Previous in Forum: Electronic Display - Multimeter Specification   Next in Forum: Frequency Synthesizers
41 comments
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Resolution of Electronic Display
09/05/2010 1:45 AM
If resolution of a multimeter display is 12000 digits, what is meant by that?
If you can't find a way, make one........
Re: Resolution of electronic display
09/05/2010 5:02 AM
It is one hell of a multimeter!
Charlie don't surf.
Good Answers: 60
09/05/2010 6:02 AM
Good Answers: 60
09/05/2010 6:03 AM
Good Answers: 60
09/05/2010 6:12 AM
the display has 12000 digits wide which would be impossible, you have misread the instruction manual
copy the manual and post it here or learn to read
09/05/2010 6:30 AM
I didn't told that display has 12000 digit. What I told is resolution of display is 12000 digit. Please carefully read the question.
If searching for datasheet of ''Gossen Metrawatt Metrahit series'' multimeter you can see like this.
Good Answers: 60
09/05/2010 6:44 AM
you need to learn some english your sentence doesnt make sense
and why should i search for datasheet? your the one asking for help.
send me a copy of data sheet or a link.
09/05/2010 6:58 AM
09/06/2010 12:19 AM
Both you and the manual are using technical English incorrectly. Where the manual says "4 1/2 places", it should say "4 1/2 digits". Where it says "11,999 digits", it should say something like "Maximum value of display=11,999".
"4 1/2 digits" normally means that 4 of the digits can display any value from 0 to 9, while the 5th digit has a restricted set of values that can be displayed. I suspect that the first digit of this meter can only be a zero or a one. On some meters, the rightmost digit can only be a 0 or a 5.
This display can show a variation of one part in 12,000, which is an order of magnitude more precision than most common hand-held meters. The fact that it can display such precision may or may NOT mean the instrument is accurate to that precision.
09/06/2010 12:27 AM
I agree with you, but what about my 24th comment.
Good Answers: 60
09/05/2010 6:46 AM
Good Answers: 60
09/05/2010 6:53 AM
Good Answers: 60
09/05/2010 6:59 AM
Just athought as you may not have bought the meter yet, What is the requirement of the meter
or what do you need the meter for ? then someone may be able to advise as to a better meter for the purpose you require of it
09/05/2010 7:07 AM
This multimeter suits to my need. I have only one doubt regarding that display specification. This question is asked only for my knowledge.
Good Answers: 60
09/05/2010 7:02 AM
http://datasheet.octopart.com/METRAHIT-27I-Gossen-Metrawatt-datasheet-546034.pdf
Resolution at Upper
4¾ 30000 / 3¾ 3000 do you mean this bit?
09/05/2010 7:14 AM
Please go through this link. I meant that second point in the brochure.
http://www.farnell.com/datasheets/315681.pdf
Good Answers: 60
09/05/2010 7:29 AM
Ah Ha I see what you mean I appologise for the other Negative comments i made
But it would have helped if you had posted the manual link earlier
1234.1 is the 4.5 place display as i understand the first part, but have to admit dont know what (11,999 digits), means unless it referrs to a scroll function
4½-place display (11,999 digits),
you know i dont know perhaps someone else can help.
now we have a copy of the manual
other models
http://www.amptron.th.com/GMC/Technology-Portable.html
its the 12.000 resolution thats confusing
Good Answers: 60
09/05/2010 7:45 AM
the answer may be in here.
i will check
http://www.google.co.uk/search?q=explanation+of+technical+terms&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=OIKDTI71MtO6jAfV0cCOCA
getting there
http://en.wikipedia.org/w/index.php?title=Special%3ASearch&search=resolution+of+digital+display&button=
closer
http://en.wikipedia.org/w/index.php?title=Special%3ASearch&redirs=0&search=resolution+of+digital+volt+meter+digital+display&fulltext=Search&ns0=1
http://en.wikipedia.org/wiki/Multimeter
Bingo got there whooopee
Resolution
Digital
The resolution of a multimeter is often specified in "digits" of resolution. For example, the term 5½ digits refers to the number of digits displayed on the readout of a multimeter.
By convention, a half digit can display either a zero or a one, while a three-quarters digit can display a numeral higher than a one but not nine. Commonly, a three-quarters digit refers to a maximum value of 3 or 5. The fractional digit is always the most significant digit in the displayed value. A 5½ digit multimeter would have five full digits that display values from 0 to 9 and one half digit that could only display 0 or 1.[3] Such a meter could show positive or negative values from 0 to 199,999. A 3¾ digit meter can display a quantity from 0 to 3,999 or 5,999, depending on the manufacturer.
While a digital display can easily be extended in precision, the extra digits are of no value if not accompanied by care in the design and calibration of the analog portions of the multimeter. Meaningful high-resolution measurements require a good understanding of the instrument specifications, good control of the measurement conditions, and traceability of the calibration of the instrument.
