Previous in Forum: Which New Hot Water Heater Should I Get? Tankless? Hybrid?   Next in Forum: chinese Hybrid Solar Air Conditioners
40 comments
Wind Powered Cooler
09/25/2010 9:16 AM
My son had the idea to mount a 'vertical turbine with a fan base' (1-2m diameter), situated to draw air through a tall cylinder (10-15m high) located about a set of coils (in, or beneath the bottom of the cylinder). The thought was, the turbine would generate enough power to run a small compressor and at the same time draw air to cool the coils and heat to rise up the cylinder as a boost (OK maybe a very small boost).
Some ideas he is floating ...
Considering a raised home, would mounting the coil under the house, run through the middle of the house and exit above the roof be advantageous? Off hand I'd say yes, as long as it is insulated well within the living spaces.
If so, roof design to enhance prevailing winds?
What about the addition of a boiler/firebox inline to power the fan (additionally acting as a venturi in the main cylinder) when the wind was not blowing enough or to increase performance.
Anyone with PE that he can quote for his paper? I am granting him (21 year old) access to the account to communicate. I will be out of the country (No internet for 6 days).
Thoughts? Impact possible in BTUs. Wind needed. Design of turbine (horizontal versus vertical). References. Thanks!
Good Answers: 60
Re: Wind Powered Cooler
09/26/2010 6:42 AM
09/26/2010 2:43 PM
CR4 ADMIN: Deleted Post #2
Vulgar/Rude:
This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
09/26/2010 9:25 PM
You give yourself way too much credit calling those 'links'. They are Google searches ... non-informative and a waste of time. If you have nothing of personal or professional experience, or any other insight of your own, they why bother on this topic.
09/26/2010 11:24 PM
Perhaps he/she is trying to help.
You get a lot of people posting questions here who dont bother or dont know how to Google.
If the information etc he provides is of no intrest to you dont read it.
09/27/2010 7:52 AM
Just look at his post on this thread ... it is obvious that he is just trying to be an annoyance. When you look at the link he provided, it says search after the url ... if you look up most of his replies to other post he does the same ... he offers no opinion ... just childish antics.
Good Answers: 60
09/27/2010 8:27 AM
these are some of my by your standard childish antics offerin no opinion
09/27/2010 8:29 PM
I'd invite everyone to check those post and go to the links and see what you are linking to ... and decide if they really are good answers. The links you provided for this post took me to absurd sites that had nothing to do with the topic ... for instance your first link leads to this:
The FIREPLACE TECHNICIAN THE FIRST MOBILE HEAT SHOP IN NEW ZEALAND Library FAQ's Troubleshooting Chimney Draft Problems We often hear the complaint that someone has a "bad" stove or fireplace because it smokes into the house. In our experience, however, draft problems are almost never caused by the fireplace or appliance. The chimney is the engine of every wood-burning system. In order for the fire to burn properly, the chimney must pull combustion air through the fireplace or stove. Here are some common causes of chimney draft problems, and possible solutions. Improper flue sizing Masonry fireplace flue sizing is determined by the size of the fireplace opening below. Masons have for many years sized fireplace flues using a "rule of thumb" that the CSA (Cross-Sectional Area) of the masonry flue be at least 1/10 the CSA of the fireplace opening. For example, an 8x12 (id) flue liner is used in a chimney venting a fireplace with an opening measuring up to 40" wide x 24" tall: larger fireplaces require larger liners. If your fireplace smokes because the flue is too small, try temporarily reducing the size of the fireplace opening with pieces of sheet metal; if this works, use masonry materials or heavy steel to accomplish a permanent solution. Proper woodstove flue sizing is determined by the stove Manufacturer for each model during the testing process. In order for a woodstove chimney to do the best possible venting job, the flue opening must have exactly the same cross-sectional area as the vent opening on the appliance. If the chimney is too small, it may not have room for the volume of rising air the stove requires. If it is too big, it may draw too slowly for the appliance, and may never heat up enough to compensate. For this reason, both flue undersizing and flue oversizing should be avoided. If your chimney is too small, replace either the chimney or the appliance. If your chimney is too big, install a masonry or stainless steel flue liner that has the same CSA as the vent opening on the appliance. Flue blockage If the chimney is the proper size and still isn't providing sufficient draft, the first thing to do is check the stovepipe and chimney flue for blockage: bird nests, fallen bricks, Frisbees, leaves, etc. can block or partially block a chimney flue, interfering with proper draft. Make sure the flue is clean: even the thinnest coating of creosote or soot reduces the flue diameter, and can interfere with proper draft.
