Previous in Forum: Pneumatic Control for Conveyor   Next in Forum: Max Process Temperature of Pressure Gauges
15 comments
Level Gauge and Level Transmitter
07/08/2010 11:51 PM
dear all,
what is difference(installation method at site,tolerance,function etc) between level gauge and level transmitter for pressure vessel(tower,drum,etc) at site?
Re: level gauge and level transmitter
07/09/2010 12:23 AM
Your question is too broad and non-specific. Tell us precisely what you are trying to do, please.
07/09/2010 12:41 AM
I'm sorry
what is difference(function) between level gauge and level transmitter for pressure vessel at petrochemical plant?
07/09/2010 10:17 AM
Whether at a petrochemical plant or not, a transmitter has an electronic output to send the measurement somewhere else, whereas a gauge does not.
07/11/2010 12:09 AM
Gauge is basically mechanical measurement by which u can see parameter value locally whereas transmittter transmit the data electronically where ever u want
Good Answers: 266
Re: Level Gauge and Level Transmitter
07/09/2010 9:09 AM
Transmitter(sensor) sends a signal in relationship to the level. A gauge is a functioning device that the level can be read from. It can be a stand alone device or can be connected to a transmitter. Installation depends on the manufacture of the devices.
07/09/2010 10:42 PM
i guess level gauge' function is device to control about pressure vessel fluid's from H.L.L(High Liquid Level) to N.L.L(Normal Liquid Level). dear all, how think about my guess ?
07/10/2010 12:29 AM
Rong Guess
07/10/2010 3:15 AM
May be you need a lot of basics and principals related with instrumentation. The attached file is in PDF format (724 Pages & 28.63 MB) is very interesting training course: Instrumentation_and_Control_Course.
07/10/2010 7:18 AM
wow, thank you very much for your comment
07/12/2010 10:30 AM
another guestion is dimension's tolerance about level gauge and level transmitter.my job is Q.C and my main task is inspect about pressure vessel and tower and reactor etc at fabrication shop. when nozzle's dimension(distance from nozzle to nozzle) inspect about pressure vessel or when pressure vessel body(category "D" joint) is welded to nozzle for level gauge and level transmitter,this distance's tolerance from nozzle to nozzle (nozzle for level gauge) is ±1mm ,but distance's tolerance from nozzle to nozzle(nozzle for level transmitter) is ±6mm. although the functional difference but the same level is, i want to know why difference fabrication tolerance between level gauge and level transmitter.
best regards
07/12/2010 11:57 AM
• The quality control related to the fits and tolerances in workshop for fabrication and assembly of pressure vessels, reactors, columns & heat exchangers are differ from company to another.
• At our workshop which hold certificates of authorization U, PP, S, R & ISO 9001, the tolerance for nozzles for level instrument is ± 2 mm.
Note. Level Instrument may be means Level Gauge LG or Level Transmitter LT.
07/12/2010 8:16 PM
thank you
Good Answers: 204
07/10/2010 11:53 AM
Level Transmitter = Analog device with usually 4-20mA output
Level Guage = Visual Indicator
Level Switch = Binary device, used to operate pumping equipment to maintain level. (on when low, off when high) (adjustable)
chris
07/10/2010 12:05 PM
thank you
Canada - Member - New Member
Good Answers: 39
07/12/2010 12:59 PM
A quick question on this from my line of work. (Customs broker) Do both the gauge and the transmitter "measure" the level in the vessel? In other words does the transmitter meet the following definition?
9026.10 Instruments and apparatus for measuring or checking the flow or level of liquids.
All that is required for evil to succeed is for good men to do nothing.
Register to Reply 15 comments
Abdel Halim Galala (2); Anonymous Poster (1); Apothicus (1); chrisg288 (1); josej (1); Mikerho (1); mkbj1205 (6); ozzb (1); PWSlack (1)
