Previous in Forum: Circuit Breaker Fail Protection.   Next in Forum: CT grounding
9 comments
Weight Required for Gen Set
06/22/2010 8:24 AM
please tell me the weight(kg) for given specs diesel gen set
Diesel Genset 2275 KVA / 1820 EKW Prime Power at 11000 Volts, 3 Phase, 50 Hertz, 1500 RPM, 0.8 Power Factor.
Good Answers: 140
Re: Weight Required for Gen Set
06/22/2010 11:46 AM
You are kidding right?
06/22/2010 12:15 PM
.....and the reason this cannot be obtained by telephoning the manufacturer directly is what, please?
Good Answers: 97
06/22/2010 12:41 PM
I would guess, based on you spec's, fairly heavy, even in kg's
CRTL-Z
06/22/2010 2:13 PM
There's probably a rule of thumb on this, something like 3kg/kva for medium-size gensets. (Just a WAG.)
06/22/2010 2:56 PM
what is the acceptable tolerence?
do we have another chance? or we are eliminated from the game with the first wrong answer?
well, the similar caterpillar genset is 18.3 tons, 18,300 kg, open, skid mounted without canopy...it is your turn to play now
if you really need accurate weight call the manufacturer, or check the manual
dont say it, write it
Good Answers: 97
06/22/2010 4:26 PM
Uh...Prime or Standby?
Why would an insect in a larval stage need such a large genset?
CRTL-Z
06/22/2010 8:47 PM
I always ask the same question, what an insect has to do with heavy equipment!!!! here the site , please check , if you find out please tell me
www.cat.com
06/22/2010 3:19 PM
I stand corrected. 18,300 ÷ 2275 ≈ 8kg/kva! You learn something every day on CR4.
06/23/2010 3:01 AM
Please try with Ms. Wartsila Diesels Ltd who are dealing with Mega Watt range of
Diesel Generators. Use google search -DG set higher capacity.
S.Poornam.
Le_Noble (2); manroop (1); North of 60 (1); PWSlack (1); Tornado (2); Unredundant (2)
You might be interested in: Fuel Testers, Water Pumps