second on the list: The Chimney Sweep Online Fireplace, Woodstove, Gas Stove and Barbecue Shop Chimney Draft Problems; Excessive Updraft Q: I read [your] discussion on drafting. I am told that I have the opposite problem - too much draft. I recently had a new Lopi Liberty woodstove installed with a stainless flue liner. When I fill the stove for a long burn, I have trouble reducing the temperature - it shoots to over 800 and completely shutting down the air supply doesn't cool it until much of the wood is burnt. What are your opinions and possible solutions?
3rd o n the list http://en.wikipedia.org/wiki/Solar_updraft_tower ... then you repost it for you lovable good answer ... ignoring that the post is for WIND NOT SOLAR. Then the scale is ignored. and on and on.
If I had my dad mention solar ... I'd say that that link would have been a great link that I would have found long ago ... The focus of the question was WIND, solar was not mentioned once.
I'd invite all to test this in your other 'good answers' and make appropriate judgement then.
and yes 21 with internet access but did not have access to this site ... can use search sites fine ... opinions were asked for, not search links ... please just go help someone else. Pretty please ... I'll throw in a cherry on top! And the walls came tumbling down.
Good Answers: 60
09/28/2010 5:43 AM
But what you have mentioned in you first post is basically a chimney with updraft and a turbine at the top
i provide some links that i think may be useful based on the pathetic amount of information you supplied.
you take a quick scan if no good don't read further and ignore
i suppose what your after is precise information without you having to do any work ?
You need to describe exactly what information you require.
But i will as you requested not help you anymore.
Good Answers: 60
09/28/2010 6:45 AM
BUT WHY WOULD THE AIR GO UP THE PIPE WITHOUT HEAT ETC TO AID IT
I THINK YOU WILL FIND IF YOU STICK A BIG PIPE UP NOTHING WILL HAPPEN.
YOU NEED TO GIVE THE WIND SOME REASON TO GO UP THE PIPE.
09/29/2010 2:05 AM
First let me say i'm sorry for coming off like a fool ... lets start over ... maybe we will both learn something.
Consider a horizontal axis wind turbine (or rotor) exposed to prevailing wind, geared to a shaft with a second perpendicular rotor located inside the top portion of a vertical tube (this will cause air movement in the tube) ... shaft also connects to a compressor located inside tube directly or by a belt (a belt would be great to change the ratio but will try direct first unless opinions suggest belt is a no brainer) ... compressor & large volume thin tank (tube in a tube) that receives compressed air, thus gets hotter pv=nrt. .... therefore, heat will be generated inside the tube ... additionally hot air can be introduced via a combustion process (incineration of waste products).
I can use less efficient components in the build and translate the loses to increase input ... In other words given a prevailing wind, I can increase the wind pressure by the amount I can show, in theory, that a different component would provide in efficiency. The build has to show how the system works and the paper can show how, if different components were used, that the desired output is achievable. Hopefully I will get close enough so that the corrected wind pressure doesn't blow the whole thing apart.
Ideas ...
Vane type compressor (TVS type looks promising and have that data) but will use components from a refrigerator (don't know how that will work out just yet) unless someone can point me in a different direction.
Turbines made via balsa (or fiberglass rods) and film (skin) - trying to keep mass low -but would a flywheel be of benefit? If so, the mass of turbines would not need to be made so light (or weak) and can just use mass of turbines instead of a flywheel? Design of perpendicular rotor considering it will act as a suction type device when prevailing winds are good (load vector down) and propulsion (load vector up) when combustion process is in use? ... Would 10 degree at the hub and 5 at the tip still apply? hopefully i can get a Cp of .25 -.3 ... and on paper .34999 :o)
Cylinders of different diameter PVC pipe sealed to make a 'tank' - would a higher conductive material, aluminum or copper, be better? Seems like it would - but would a less conductive material act as a thermal battery (slower released heat inside tube) to help drive turbine during periods of slack wind? Size of tank to store pressure for use in times of slack wind pressure ... how big is too big or too small. {We are testing that now.} The tank is what I consider a 'storage' component so the bigger the better is my opinion ... this tank may have various inlets through it to draw additional air to the center tube via venturi principle.
