Previous in Forum: Solar Highways Video   Next in Forum: Small Scale ORC Power Gen
9 comments
Bio Fueled Water Pump
09/20/2010 1:19 PM
I don't have pictures right now, just video.
You can see a little working prototype at http://blip.tv/file/4142099 or on youtube.
I made something like this over 20 years ago but abandoned it.
I have access to different materials now.
This is the first time I have used "biofuel" to run it.
I got inspired by the windowfarms project to do this.
Perhaps some of those people can use it too.
Maybe someone can suggest a more easy way to design the part inside with the little siphon tube in it? I think this part will always be too big to fit in a pop bottle but lots of ways to make it fit in the energy drink bottles.
Brian
Re: Bio Fueled Water Pump
09/20/2010 7:07 PM
I'm very unimpressed with your yeast powered siphon system. Showing a video with excuses for why it does not work this time but making a claim that "once upon a time" it did work does not inspire confidence. The one meter of maximum vertical lift but with a net final drop in elevation tells me that you do not know the basic kinematics of how a simple siphon works. Beyond that, I recommend that you only post videos of a system that works. Nobody is interested in an excuse.
09/20/2010 11:21 PM
What on earth are you talking about? It worked fine.
A net final drop in elevation? And it isn't a "yeast powered siphon system".
The siphon is just a switch that is inside one of the bottles. You didn't understand it.
Guess that is my fault. Certainly could not be yours.
09/20/2010 11:39 PM
Ok, I'll give you the benefit of a doubt since the link you provided sent me to a site that only gave me a commercial, just like Lynlynch. One of the displayed related videos under your name is what I did view and was disappointed with. (I did have to sit through a second commercial, somebody has to pay for the bandwidth.) In that video there was a failure of a hose. So you may be accidentally presenting the wrong video.
09/20/2010 8:45 PM
All I got was a stinking commercial.
Sorry, but I don't understand what makes people think you can subject someone to a compulsory commercial every time they want to look at the video.
Good luck with the enterprise.
09/20/2010 11:35 PM
Sorry, I didn't know that they put commercials in front of the videos. I have never seen a commercial played before one of their videos so it must be a recent change.
Its on youtube too.
http://www.youtube.com/watch?v=-y1p2pZaYTM
09/20/2010 11:57 PM
I'm still not sure what you are doing but maybe you've rediscovered a version of Heron's Fountain or another of Hero's siphons that gets some added power from fermentation gas.
Good Answers: 97
09/21/2010 2:07 AM
The plant material require water to produce.
Cabbage would require about 250 mm (or more) of irrigation per season to grow,
if a plant occupy 20 x 20 cm the requirement would be 10 litre irrigation per plant.
If the energy of irrigation, harvesting etc is ignored you would at least require the "pump" to deliver 10 litre at some head to break even.
Back to the drawing board.
The person should rather eat the sauerkraut and use the energy to operate a hand pump to pump the water. At least more effective use of the bio-fuel.
Good Answers: 204
09/21/2010 2:22 AM
"The person should rather eat the sauerkraut and use the energy to operate a hand pump to pump the water. At least more effective use of the bio-fuel."
Yes, but there is absolutely no imagination in that. If nothing else, Gaiatechnician is showing something different, and exploring it with a minimal budget.
09/21/2010 1:03 PM
You can still eat the sauerkraut or drink the beer. It is not wasted.
If you use the saurkraut fermentation with weed leaves, you cannot eat the saurkraut but you get speedy compost tea instead, (I think).
The CO2 is just a waste product that nobody uses. I am thinking more of a small scale thing to recirculate water round a propagator, or plants in a greenhouse or something like that, where hand watering is an often forgotten chore. In the small scale ventures where people go away for a weekend, they often come back to dessicated seedlings.
Or for the windowfarms project. So even when the CO2 gets out of the pump, it is feeding the plants.
The windowfarms link is at http://www.youtube.com/watch?v=PkCuPrsPn_I
http://nxtwave.tripod.com/suctionpump/index.html is some animated details of my first working water pump. From over 20 years ago.
(It worked on vacuum but for this pressure operated pump, you should be able to stack pumping stages in the same fashion).
Register to Reply 9 comments
chrisg288 (1); gaiatechnician (3); Hendrik (1); lyn (1); redfred (3)
You might be interested in: Power Generation Systems, Spray Washers, Water Coolers
