Previous in Forum: 6 axle with 2 motors ?   Next in Forum: Gas Pipeline
28 comments
In service pipe thickness limits
01/17/2009 7:30 PM
I been doing UT thickness gauging of process line in a petrochemical company, and have been asked a question by a colleague I cant answer. I understand that on piping the ASME code allows a 12.5% reduction of wall thickness and still remain acceptable. I understand this to be true for new fabrication.
But wahat about pipes that has been in service for several years?
At what point would a pipe be considered to be worn beyond its service life are require replacement? Is this a judgment call by the owner/consultant?
Re: In service pipe thickness limits
01/17/2009 8:47 PM
"I understand that on piping the ASME code allows a 12.5% reduction of wall thickness and still remain acceptable"
That statement is not true/accurate and has been misinterpreted from the following discussion.
To determine the minimum pipe thickness:
  1. Determine applicable piping code (this example will use ASME B31.3)
  2. From Section 304.1 - the minimum thickness (tm) will be the sum of the thickness determined from the pressure equations (t) + 'c' (mechanical allowances + corrosion + erosion)
  3. The minimum thickness (T), for the pipe selected considering manufacturer's minus tolerance, shall not be less than tm
Your confused statement comes from the 12.5% manufacturer's minus tolerance (on most pipe specs but you must confirm according to your exact pipe/purchasing specification).
For example, for arguments sake, say that you determine the value (t) for an 8" pipe is 0.322". Then you want to add, for corrosion/erosion/mechanical an additional (c) 0.0625". You must then select the next higher nominal pipe size/thickness minus the 12.5% tolerance larger than (tm) 0.3845".
Therefore you would select, most likely due to availability, 8" Sch. 80 pipe (nominal = 0.500"; nominal - 12.5% underwall = 'T' = 0.4375") NOTE 0.4375" > 0.3845"
For pipes that have been in service you need to look to your jurisdictional requirements, which most likely point back to the original code of construction, or API 570.
The point at which a pipe is worn beyond its service life is when the corrosion allowance is gone and/or you have reached/gone under the required minimum thickness according to the pressure equation of the applicable code. It is not normally a judgement call - it is usually enforced by the previous paragraph, however, there are often allowances for a fitnesss-for-service test (API 579/ASME FFS-1) to be administered to allow for variances and to determine risks.
01/18/2009 4:24 AM
Good answer.
Fully agreed.
In every case you should calculate minimum wallthickness of a pipeline.
Because 12.5% reduction is a approximatly reduction from NDT personnel who
don't like to calculate.
In-line Inspections for pipelines, diagnostic and NDT
Good Answers: 120
01/18/2009 11:39 PM
refer to pipe schedules and type of corrosive service. They will advise the wall thickness for the use of steel and other metals with nested curves for expected years of service with a safety factor at various pressures.
It is cheaper to use steel and schedule it than buying totally non corrosive pipes. Then you replace it in toto after the life is done
Per Ardua Ad Astra
01/19/2009 2:12 AM
The following example demonstrates the definition of Pipe Wall Thickness Tolerance, which must to be taken into consideration while calculating the pipe wall thickness for the new construction. This tolerance is only taken to avoid the decreasing in thickness due to inaccuracy in pipe mill production. For this reason, all ASME and ASTM codes assume ±12.5% as a tolerance, and the worst case is when you received that pipes with expectation of decreasing in its pipe wall thickness. So, we have to compensate that expectation by adding what we call Pipe Wall Thickness Tolerance. Please see the following CR4 Thread: High Pressure Steam Pipe.
Given : Code : Power Piping ASME B31.1
Design Pressure (P) : 13 bar (188.5 psi), [oper. press. 10 bar (145 psi)]
Design Temperature : 180 oC (356 oF), [oper. temp. 150 oC (302 oF)]
Material : ASTM A106 Grade B, Seamless
Nominal Pipe Size : 3 inch
Find : Minimum Theoretical Wall Thickness, tm & Minimum Nominal Wall Thickness, t
Data : tm = P Do / (2 S + 2y P) + C (ASME Code B31.1)
Corrosion Allowance, C = 3 mm (0.11811 in.)