Heat input ... I have design and data for the incinerator via US Navy. Given that it is mentioned that only waste products may be used in any combustion process ... I'll probably need one. I'll get the wind pressure profile today (i suspect a weilbull distribution). It would be used when the prevailing wind pressure is not sufficient to meet demand (which is to be constant). Inlet entry of exhaust into the cylinder ... I suspect inlet coming in at the bottom would be most efficient ... but it would heat the pressure storage tank or does it really make a difference. The lower the inlet the lower the exit temp at turbines and possible belt drive given a sufficient additional venturi inlets ... so material selection to withstand temperatures eased for turbines is a thought. The incinerator exhaust will heat the 'tank' ... will i be able to cool the exhaust via venturi inlets? What if I angle the venturi inlets to create a vortex more or less confining the hot stream to the the center and the drawn in air at the sides of the tank ... would that work ... or will that mess things up and wind-up making a Ranque-Hilsch vortex tube ... would i need a stator type arrangement at the top to prevent that situation from occurring ... would a stator be a benefit when the incinerator was not in use ... seems like it would be a good idea from the get go ... based of jet boat pump design ... but really don't know. What about a filter ... if I directly exhaust the incinerator into the tube should I worry about that?
things I haven't spent much time thinking about ... yet:
instead of the perpendicular rotor ... an inline rotor inside an elbow arrangement.
Furling system ... good furling system for this set up anyone?
Stirling engine in conjunction with exhaust from incinerator.
Turbo charger type set up on expansion valve to aid efficiency? ... just throwing it out there ... have not put much thought into it yet.
Drawing air through a length of copper pipe placed underground thinking cooler denser 'charge' of air.
roof design ... I thought I read somewhere that the turbine should be 10m above anything ... but is that for turbulence problems for generating electric charge via a generator or just in general ... prevailing wind is from west to east due to topography and vegetation.
plantings to form a tall 'hedge' to aid in directing or compressing prevailing wind to intake of the tube.
----------------------------- I'd be just as happy if someone points out why any of these would be bad ideas so I don't waste time on them. Obviously good ideas are better :o)
Anything else to consider?
Good Answers: 60
10/02/2010 10:05 AM
optimum height for wind turbines.
You mentioned somthing about 10metres
http://www.google.co.uk/search?q=optimum+height+for+wind+turbines&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=EzynTJLcLoqQjAeKyKTuDA
"I thought I read somewhere that the turbine should be 10m above anything ... but is that for turbulence problems for generating electric charge via a generator or just in general ... prevailing wind is from west to east due to topography and vegetation."
this i beleive is in relation to the following link which is about pillar mounted wind turbines.
i have not read the links, and provide them in casr you have not found them.
If they are of no use do not read further
i would also suggest you look at the suction a roof of a house provides, this information may be on one of the links i have already provided.
its the property of the chimney/or stack protruding above the roof to provide the stack with increased updraught, if all these where incorporated into one design it may work.
Good Answers: 60
09/28/2010 2:34 PM
The purpose of this post was to assist you in learning how a chimney works,
this i thought would assist you in designing a working system.
as is the the solar illustration links i know your dad didn't mention solar, but when designing a new system i have always found in beneficial to fully understand all the variations of the subject.
all the work already undertaken on similar projects in fact anything that would help me to design a product.
so the purpose of the links was to stimulate your mind to see if there was anything else that perhaps you hadn't considered, and to show you all the systems that have been tried and tested.
This should enable you to at least make a working device without lots of experimenting.
you can thus learn from others failings.
there are after looking at the useless links i have provided a couple of ideas that spring to mind to improve on the basic idea, that incorporates some parts of all of the information contained in the links.
and once i have placed all the links in one place it saves me time because i have done all the finger work and all the links i will need to further the idea are now in one place, even if they are not usefully to you.
