I have continuously available 110 volts DC supply source. I want to use LEDs for illumination purpose in the analog pressure gauges. Generally 5 to 12 LEDs can be incorporated on specially manufactured PVC ring. LEDs to be connected in parallel to avoid entire blackening of circuit due to failure of any single LED in serial circuit.
I have calculated required Resistance by using Ohm's Law (V=IR) and Power Wattage by using (P=VI) formula. Generally LED consume 20 mA Current.
So, Resistance required for reducing 110 Volts to 2 Volts, Resistance works out to be of 5.4k Ohm. For safe calculation for wattage I have used 2 watt resister. When this resister put in series with LED and activated the circuit, 2 Watt Resistance is excessively heating. Like this I used many combination with different values of Resistances but heating of 2 Watt resistances are more or less same and not heat getting reduced.
Can anyone suggest me how to calculate appropriate Resistor to reduce the heating of Resister. Due to space constraints higher than 2 Watt Resistance can not be used.