Factor, y = 0.4 (for carbon steel) [ASME Code B31.1, Table 104.1.2(A)]
Joint efficiency, E = 1.0 (for seamless pipe E=1)
Pipe Outside Diameter, Do = 3.5 inch
Allowable Tensile strength, S @ 356 oF=15000 psi (ASME B31.1,Table A-1)
Wall Thickness Tolerance = 12.5% (ASME B36.10 & ASTM A106)
Solution : By substitution into equation, tm = P Do / (2 S + 2y P) + C
= (188.5 psi)(3.5 inch)/(2*15000 psi +2*0.4*188.5 psi) + 0.11811 inch = 0.14 inch (3.6 mm)
Which is the theoretical minimum for wall thickness without allowing for wall thickness tolerance.
Thickness adjusted for wall thickness tolerance, t = tm / (100%-12.5%)
= 0.14 inch/(1-0.125)=0.14/0.875= 0.16 inch (4.06 mm)
The next greater commercial wall thickness is found from ASME B36.10 to be 0.216 inch (5.49 mm) which corresponds to 3" Sch. 40.
In other words 0.216 inch nominal pipe wall thickness is the commercial wall which, when reduced by the full tolerance of 12.5%, satisfies the code formula for tm.
Important Notes.
1. When you evaluate an existing piping system (inservice), no way to deduct that tolerance from the actual pipe wall thickness to evaluate the remaining strength, only the mechanical corrosion/erosion shall be considered.
2. Also, not in all cases that increasing of the pipe wall thickness is considered as advantage, where can decreases the MDMT.
02/04/2010 10:35 AM
Engineer /Abdel Halim Galala,
is true when I say this :
the minimum acceptance thickness for in service pipe should not be lass than the Nominal thickness (as per the pipe sch ) minus Tolerance minus corrosion allowanace?
actually I used to take the actual thickness(in service pipe) and compare it to the Nominal thickness -0.125-C.A.
If the thickness of in service pipe Less than (Nom thick-0.125-CA) then I will go for cut and replace
is this true?
Thanks alot Eng Abdel Alhalim
07/09/2011 11:02 AM
Dear Mr. Galala and all other participants, hi
Its perfect what calculations you did present here for determining the wall thickness for pipe according to ASME B31.3.My question here is that can we perform the same steps [find tmin, then find t by using tm/(1 - Mill_Tol%) ] for determining the pipeline wall thickness for ASME B31.8? ASME B31.3 gives formula to find MINIMUM WALL THICKNESS, but in ASME B31.8, we see the formula for finding NOMINAL WALL THICKNESS (tnominal = PD/2*S*E*F*T ). Or simply, how can I calculate the Minimum Wall Thickness for ASME B31.8?
I used to do the same steps for ASME B31.8 which you mentioned here for ASME B31.3 but one of my colleague told it wrong for ASME B31.8. He told me not to include Mill Tolerance [t = tm/(1-c%) ] with ASME B31.8 as it gives formula for nominal wall thickness, not for minimum wall thickness. According to him, once we find tm, we only have to look at standard tables (ASME B13.10) for next larger standard available thickness as we have enough margin for accomodating the effects of Mill Tolerance. I am myself not convinced of his comment but unfortunately, i cannot just find the "Minimum Wall Thickness" formula for ASME B31.8.
Would highly appreciate if you give explanation like you did for ASME B31.3 case. I need example as ASME B31.8 does not give sample calculations like ASME B31.3 App. S.
Please help me, and Thanks in advance.