But as you've completely misunderstood the logic behind what i was trying to achieve.
sorry about some of the sarcastic bits but your complete misunderstanding of what i was trying to achieve was very disappointing
09/28/2010 6:22 AM
Are you a sewing machine engineer maybe? Or the operator of one?
I recommend you stay away from anything the least bit complex - seems to cause an overload.
09/28/2010 6:26 AM
very likely your right a sewing machine mechanic, also in reply to 18
Good Answers: 60
09/28/2010 6:00 AM
AND THE LAST LINK ON THIS PAGE WAS NO USE EITHER THEN
Good Answers: 60
09/26/2010 4:47 PM
09/26/2010 6:46 PM
A wind turbine could be adapted to turn a refrigerant compressor. The evaporator could serve various cooling needs, and the condenser could do some heating duty.
09/26/2010 11:20 PM
Thank you for your time ... I see your idea as basically a miniaturize version of a HVAC ... which is great, because it can be easily adapted, and I can possibly get some old fridges from a junk yard. I could get some green bonus points!
I hope to be able to cool a 200x200cm area such as a king size bed. I hope to include a thermostat so that the excess can be diverted, or debt to call upon a boiler/incinerator to activate which would hopefully increase the cooling. The Paper is to show that micro climate control can save substantial nrg in certain situations like when we go to sleep.
Do you think it would be worth it to put the condensing unit inside the mentioned cylinder to aid in updraft? Or, could better efficiency be gained by using the condenser to power a sterling engine to help run the compressor/condenser (some coils would still enter the cylinder?) Would there be enough heat there between the condenser and maybe the internal air column of the cylinder? A different way? Thoughts?
I can estimate the torque of a turbine at a given wind speed, translate that to the condenser and use the pressure change minus work to get the heat. What I see as hard to estimate, is the effect of the air movement in the column (convection). If I put the cold side of the sterling inside the column at the columns lowest part ... setting the coils of the condenser in the column a bit higher? The Stirling to run a fan inside the column to aid airflow aid the compressor.
If I can get enough BTUs out of such a system to operate a cooling blanket, I can get cracking on this idea for my school project.
For school, I just have to do the math, but I can get a free exam drop, if we also turn in a working example, where we can set up the conditions within a set of maximum parameters (So roof design might help). It is my Friday class and this is the only class I can't skip the exam with an A average (unless project is a success). Thus I'd be able to go with my dad to Port Elizabeth when he goes the week before semester break. Otherwise, I'd say ta hell with it and wait till my junior year when I have to do it.
Any help appreciated. Sorry I gave the previous guy the finger for his effort. I should have just ignored it.
09/26/2010 11:31 PM
"Anyone with PE " ?
= Physical education ?
09/27/2010 6:20 AM
Are you serious? You are on a engineering site and you don't know what a PE is?
A Professional Engineer or PE is an engineer who is registered or licensed within certain jurisdictions to offer professional services.
09/27/2010 6:27 AM
I did consider that it may be Professional engineer but it could also have been just about anything else as well.
Best to be sure dont you think ?
