is varying w.r.t to the ground line it is phase. In a two wire system we may have a Phase and Neutral or Phase 1 ans Phase 2 (if neither is tied to the ground.)
The question I am ashamed to ask is:
If the switch is open (S1).. (S1 and S2 were only put in to make clear to all what the question was. But it only seems to have complicated things and left lot of them confused.)
re-iterating... if the switch S1 is open then can it be said that one end of the switch is connected to the Phase line and the other end of the switch is connected to the load end at ground potential or at Phase2 potential.
This is not while dealing with schematics or wiring diagrams. I was just verbally explaining the connection and said the same stated above. I got cornered .. and was told that I was wrong as the switch cannot be connected across phase and neutral as it would be a direct short. I tried explaining that I did not mean a switch parallel to the load but one in series. But under the given configuration the potential at the two ends of the switch will be of Phase1 and that of Phase 2 as long as the switch is open. Well once closed there is no potential (other than trace marginal voltage) difference across the switch.
I would really like to know what is the correct engineering terminology (not reference names or numbers of Schematics or wiring diagrams) of referencing the open end of the load (either side of phase or neutral) with refence to the supply lines. What potential does it carry??? Because after 14 years of schooling, 4 years of engineering and 6 years of feild/design work if I am not able to properly name this meagre point of reference then there must really be something wrong with me nad my understanding of the education.
And can someone please correct me with the definition of phase and neutral if the same mentioned in my original post is wrong.
06/07/2010 12:33 PM
Vish,
I think that you should say: S1 is connected between the Line and the Load. This should be enough to define it's status and duty.
I hope this satisfies.
Good Answers: 164
06/07/2010 12:34 PM
No no ... going by the calibre of your posts, your education is certainly not wasted. Please get your self-esteem up .. only you can do it to yourself. Do not let yourself down because of some stupid fellows who just want to pull your chain.
Coming to your (still open) question, what i would say is : Switch S1 is in the LINE side of the load, and the neutral is connected to the other side of the load, thats it
Any complex schematic can be reduced to this i believe.
Now that your post has attracted some of the best brains of CR4, i am sure you will get a better answer .. let's wait.
06/07/2010 3:29 AM
I see a couple of questions from this post. I am glad S2 has been removed. From the standpoint of identifying the TWO sides of the switch 'S1", we have to designate ONE side a name and then the other side of the switch a different name. This way we know from a schematic point of view what point we are referencing.
Since the switch provides a "Make and Break" function for the Source (hot) side of your load, the 'Make' side would be the actual line source leading right up to the input terminal side of the switch. The 'Break' side of the switch is the only side that actually breaks the source OFF of L2. Call the make side S1m and the break side of the switch S1b.....just an idea! I would not reference the return side of your LOAD as phase 2. It is the 'identified' ground wire in the circuit(return). Hope this helps..
Mark Abell
Good Answers: 164
06/07/2010 4:16 AM
Maybe this will help further?
Now we go further to muddle things a bit When you use a switch of any respectable rating (like an MCCB), it is prudent to wire it in such a way that the arc products do not come inwards and possibly wreck the innards !
OK, here i am going into the realm of short-circuits, and it is off-topic.
Good Answers: 61
06/07/2010 12:17 PM
With S2 removed:
  • The wire from the source to S1 is called the "Line" conductor, sometimes called the "Phase" conductor. Its potential with respect to ground is always at line voltage.
  • The wire from S1 to the load is called the "Switch Leg". Its potential with respect to ground is dependent upon the position of switch S1.
  • The wire from the load to the grounded side of the source is called the "Neutral" conductor, also known as the "Grounded" conductor. Its potential with respect to ground is always zero.
Note: As PWSlack mentioned with British Standards, the US National Electric Code(NEC) also prohibits independent switching of the neutral conductor.
06/06/2010 11:17 AM
this type of questions are reasonable if you are a student as it is quite natural at the beginning of your electrical course. It is explained clearly above. switches are provided in phase only. There is rules and standards to use color codes for phase and neutrals.
Good Answers: 164
06/06/2010 11:52 AM
Well, i checked the credentials of Vishal. He seems to be a software engineer going by his posts. 75 posts, so he is not new.
So, naturally he wouldn't know much about electricity, and if we can help him get some 'gyaan', what do we lose? So my response, which, i hope, will help him.
By the way Vishal, your signature statement is wonderful, keep it up, you are a good human being already i think
And, remember the CR4 doctrine, try not to give out personal data in an open forum, there are nuts here, i can vouch.