07/09/2011 1:00 PM
Dear AlBaigMughal,
The pipe mill tolerance is a request and demand by the code governing the pipe material specifications, and that tolerance is due to the inaccuracy of pipe production process at mill (manufacturer). And that tolerance is ±12.5% as found at codes of ASME or ASTM for material SA 106 or A 106. See the following page which extracted from ASME SA_106, where you can find the equation:
tn x 0.875 = tm
where, tn = nominal (average) pipe wall thickness, and tm = minimum pipe wall thickness
Therefore, when I use that material of ASME SA 106, whatever the applied code B31.3 or B31.8, I have to apply that mill tolerance to avoid the worst case in reduction of thickness when it becomes -12.5%.
07/11/2011 12:36 AM
Dear Sir,
I am sorry but I think I didn't make myself very much clear. Following is my real case which might help me make the experts clear my problem:
GIVEN CONDITIONS AND DATA:
Pipe Material = API 5L X52 Seamless
NPS = 18
Service = Location Class 1, Division 2
Corrosion Allowance = 4 mm
Mill Tolerance = +0% ~ -12.5%
SMYS = 52,000 psi
Design Pressure = 1885 psig
Design Temperature = 230 Deg. Fah
FORMULA:
According to ASME B31.8 - 2007, 841.11 Steel Pipe Design Formula,
P = 2 S t F E T / D
Re-arranging for t,
t = PD/(2SEFT)
where t = Nominal Wall Thickness, (as opposed to what ASME B31.3-2008 gives which is Minimum Wall Thickness tm = t + c, according to 301.1.1 Straight Pipe General)
SOLUTION:
Now, according to my case, as defined in "GIVEN" above,
P = 1885 psig
D = 18 in.
S = 52,000 psig
E = 1.00 (Table 841.115A)
F = 0.72 (Table 841.114A and B)
T = 1.00 (Table 841.116A)
t = (1885) x (18) / [ 2 x 52,000 x 1.00 x 0.72 x 1.00 ]
= 0.4531 in.
So the Nominal Pipe Wall Thickness is
t = 0.4531 in.
Adding the Corrosion Allowance,
t = 0.4531 + Corrosion Allowance
= 0.4531 + 4/25.4
= 0.6106 in.
= 15.51 mm
My QUESTION starts from here: Do we need to divide this value of t (0.6106 in or 15.51 mm) by (1-Mill_Tolerance%) ? i.e., (100% - 12.5% = 87.5% or .875 ) keeping in view that we have already found the Nominal Wall Thickness, not the Minimum Wall Thickness?
t = 0.6106 / 0.875
= 0.6978 in.
= 17.72 mm
Is the above step of dividing the Nominal Wall Thickness by 0.875 really required? Once we have calculated the Nominal Wall Thickness using formula, what we are going to calculate by dividing it with 0.875?
According to my colleague, we simply have to look at standard tables of ASME B36.10M for the very next larger value after 0.6106 in. or15.51 mm, which is .625 in. or 15.88 mm. We don't have to include the Mill Tolerance Step and so, we don't have to see the next larger value after 0.6978 in. or 17.72 mm which is 0.75 in. or 19.05 mm. This is the point which I want you experts to clear whether the understanding of my colleague is right or we should get the mill tolerance step included in our calculations which leads to the greater wall thickness and so more cost. He seems to be right because the standard ASME B31.8 gives NOMINAL WALL THICKNESS FORMULA, not the MINIMUM WALL THICKNESS as ASME B31.3 does.
07/11/2011 9:35 AM
Yes, the method of calculation is OK.
But note that the tolerance ± 12.5% is based on ASME material SA 106, but for material API 5L X52 the tolerance is differ, please refer to the following Table 9 of API 5L "Spesifications for Line Pipe":
From Table 9, for NPS 18, the tolerance shall be + 15% & - 12.5%.
Note. The worst case for reduction in thickness in both materials (ASME SA 106 & API 5L X52) are - 12.5%, which indicates that your method of calculation is correct.
07/12/2011 12:24 AM
Thank you very much Mr. Galala for the correction of Mill Tolerance Values.
Its mean we should take into account the Mill Tolerance to calculate the Wall Thickness for Pipeline too, just like process piping according to ASME B31.3?