09/27/2010 6:33 AM
Just looked up PE on http://www.acronymfinder.com/PE.html
and as i thought there are a lot of them, so much easier to ask, even if i do get snide remarks, thanks for your help
PE
Press Enterprise (newspaper)
PE
Peru
PE
Physical Education
PE
Professional Engineer (National Council of Examiners for Engineering and Surveying)
PE
PE
Port Elizabeth (South Africa)
PE
Provider Edge (IETF RFC 2547)
PE
Private Equity
PE
Portable Executable
PE
Project Engineer
PE
Program Element (Army financial)
PE
Premature Ejaculation (male condition)
PE
Public Enemy
PE
Potential Energy
PE
Prince Edward Island (Canada)
PE
Professional Edition (usually describing software)
PE
Por Ejemplo (Spanish: For Example)
PE
Pernambuco (Brazil)
PE
Personal Edition
PE
Physical Examination
PE
Processing Element
PE
Public Education
PE
Polyethylene
PE
Por Exemplo (Portuguese: For Example)
PE
Price to Earnings (ratio)
PE
Performance Evaluation
PE
Plain Edge
PE
Planet Earth
PE
Platinum Edition
PE
Process Equipment
PE
Peterborough (postcode, United Kingdom)
PE
Pellet
PE
Per Esempio (Italian: For Example)
PE
Preliminary Engineering
PE
Photo-Etched
PE
Parlamento Europeo (Italian: European Parliament)
PE
Principal Engineer
PE
Permanent Establishment
PE
Process Engineer
Pe
Perjantai (Finnish: Friday)
PE
Program Evaluation
PE
Philadelphia Eagles
PE
Pulmonary Embolism
PE
Production Engineering
PE
Professional Ethics
PE
Phenylephrine
PE
Principles and Practice of Engineering
PE
Pulmonary Edema
PE
Parasite Eve (video game)
PE
Plant and Equipment
PE
personal effects (US DoD)
PE
Parse Error
PE
Penis Erection
PE
Preinstallation Environment (Microsoft Windows)
PE
Personalentwicklung
PE
Pleural Effusion (excess pleural cavity fluid)
PE
Product Engineer
PE
Protestant Episcopal
PE
Physical Exertion
PE
Primavera Estate (Fashion, Italy)
PE
Pericardial Effusion
PE
Pelvic Exam
PE
Petroleum Engineer
PE
Preliminary Evaluation (EPA)
PE
Point Estimate
PE
Power Engineer
PE
Peripheral Equipment
PE
Pharmacoeconomics (cost management analytical tool)
PE
Processing Engine
PE
Parity Error
PE
Pescara, Abruzzo (Italian province)
PE
Probability of Error
PE
Prostate Enlargement
PE
Project Executive
PE
Plasma Exchange
PE
Protective Earth (electrical units safety measure)
PE
Periodic Inspection
PE
Performance Efficiency
PE
Project Entropia (game)
PE
Plain End
PE
Peer Educators
PE
Phosphoethanolamine
PE
Presumptive Eligibility
PE
Playboy Enterprises
PE
Pilot Error (aircraft)
PE
Probable Error
PE
Punctuated Equilibrium
PE
Peclet Number
PE
Post Entry
PE
Physical Entity
PE
Pancreatic Enzyme
PE
Practical Exercise
PE
Permanent Employee
PE
Population Equivalent
PE
Pacific Electric Railway
PE
Phase Encoding
PE
Project Estimator
PE
peace enforcement (US DoD)
PE
Problem of Evil (philosophy)
PE
Printer's Error
PE
Parabolic Equation
PE
Processor Elements
PE
Pouvoir Executif (French)
PE
Protein Explorer
PE
Program Engineer
PE
Particulate Emission
PE
Partial Evaluation (computer languages)
PE
Procurement Executive
PE
Precision Engagement (time sensitive targeting)
PE
Private Exchange
PE
Primitive Equation
PE
Policy Element
PE
Parallax Error
PE
Port Engineer
PE
Peking Express
PE
Push Enteroscopy
PE
Premier Executive
PE
Permian Extinction (geological event)
PE
Probability of Exceedance (earthquake
PE
Probability of Exceedance (seismic risk analysis)
PE
Propulsion Equipment
PE
Protocol Elements (ITU-T)
PE
Peace Establishment
PE
Penerase (Hyper Logo command)
PE
Permanent Echo (radar)
PE
Planning Estimate
PE
Project Ego (game)
PE
Preceding Event
PE
peacetime establishment (US DoD)
PE
Potential Excess
PE
Probability of Bit Error
PE
Pipeline Execution
PE
Preço de Exercício (Portuguese: Exercise Price)
PE
Potential Earth (earth Ground point in an electrical circuit)
PE
Parasite Energy
PE
Phycoerytherin
PE
Pressure Equalizer
PE
Pure Enantiomer (crystals)
PE
Protective Entrance
PE
PTF in Error
PE
Pair Equipment
PE
Potential Electrode
PE
Polychromatic Erythroblast
PE
Probability Equivalence
PE
Precision Echo
PE
Peoples' Elbow (wrestling finishing move)
PE
Phase Estimator
PE
Perceptual Energy
PE
Pyetlyakov (Soviet aircraft designer)
PE
Permitted Explosive (mining)
PE
Preferred Elite (insurance)
PE
Preliminary Exploitation
PE
Plant Emulator
PE
Physical Inventory, Ending
PE
PAMRI Emulator HWCI
PE
Parity Even/Enable
PE
Pedal Exungulation (the clipping of toenails)
PE
Proving-Period Emergency
PE
Pervasive Expression
PE
Progressiewe Enkefalopatie
Good Answers: 60
09/27/2010 6:38 AM
looks like you had to look it up ?