Specifying "display counts" is another way to specify the resolution. Display counts give the largest number, or the largest number plus one (so the count number looks nicer) the multimeter' display can show, ignoring a decimal separator. For example, a 5½ digit multimeter can also be specified as a 199999 display count or 200000 display count multimeter. Often the display count is just called the count in multimeter specifications.
Analog
Resolution of analog multimeters is limited by the width of the scale pointer, vibration of the pointer, the accuracy of printing of scales, zero calibration, number of ranges, and errors due to non-horizontal use of the mechanical display. Accuracy of readings obtained is also often compromised by miscounting division markings, errors in mental arithmetic, parallax observation errors, and less than perfect eyesight. Mirrored scales and larger meter movements are used to improve resolution; two and a half to three digits equivalent resolution is usual (and is usually sufficiently adequate for the limited precision actually necessary for most measurements).
Resistance measurements, in particular, are of low precision due to the typical resistance measurement circuit which compresses the scale heavily at the higher resistance values. Inexpensive analog meters may have only a single resistance scale, seriously restricting the range of precise measurements. Typically an analog meter will have a panel adjustment to set the zero-ohms calibration of the meter, to compensate for the varying voltage of the meter battery.
Accuracy
Digital multimeters generally take measurements with accuracy superior to their analog counterparts. Standard analog multimeters measure with typically three percent accuracy,[4] though instruments of higher accuracy are made. Standard portable digital multimeters are specified to have an accuracy of typically 0.5% on the DC voltage ranges. Mainstream bench-top multimeters are available with specified accuracy of better than ±0.01%. Laboratory grade instruments can have accuracies of a few parts per million.[5]
Accuracy figures need to be interpreted with care. The accuracy of an analog instrument usually refers to full-scale deflection; a measurement of 10V on the 100V scale of a 3% meter is subject to an error of 3V, 30% of the reading. Digital meters usually specify accuracy as a percentage of reading plus a percentage of full-scale value, sometimes expressed in counts rather than percentage terms.
A multimeter's quoted accuracy is specified as being that of the lower (mV) DC range, and is known as the "basic DC volts accuracy" figure. Higher DC voltage ranges, current, resistance, AC and other ranges will usually have a lower accuracy than the basic DC volts figure. AC measurements only meet specified accuracy within a specified range of frequencies.
Manufacturers can provide calibration services so that new meters may be purchased with a certificate of calibration indicating the meter has been adjusted to standards traceable to, for example, the American National Institute of Standards and Technology, or other national standards laboratory.
Test equipment drifts out of calibration over time, and the specified accuracy cannot be relied upon indefinitely. For more expensive equipment, manufacturers and third parties provide calibration services so that older equipment may be recalibrated and recertified. The cost of such services is disproportionate for inexpensive equipment; however extreme accuracy is not required for most routine testing. Multimeters used for critical measurements may be part of a metrology program to assure calibration.
Sensitivity and input impedance
Keithley Instruments Series 2100sm
When used for measuring voltage, the input impedance of the multimeter must be very high compared to the impedance of the circuit being measured; otherwise circuit operation may be changed, and the reading will also be inaccurate.
Meters with electronic amplifiers (all digital multimeters and some analog meters) have a fixed input impedance that is high enough not to disturb most circuits that are encountered. This is often either one or ten megohms; the standardisation of the input resistance allows the use of external high-resistance probes which form a voltage divider with the input resistance to extend voltage range up to tens of thousands of volts.
Most analog multimeters of the moving-pointer type are unbuffered, and draw current from the circuit under test to deflect the meter pointer. The impedance of the meter varies depending on the basic sensitivity of the meter movement and the range which is selected. For example, a meter with a typical 20,000 ohms/volt sensitivity will have an input resistance of two million ohms on the 100 volt range (100 V * 20,000 ohms/volt = 2,000,000 ohms). On every range, at full scale voltage of the range, the full current required to deflect the meter movement is taken from the circuit under test. Lower sensitivity meter movements are acceptable for testing in circuits where source impedances are low compared to the meter impedance, for example, power circuits; these meters are more rugged mechanically. Some measurements in signal circuits require higher sensitivity movements so as not to load the circuit under test with the meter impedance.[6]
Sometimes sensitivity is confused with resolution of a meter, which is defined as the lowest voltage, current or resistance change that can change the observed reading[citation needed].
For general-purpose digital multimeters, the lowest voltage range is typically several hundred millivolts AC or DC, but the lowest current range may be several hundred milliamperes, although instruments with greater current sensitivity are available. Measurement of low resistance requires lead resistance (measured by touching the test probes together) to be subtracted for best accuracy.