Re: A Simple Question - Phase / Neutral
06/07/2010 1:44 AM
Dear Sir,
Your quetion is the best if you are a student of Logic & not engineering.
I assume that the practice is to provide solid connection after the load ( You can
see two fuse links in a single phase main switch of which one is wired to suit the
load & other has solid copper plate on the nuetral side so only the line fuse blows).
For Three phase connection there will be a solid terminal for the neutral ( except
for change-over-switches which are 4 pole type).
Manroop.Chennai.
06/07/2010 2:36 AM
It's simple the way I look at it...
Doesn't matter which side of the load you touch, if you get a shock it's Live (phase).
If you don't it's Neutral (lucky).
Actually it's a great question, with important safety implications (there's 'cat' in the middle of that word...did you see it eh? eh?)
Id probably call it something like 'Live but connected through (or via) a load' if I was explaining it to someone.
It's a good illustration of why we generally switch Live rather than switching Neutral. (I've heard of both in commercial Laundry equipment)
06/07/2010 2:58 AM
A simple question-phase/neutral? I agree with a) and b) almost, the wording a little different but it will work. If indeed this circuit is single phase.. either 240 v-50 hz, or
120v-60 hz. One line is high potential (hot) and One line is the identified ground return line (neutral). The LOAD requires both potentials acting on it for the LOAD to work or perform! Normally you would install a switch only in the HOT side of your load.
There are only a few exceptions in the NEC code, but I am not sure about the other
country codes out there. It is hard to provide a simple answer with few details of the concern.... Mark
Mark Abell
06/07/2010 4:48 AM
British Standard 7671 does not allow switches in the neutral wire on safety grounds.
06/07/2010 7:45 AM
You are complicating the issue. With only S1, one side is indicated as Live side. The other side will be called the load side.
But then, no indication is required on the switch itself since it is reversible (connection wise).
If One of the supply phases (or end...) is grounded, you should use only S1 for safety ( isolate the load when open, and trip a circuit breaker if a fault develops...)
If no end is gounded, then S1 & S2 should be there and linked mechanically for best practice. And you do not need to baptise them with any names except indicate where they are connected to (like L1 and L2 if these letters are used somewhere else on the supply lines...ex: transformer outputs(?)).
Good Answers: 18
06/07/2010 7:52 AM
For single-phased AC power feeds (whether there is more than one phase or not), the wire with sinusoidal power on it is called the 'line' wire and the voltage it carries is 'line voltage'. The 'neutral, wire is called 'neutral'.
For multi-phased AC power feeds, phases much be distinguingished from each other. This is typically done by calling one phase 'L1', a second 'L2', and a third one 'L3'. Not all phases need be there, and they don't have to be called L1, L2, L3 .. they could just as easily be called L-A, L-B, L-C. To avoid confusion, the same convention should be used at a given facility.
As concerns control switches: in single-or multi-phased systems, it's good practice to connect them in series upstream of the load, where 'upstream' means closer to the line wire L and 'downstream' means closer to neutral. That you, just like kvsridhar said, won't get power on the upstream terminal of switch S2, which could shock an unwary electrician. (He ought to know better than working on an electrical circuit without first opening and locking a protection switch or breaker that powers that load, but we're all absent-minded at time; putting all switches on the 'line' side ensures that an electrician doesn't assume that there's no power on the upstream side of switch S2.)
Note that the above concerns CONTROL switches, which are used to turn a load on and off. For PROTECTION switches, that is switches/breakers/whatever that open automatically when there's a fault in the circuit (short circuit, short to ground, overload, etc.), the North American convention is to have a single relay contact (that is, a switch inside a protective relay) upstream of control switches where S1 presently is (here we define S1 as a control switch), which cuts off line power, but not neutral, to the control switches and the load. The European convention, however, is to cut off BOTH the line and the neutral. In that case, a protective switch upstream of where S1 is, and one downstream of where S2 is, are needed.
I'm not sure if the European convention requires that both switches be contacts within the same protective switch/breaker/whatever, but generally speaking it's good practice to have them so.
Cheers! DZ
Do unto others. Then run.
Register to Reply 20 comments
Anonymous Poster (2); DreadZontar (1); kvsridhar (6); LAA_Lucke (2); manroop (1); MasterEmaybe (2); phoenix911 (1); pwr2thepeople (1); PWSlack (1); redfred (1); user-deleted-1105 (1); vish_al210 (1)
You might be interested in: Switch Boots, Audio Switch Matrices