Professional Engineer - Wikipedia, the free encyclopedia
A
Professional Engineer is an engineer who is registered or licensed within certain jurisdictions to offer professional services ...
en.wikipedia.org/wiki/Professional_Engineer - Similar
as your answer is suprisingly like the one above
Good Answers: 60
09/26/2010 11:33 PM
But No Googling it would seem re refrences
09/27/2010 12:04 AM
A Stirling cycle depends largely on temperature differential for any efficiency. This does not fit a wind turbine setup very well.
Generating electrical power from wind can run a compressor, but the controls will be somewhat complex and the losses significant. This more or less rules out the hermetic motor-compressor of a domestic fridge. However, an open compressor with a belt or gear drive could be run off a turbine, and could work at varying speeds.
There are still some obstacles. A compressor is very nearly a constant-torque device, whereas turbine torque varies as the square [?] of wind speed. Either some compromises will be required, or perhaps a variable-speed drive.
Before adding in combustion processes and energy recovery from them, I would start with a straightforward heat pump system as already outlined, and then consider augmenting it.
09/27/2010 7:24 AM
I thought about connecting the turbine to the compressor via a flexible shaft that is found on some electric weed eaters (though I have a concern it may melt) or perhaps just brazing it directly to the turbine shaft. Rotating mass considered, I'll have to make a trade off there I think. A 1/8 scale set up might be able to use the weaker weed eater part. If I braze it to the turbine, I'd have to come up with a way to protect it, if I go with an augmented combustion process (I am limited to burn waste products only ... trash grass leaves etc) ... putting the compressor as low as I can could get it out of the way of the augmented process.
I think that direct connecting to the turbine would require a large volume storage tank for the gas, so it can store excess pressure (hopefully) without exerting to much back pressure on the compressor. A check valve/ relief valve will probably need to be placed after the compressor. I could double wall the cylinder most of the length and make a rather large storage tank out of it. IE work off of a variable pressure in the tank rather than worrying about varying the compressor. Opinions? any better way?
09/27/2010 7:34 AM
use turbine to generate electricity which is the easiest option storage then could be in a battery then run compressor from electric motor.
this way the varible out put from the turbine would not be an issue.
also in extreme cases you could augment the stored power from solar panels or generators etc, it would be a more flexible approach giving you much more options.
Good Answers: 60
09/27/2010 8:33 AM
no opions just links to sites that use the ideas your son is suggesting, these may be of use to improve on his idea or to check feasability of project.
Solar Updraft Tower
The Solar Tower uses warm air produced in a very large greenhouse chamber which is allowed to rise through a tall tower. The updraught is used to turn a electric generator turbine at the base of the tower.
The solar updraft tower is a proposed type of renewable-energy power plant. It combines three old and proven technologies: the chimney effect, the greenhouse effect, and the wind turbine. Air is heated by sunshine and contained in a very large greenhouse-like structure around the base of a tall chimney, and the resulting convection causes air to rise up the updraft tower. This airflow drives turbines, which produce electricity. A 50MWatt prototype biult in Spain in 1981 used a greenhouse collector 240 meters in diameter feeding warm air to a tower 195 meters high.
