Previous in Forum: Is the Bias Real Culprit Here?   Next in Forum: Gunnery
11 comments
CNC Cutting of Complex Shapes
06/18/2010 12:14 PM
Is modern cnc capability able to reproduce complex shapes. We have quite often been asked for Figure skating blades which are no longer produced and I wonder if these could be reproduced by copying. The shape can be quite complex, especially that of the rake which is used for jump take offs. Can a template be created from an actual shape and scales accordingly as these are made in different sizes to fit the selected skate boot. The material is generally hardened carbon steel.
Pathfinder Tags: figure skate copying
Re: Cnc cutting of complex shapes
06/18/2010 12:42 PM
I'm slammed for time now. Check this out.What is "Digitizing a Template?"
Re: CNC Cutting of Complex Shapes
06/18/2010 1:50 PM
If they were produced originally, I see no reason why it still can't be reproduced. The original wasn't CNC made. It was probably made by conventional machine tooling.
Mr.Ron from South Ms.
Good Answers: 97
06/18/2010 2:02 PM
Yes it can be done!
It is more than 50 years ago when I had a pair of skates in my hand. I cannot remember complicated shapes. but I was in level F (fall).
Sometimes it is better to digitize sections which is then imported into a cad/cam package and a drawing and tool-path produced from that.
A caliper, railway curves and a cad can also so wonders.
06/18/2010 2:53 PM
Hey Hendrik, I don't suppose a 'railway curve' is what we call a 'French curve' by any chance? A foot long bit of plastic which can be bent to form smooth curves when drawing?
Good Answers: 97
06/18/2010 5:36 PM
French curves may also be useful. (I had a friend who could not resist bending it - until the metal strips inside pushes out at the tip.)
Railway curves is a set of plastic arcs each about 450 mm long for drawing rail lines or roads on a plan. (inside and outside)
06/19/2010 2:32 AM
Yes, Some people just won't leave things alone!! Thanks for clearing that up!
06/19/2010 2:52 PM
If the metal itself lends itself to plasma cutting, I see no problem with scanning in and copying skate blades using a good Plasma CNC machine......
06/20/2010 2:24 AM
Ian rob,
What a great question!
There would be no issues with producing them on a CNC machining centre we are more than happy to manufacture for you .......
How many sets of blades are you planning to order?
if the answer is 1 or less than 50 then why wouuld you want to tie up a production machine such as a CNC machine it would be far more cost effective to produce them mannually.
We have an old style 3D Panograph machine that would eat that job for breakfast most likely 50 units before lunch......... That is if you have a sample of course .... or you could go to all the expense of getting a blade scanned
Could have it scanned by lunch time the you would need to create a cnc program do you have Cam software? And by dinner you have not cut metal.
Ian Rob, we more than happy to produce your blades for you just send us a sample or drawing and we can get a quotation the next day
Kind Regards and Happy Machining
Anthony@Alno
www.alnoproductservices.com.au
Mechanical Designers - Component Manufacturing - Toolmaking - Production Engineering
06/20/2010 6:21 AM
Hi Anthony, Thank you for your interest. I sell and sharpen skate blades for a living and am quite often asked for blades which are no longer made. Blades are attached to sole plates which usually come in 1/4 inch increments and the attached runners vary in length according to the sole plate. You can see some British made blades via the blade page at our web site www.iceskate.co.uk. Quantities would be small. I don't know if someone like myself could acquire the equipment and do myself or what would the cost of templating be? I could certainly send you a sample. I don't know how the various manufacturers would react to the copying even if they are no longer made. This takes me to another similar subject. Is there a 3d scanner which could store the shape of a foot in digital form and recreate from this image. I sell custom skate boots and it would be wonderful to be able to scan in customer's feet and send the image to the manufacturer who could generate a last from the digital image.
06/20/2010 7:34 PM
Ian,
Best bet is send us a sample - as for scanning we can work of a photograph that would need to taken perpendicular to the base of the foot this would not be an issue - or there was a company associated with SolidWorks that were selling small scanner for about $2500 US a couple of years ago - but I'm not sure if they are still in operation.
Anthony@Alno
Good Answers: 123
06/25/2010 10:30 PM
Many years ago there were some members of my family that had developed a technique for casting moulds of people's feet. The first step was to fill a bucket 2/3 full of concerte. Then insert the rat's customer's feet into the bucket. The next step was to allow the mold to harden, then soak in the river water. I don't remember the final steps, but I will ask my uncle. He might remember.
Bob
Register to Reply 11 comments
Andy Germany (1); Anonymous Poster (2); Anthony@ALNO (1); bob c (1); Hendrik (2); lyn (1); Mr. Truman Brain (2); ronseto (1)
