Previous in Forum: Conversion   Next in Forum: Flange Sealing Without Gaskets
11 comments
Wall Thickness
07/07/2010 10:52 AM
Dear all,
I am designing a piping for a fire water system using the API 5L GR B, the wall thickness according to ASME B31.3 is 4.39mm, so can I opt for the nearest thickness which is 4.4mm, or should I go to the schedule 40 (STD)?
Thanks in advance.
Re: Wall Thickness
07/07/2010 12:32 PM
which NPS you have ?
Re: Wall Thickness
07/07/2010 12:57 PM
make sure to consider corrosion allowance & mill tolerance in your calculations
RK
Re: Wall Thickness
07/07/2010 2:16 PM
It's 6 inch.
The corrosion allowance and the mill tolerance, are included.
Re: Wall Thickness
07/07/2010 2:50 PM
If each alternative satisfies the specifications, then it makes sense to use the most economical. The Sch 40 might be heavier than you need, but it might cost less as a more commonly available size.
Engineering Fields - Piping Design Engineering - New Member
Re: Wall Thickness
07/08/2010 12:34 AM
It's better adopting the standard sizes available. Go for 6" SCh. 40
Regards,
Ashfaq Anwer
http://thepetrostreet.com
Re: Wall Thickness
07/08/2010 12:35 AM
Does the wall thickness calcualted by you includes the corrosion allowance and 12.5% mill tolerance.
If the above discussed has been included in your calculations then go for the schedule just immediatly high from your calculated thickness that is available in the market.
This is the engineering practice which is normally followed.
Best Regards
Ikram Ali Khan
Re: Wall Thickness
07/08/2010 9:23 AM
Pipe has a pretty good tolerance allowance.
4.39mm and 4.4mm is pretty much the same thing. I would assume that the 4.4mm is just the 4.39mm rounded up. You should be able to use 6" STD Black pipe.
Re: Wall Thickness
07/08/2010 10:47 AM
But why are you chosing the STD whitch is at 7.1mm wall thickness, however there is five wall thicknesses(4.4, 4.8, 5.2, 5.6, 6.4mm) before this STD.
Re: Wall Thickness
07/08/2010 11:18 AM
You can use the thickness which covers the min. required per code, taking into consideration the corrosion and erosion allowances. For more details, see a solved examples through the following CR4 Threads:
• In service pipe thickness limits (Post #4),
• Schedule of pipe,
• Maximum Wall Thickness for Seamless Pipe,
• Pipe minimum allowable thickness,
• Significance of "-Mill Tolerance" in the Piping Stress Analysis &
• Pipe Wall Thickness.
Re: Wall Thickness
07/11/2010 7:21 AM
sir,
as the pressure is low enough, you can use the designed pipe. In this application you can use it without further calculations.
kiran
if you are a managment professional or youth who wants to start business contact for free help for your project including financial assistance through NGO in and around Pune India
Re: Wall Thickness
07/11/2010 9:39 AM
Thank you guys for your answers,
I think I'll opt for (4.8mm), whitch satisfied the requirment of the code, and be cheapper than the STD wall.
Any comment?
Register to Reply 11 comments
Abdel Halim Galala (1); Anonymous Poster (1); ashfaqanwer (1); brkmech (1); cestrems (1); hambhp (3); Janissaries (1); kirannawathe (1); Tornado (1)