The generating ability of a solar updraft power plant depends primarily on two factors: the size of the collector area and chimney height. With a larger collector area, a greater volume of air is warmed to flow up the chimney; collector areas as large as 7 km in diameter have been considered. With a larger chimney height, the pressure difference increases the stack effect; chimneys as tall as 1000 m have been considered.
http://www.solarthermalmagazine.com/learn-more/solar-updraft-tower/
09/27/2010 11:48 AM
Good help, I gave you the third GA, mainly for keeping a level head and continuing to try and help while someone asks for help and then gives you the finger. He and his son may not have known about Google or Wiki or if they did maybe they don't have access, there are 1000s of engineers around the world that don't have access to it due to gov't regulations. Rest assured when (and if) his son ever gets into the professional world, if he treats his coworkers to "the finger" after asking for help and getting what he thinks is no help at all, then he'll soon be unemployed. What goes around comes around.
Good Answers: 60
09/27/2010 12:18 PM
Thanks
by the way looking at the design i have listed wouldnt it be better to place one large turbine at or near the top of the chimney where i would have thought the air would be moving faster and therefore more stored energy.
in the drawing the turbines are placed at the bottom but there the moving air would surely have very little energy ?
just a thought, perhaps a little experimentation would be in order ?
calculations that may be usefufull
http://www.engineeringtoolbox.com/natural-draught-ventilation-d_122.html
10/08/2010 4:38 AM
Peter.. I argued against the Australian solar wind turbine and I think my idea was instrumental in stopping the building of a very tall and wide one in the desert .. my reason in a nutshell was this.. to continuously project a very large volume of super heated air into the upper atmosphere was bad enough.. to do that with dust and other wind borne debris would be catastrophic you would not only be disrupting the jet stream but polluting it and changing the thermal balances..Strangly no one from the company that proposed it had considered those things... So they went back to the drawing board..or whatever their so called designers used..anyway no one has built one yet..and I hope now they never will
Torque is not cheap
Good Answers: 60
09/27/2010 1:11 PM
http://www.brighthub.com/environment/renewable-energy/articles/65014.aspx
Comparison of Solar Chimney and Heliostat Solar Power Tower Systems
Article by Harlan Bengtson (8,249 pts )
Edited & published by Haresh Khemani (26,714 pts ) on Feb 25, 2010
Two different types of power tower solar plant show great promise. One is the solar chimney power plant, that generates wind in a solar chimney to drive a turbine. In the other type, like Solar One and Solar Two, each heliostat in an array sends solar power to a central receiver on a tower.
Introduction
The terms 'solar power tower' or 'power tower solar plant' are used to refer to two quite different systems that both generate solar power electricity. Both systems use a rather tall tower, but other than that they are quite different.
One type, also called a solar chimney power plant, uses solar collectors to send heated air into a very tall solar chimney. The updraft thus generated, turns a large wind turbine in the chimney/tower to generate electricity.
The other type uses mirrored heliostats. Each heliostat in a large array reflects incoming solar energy to a receiver at the top of a centrally located tower. The heat generated by the reflected solar energy is used to generate steam that is used for Rankine cycle thermal generation of electricity. Solar One and Solar Two near Barstow, CA are examples of this type.
CR4 Admin: Modified Post
Copyright Violation: Reduced copied text according to copyright law. Please see Section 13 of the CR4 FAQ about posting copyrighted material.
Good Answers: 60
09/28/2010 5:56 AM
WHAT ABOUT THIS LINK UNRELATED I SUPPOSE
Good Answers: 60
09/28/2010 5:59 AM
AND THIS ONES NO GOOD EITHER THEN I SUPPOSE
09/27/2010 4:36 PM
http://www.youtube.com/watch?v=5HWlx--tQbA&feature=related
09/28/2010 6:39 AM
So your son has dreamed up the following
Taken from other posters and Pasted below from the information contained below, i would say unless your son has a lot of spare land to forget the idea as a waste of time.
It has all been undertaken before and unless it is undertaken on a large scale does not seem worth the effort.
Just stick a big wind turbine up and couple to a large PV panel and use electricity to run AIR CON job done
Also you need to look up any Patents just in case he is infringing any of them
http://www.google.co.uk/search?q=patents+for+updraft+towers&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=RcWhTOuGLZGP4AbKsP35Ag
Solar Updraft Tower
The solar updraft tower is a proposed type of renewable-energy power plant. It combines three old and proven technologies: the chimney effect, the greenhouse effect, and the wind turbine. Air is heated by sunshine and contained in a very large greenhouse-like structure around the base of a tall chimney, and the resulting convection causes air to rise up the updraft tower. This airflow drives turbines, which produce electricity. A 50MWatt prototype built in Spain in 1981 used a greenhouse collector 240 meters in diameter feeding warm air to a tower 195 meters high.