Yesterday, I also went through the Canadian Standard CAN/CSA-Z184-M86 Gas Pipeline System which gives the same formula to determine the pipeline wall thickness as ASME B31.8 does give, but the Canadian Standard defines the t as "Design Thickness" not "Nominal Thickness", as ASME B31.8 does. I think the definition of "t" should be corrected in ASME B31.8 as at present, it makes a lot of confusion by telling us it is "Nominal Thickness".
Anyways, Thanks alot for your kind help and time.
AlBaigMughal
07/12/2011 2:38 AM
You are welcome AlBaigMughal,
And pipe wall mill thickness tolerance is a request and demand by the standards and codes of material, and not necessary to be included at code of design.
07/08/2014 12:38 PM
Dear Mr. Abdel Hamil Galal,
Thank you very much for mentoring young engineering like us. However, if you are saying that no matter which code are ASME 31.1 or 31.8 we have to consider mill tolerance. but as per ASME code 31.8 para 841.1.1 Steel Pipe Design Formula is given for nominal thickness and they also clearly mention that "F p design factor obtained from Table 841.1.6-1. In setting the values of the design factor, F, due consideration has been given and allowance has been made for the various underthickness tolerances provided for in the pipe specifications listed and approved for usage in this Code."
Question:1
Do you think till we have to consider mill tolerance ??
Question: 2
I know, mill tolerance is not code requirement,it is requirement of material. Do you have any document reference which will prove that it is material requirement and we have to consider mill tolerance in pipe wall thickness calculation ASME 31.8.
Regards
Mayur
Project Engineer
04/14/2012 5:35 AM
you can go to www.standardshop.org
there sale a lot of asme aws api standard and so one .can immediately download,and very cheap low price!
01/05/2016 11:41 PM
regarding ASME B31.8 (and ASME B31.4) for underthickness tolerance, isn't it already covered by the design factor?
in ASME B31.8, state in para. 841.1.1 (a) regarding F= design factor "... due consideration has been given and allowance has been made for the various underthickness toler ances provided for in the pipe specifications listed..."
ASME B31.8 para. 804.5, "... nominal wall thickness, t: the wall thickness computed by or used in the design equation in para. 841.1.1 or A842.2.2(a) in Chapter VIII. Under this Code, pipe maybe ordered to this computed wall thickness without adding allowance to compensate for the underthickness tolerance permitted in approved specifications."
ASME B31.4 para. 403.2.2, "... Design factors in this Code were established with due consideration for underthickness tolerance and maximum allowable depth of imperfections allowed by the referenced standards; no additional allowance is necessary."
But for ASME B31.3, underthickness tollerance still need to be consider in determine minimum thickness, as per para. 304.1.1 (a)
01/19/2009 2:47 AM
The 12.5% is typically a manufacturing tolerance for some pipes and therefore would be allowed as such for new installation, relative to the nominal thickness. Strictly speaking, however, not all manufacturing tolerance is 12.5%. It depends on the applicable ASTM specification of the pipe. Refer to the proper ASTM standards applicable for the pipe and verify the manufacturing tolerance. Although 12.5% is considered conservative.
The criteria for allowable thickness during its service life is the calculated net thickness at corroded condition. Therefore the service corrosion allowance must be known. The minimum allowable service thickness therefore would be calculated as the nominal thickness minus the manufacturing tolerance minus the corrosion allowance, for butt welded piping. For pipes that are threaded and grooved ends or similarly prepared end conditions, the mechanical allowances are also subtracted to get the net thickness. Each pipe size has a different mechanical allowance. Consult the piping engineer who has Jurisdiction. It would be proper to confer with him with this advice you are getting. It is like getting a second opinion, at least.
After determining the minimum allowable net thickness as above, this would be the basis of comparing the measured in service thickness, such that all measured service thickness greater than the minimum allowable net thickness is still acceptable for continued service. Otherwise, the pipe needs to be replaced, since it has reached the end of its service life.
01/19/2009 3:26 AM
"The 12.5% is typically a manufacturing tolerance"
We have to differentiate between Mill Tolerance and Manufacturing Tolerance. Mill tolerance is that tolerance at Pipe Mill (Mill is that factory for producing pipes), where manufacturing tolerance may be means that tolerance while piping fabrication at workshop.
01/23/2009 6:58 AM
Please refer to the following CR4 Thread: Significance of "-Mill Tolerance" in the Piping Stress Analysis.
01/19/2009 3:24 AM
it depends also on the Corrosion Allowance of the pipe. If the pipe is in carbon steel then it should have a corrosion allowance, have a look on the piping class on the P&ID. as a first criteria if you have a corrosion above the corrosion allowance then you should change the pipe. or you could do an RBI analysis or a fitness for service analysis (API 579)
corrosion prevention & protection
01/19/2009 3:35 AM
Mill tolerance is differs from corrosion allowance, and in any case we have to take the both (mill tolerance & corrosion allowance) into consideration, and in no way they depend on each other.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
01/19/2009 8:00 AM
As already stated, the minimum wall thickness has to be calculated before purchasing the pipes by the authorized personnel.
When you make any wall thickness calculation (regardless pipe, vessel, valve...) it's really unusual you get just a "standard available thickness". Normal case is to round off to the nearest high standard thickness. But in any case the minimum calculated wall thickness remain the same and it's the value against what you must make comparisons of UT measurements results.
If measurement is lower than minimum calculated wall thickness then repair or replace the pipe.
There are even software to store the successive measurements and to predict the remaining lifetime of the pipe before it reaches the minimum thickness.
BTW, and don't take this as agressive... What thickness acceptance value do you use for UT measuring?
Kind regards
01/19/2009 5:37 PM
Hello Pitting depth is the concern, as well as wear. The defect will be convex meaning under neath the surface. 12.5% is hugh limit. I used the inspect to .0030. You can visual the wear pattern and or make a wax impression. Remember 100 %,75%,50%,25%, then half that to 12.5%. Former UT inspector of aircraft engine parts.
Good Answers: 120
01/19/2009 6:16 PM
The problem with steel piping and corrosion is the formation of small local cells that create deep pits. Once they hit the surface you can get a leaker or a squirter.
When I was in the plany business, we had reams of corrosion schedules for different pipes, fluids and temp/pressure that took a conservative approach. There were parametric lines for 5, 10,15,20 years that you had to stay within.
Perry's Chemical Engineers handbook has some of them and points you to where to find more at the various societies that have accumulated tyhis data.
Per Ardua Ad Astra
01/19/2009 7:18 PM
First of all thank you guyz for replying in my post, before when i was evaluating my the data in UT testing my basis for minimum wall thickness is -12.5% from the nominal thickness of the pipe.. So I think it is in correct for in service pipes...
After reading API 579-1/ASME FFS-1, to assesed the if the pipe is still serviceable you should compare the original design pressure to the new maximum allowable operating pressure that have been computed base on the new wall thickness from the UT thicknesss gauging you have conducted..
So do you think is this correct?.. Tnx again
01/19/2009 10:44 PM
For general wall loss you should still look to the original code of construction, whether that is B31.1, B31.3, ................
FFS (API 579) is more suitable for other defects such as localized corrosion, buckling, cracks, operating in creep range, ....... that are not explicitly covered in the original codes - and is generally used as a "last resort" to justify running equipment longer until it it can economically be replaced (i.e. not having to shut the entire plant down for a single vessel/pipeline).
(Having said that, and opening up the conversation for debate, have you specifically reviewed ALL of Section 4 and Appendix A of API 579?)
01/20/2009 1:36 AM
Section 7 "Inspection Data Evaluation, Analysis and Recording" of API 570 "Piping System Repair, Alteration, Rerating and Pressure Testing", is very interesting in evaluation of inservice piping systems. I have a solved example for determining the remaining life of a piping system, can be derived upon your request.