Heat can be stored inside the collector area greenhouse to be used to warm the air later on. Water, with its relatively high specific heat capacity, can be filled in tubes placed under the collector increasing the energy storage as needed.
Turbines can be installed in a ring around the base of the tower, with a horizontal axis, as planned for the Australian project and seen in the diagram above; or—as in the prototype in Spain—a single vertical axis turbine can be installed inside the chimney.
Carbon dioxide is emitted only negligibly[citation needed] while operating, but is emitted more significantly during manufacture of its construction materials, particularly cement. Net energy payback is estimated to be 2–3 years.
A solar updraft tower power station would consume a significant area of land if it were designed to generate as much electricity as is produced by modern power stations using conventional technology. Construction would be most likely in hot areas with large amounts of very low-value land, such as deserts, or otherwise degraded land.
A small-scale solar updraft tower may be an attractive option for remote regions in developing countries.The relatively low-tech approach could allow local resources and labour to be used for its construction and maintenance.
In 1903, Spanish Colonel of the Spanish army Isidoro Cabanyes first proposed a solar chimney power plant in the magazine La energía eléctrica.One of the earliest descriptions of a solar chimney power plant was written in 1931 by a German author, Hanns Günther. Beginning in 1975, Robert E. Lucier applied for patents on a solar chimney electric power generator;
between 1978 and 1981 these patents (since expired) were granted in Australia,Canada,Israel, and the USA.
Conversion rate of solar energy to electrical energy
The solar updraft tower has power conversion rate considerably lower than many other designs in the (high temperature) solar thermal group of collectors. The low conversion rate of the Solar Tower is balanced to some extent by the low investment cost per square metre of solar collection.
According to model calculations, a simple updraft power plant with an output of 200 MW would need a collector 7 kilometres in diameter (total area of about 38 km²) and a 1000-metre-high chimney.One 200MW power station will provide enough electricity for around 200,000 typical households and will abate over 900,000 tons of greenhouse producing gases from entering the environment annually. The 38 km² collecting area is expected to extract about 0.5 percent, or 5 W/m² of 1 kW/m², of the solar power that falls upon it. Note that in comparison, concentrating thermal (CSP) or photovoltaic (CPV) solar power plants have an efficiency ranging from 20-40%. Because no data is available to test these models on a large-scale updraft tower there remains uncertainty about the reliability of these calculations.
Good Answers: 60
09/28/2010 8:43 AM
in answer to #32
this by the way was me also.
tried to see if it was just me he didnt like or the answers.
Good Answers: 60
09/28/2010 7:53 AM
THIS GUY IS BRILLIANT AND SO CHILDISH.
HE HAS MARKED MY POSTS AS UNRELATED AND DELETED MY GOOD ANSWERS FROM 54 TO 42.
WHAT DOES HE THINK THAT WILL DO ?
I DONT POST FOR THE GOOD ANSWERS I POST TO HELP
SOME PEOPLE LIKE THE LINKS I POST AS THEIR ENGLISH IS SO POOR THEY CANNOT GOOGLE OR IT MAY BE THAT THEIR GOVERMENT DOESNT ALLOW THEM TO GOOGLE
ANY WAY CHILDISH 21 YEAR OLD YOU HAVE ACHIEVD NOTHING EXCEPT TO SHOW THE WORLD HOW CHILDISH YOU ARE
Have a nice day
Good Answers: 60
09/28/2010 8:40 AM
My thanks to the moderators for their help.
I tried to get all my posts relating to this thread deleted but they cannot.
i am sorry if the OP doesnt like my answers but some people do.
you know the saying.
You cant please all the people all the time.
Register to Reply 40 comments
Anonymous Poster (11); merc600sec (1); one2playwitt (7); peterg7lyq (19); Tornado (2)