01/20/2009 2:50 AM
the final decision, in my opinion, shall be based on a risk assessment. It depends on what are the consequence of a failure, what is the fluid.... sometimes the leak before break criteria is also used.
What kind of fluid is inside the pipe?
S
corrosion
01/20/2009 3:50 AM
@ Abdel Halim Galala
Tnx again for replying...
about the example can u email them to me.
@ Guest.
I have read Section 4 of FFS but the problem is the appendix A, my e copy is corrupted so i cant read some parts of it, if you can send a copy of appendix A(Equations for determining MAWP, thickness, and stress in components), i would appreciate that or u just can brief me.. tnx again
01/22/2009 3:15 AM
Dear Spirochete61,
The following is an example for determining the remaining life of a pipeline based on API 570 Inspection, Repair, Alteration, and Rerating of In-service Piping Systems-Edition 98, Addendum 2006; SECTION 7—INSPECTION DATA EVALUATION, ANALYSIS, AND RECORDING
Remaining life (years) = (tactual – trequired) / corrosion rate [inches (mm) per year]
where
tactual = the actual thickness, in inches (millimeters), measured at the time of inspection for a given location or component.
trequired = the required thickness, in inches (millimeters), at the same location or component as the tactual measurement, computed by the design formulas (e.g., pressure and structural) before corrosion allowance and manufacturer's tolerance are added.
And to find the corrosion rate to be used in equation (1), we have to compute the two components of corrosion rate: LT and ST and select the greater value.
The long-term (LT) corrosion rate shall be calculated from the following formula:
Corrosion rate (LT) = (tinitial – tactual) / time (years) between tinitial and tactual
The short-term (ST) corrosion rate shall be calculated from the following formula:
Corrosion rate (ST) = (tprevious – tactual) / time (years) between tprevious and tactual
tinitial = the thickness, in inches (millimeters), at the same location as tactual measured at initial installation or at the commencement of a new corrosion rate environment.
tprevious = the thickness, in inches (millimeters), at the same location as tactual measured during a previous inspection.
Example
Pipe NPS 30"
Pipe material API 5LX, ERW
Code : ASME B31.8
Nominal pipe wall thickness, tnominal: 0.438" (11.125 mm) = tintial
MAOP 910 psi
SMYS 52 000 psi
Pipe wall thickness after 5 years, t5 = 10.625 mm
Pipe wall thickness after 10 years, t10 = 10.125 mm = tprevious
Now, the Pipe wall thickness after 15, t15 = 0.3789" (9.625 mm) = tactual
Required: Determine the remaining life of pipeline after 15 years of inservice.
Design thickness = Required thickness = Critical thickness, trequired, tr = PD / 2SFET
Where (from ASME B31.8);
Appropriate Design Factor, F = 0.72
Longitudinal Weld Joint Factor, E = 1.0
Temperature Derating Factor, T = 1.0
trequired = PD/2SEFT = (910 psi)(30 in.)/[2(52000 psi)(0.72)(1.0)(1.0)] = 0.364" (9.26 mm)
Long term corrosion rate (LT) = (tinitial – tactual) / time (years) between tinitial and tactual = (11.125 mm) – (9.625 mm) / 15 years = 0.1 mm/year
Short term corrosion rate (ST) = (tprevious – tactual) / time (years) between tprevious and tactual = (10.125 mm) – (9.625 mm) / 5 years = 0.1 mm/year
The higher value is (both are the same) = 0.1 mm/year
So, the Remaining life (years) = (tactual – trequired) / corrosion rate [inches (mm) per year] = (9.625 mm) – (9.26 mm) / 0.1 mm/year = 3.65 years
Register to Reply 28 comments
9one (1); Abdel Halim Galala (9); AlBaigMughal (3); ANDREI (1); Anonymous Poster (1); aurizon (2); Guest. (2); jackchen (1); Khalid (1); Kwetz (1); MIKE86 (1); rpocamp2 (1); Spirochete61 (2); strider6 (2)