The upper end of multimeter measurement ranges varies considerably; measurements over perhaps 600 volts, 10 amperes, or 100 megohms may require a specialized test instrument
Taken from above what does this mean in simple terms please
09/06/2010 12:19 AM
But my problem is not solved. According to the above note for a 4.5 display most significant digit can show 0 or 1 and the other 4 digits are capable to show the value up to 9. So the resoluton should be 19,999 or 20,000. But in the manual it is given as 11,999 / 12000. This is confusing.........
09/05/2010 7:49 AM
Do you know that, what is the construction difference between the two plates of the DC Capacitor. Please read the question in the link carefully. I cannot find a solution from google.
http://cr4.globalspec.com/thread/59491#newcomments
Good Answers: 60
09/05/2010 8:48 AM
this just the start as i will be going out soon but will come back soon
I am assuming you mean electrolytic capaictor which can only be used one way ie it has a +ve and -ve
Please correct me if i am wrong about this Assumption
I typed "what is the construction difference between an electrolytic capaictor and a normal one" into Google and got this
http://www.google.co.uk/search?q=what+is+the+construction+difference+between+an+electrolytic+capaictor+and+a+normal+one&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=1pCDTMD9AYOQjAeMqLSQCA
DC Capacitor
http://www.google.co.uk/search?q=DC+Capacitor&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GZEU_en&redir_esc=&ei=OJKDTMuWCNfPjAfk7v2OCA
09/05/2010 9:09 AM
I meant that in DC capacitor each plates are specified as -ve and +ve. There should be some difference for material that is used for each plate construction. Otherwise (If both plates are of same material) no need to specify -ve and +ve plates, we can connect it anyway. For AC capacitor this construction difference will not takes place, because current is altering in both direction.
I need to know what is the difference (difference in material used to construct) between both plates of a DC Capacitor.
I think you got my point........
09/06/2010 12:38 AM
1. I read a little more in the manual. It is clearly a translation from some other language into English, and it is fairly well done, but English is definitely NOT the first language of the person doing the translating.
2. In DC Electrolytic capacitors, one electrode is aluminum foil, while the other electrode is the container together with the liquid filling the capacitor. The dielectric is a thin oxide coating on the aluminum. Capacitors with a higher voltage rating require a thicker oxide layer, which increases the separation between the electrodes, decreasing the capacity for a given physical size. If these capacitors are connected with the voltage reversed, they will be destroyed very quickly, sometimes with a loud explosion. I accidentally destroyed one that way just yesterday, but I happened to have a finger on the capacitor, and felt the heat, so shut off the power before it exploded (but not before the cap was destroyed).
09/06/2010 12:46 AM
Which electrode have aluminium coating -ve or +ve. I need know why it is getting exploded when polarity is reversed. I am expecting the correct scientific reason.
09/06/2010 1:07 AM
The foil must have the coating, because it has a large surface area The container has a relatively small surface. Capacity is directly related to surface area, and inversely related to dielectric thickness. That is why they try to get the coating as thin as possible. The thinner the coating, the greater the capacitance for a given surface area, but the greater the danger of failure.
Any current flowing in the correct direction will tend to oxidize any microscopic areas of exposed aluminum, decreasing the capacity very slightly, but causing no harm, as long as the voltage is low enough for the dielectric.
Any current flowing in the opposite direction will tend to reduce (remove oxide from) such microscopic flaws, enlarging them, thereby increasing the current, which increases the rate of oxide removal, etc. to destruction.
09/06/2010 1:22 AM
Whether both electrode having oxide coating? Otherwise please specify which electrode have aluminium coating (+ve or -ve).
Good Answers: 60
09/06/2010 4:21 AM
Why cant you just accept that the electrolytic capacitor is polarity conscious and normal capacitors are not ?
as for the meter if it works and you know how to use it, accept it.
the extra knowledge wont affect your ability to earn money will it ?
so why bother trying to work out the small things.
You will be asking next what is Gravity?
what is Magnetism
what is the purpose of life.
09/06/2010 4:45 AM
For everything that is happening around us, there will be a reason. We should be anxious about these reasons.
When we study about one thing thousands of questions that starting with ''Why'' will arise in our mind. By finding all the answers of that questions we are getting deep knowledge in that subject. Otherwise, study will not be worth. I don't like to byheart data as it is given.
We may have huge knowledge, but sometimes we are missing some simple ''Why'' like this.
I am searching the answers for that questions that arising in my mind.
That is why i am asking which electrode have oxide coating.
Good Answers: 60
09/06/2010 8:25 AM
Fair enough the answer by the way "which electrode has coating" is contained in one of the replies i posted, Have you not read them?
Because if your not reading them i am wasiting my time researching them
below taken from
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Construction
Aluminum electrolytic capacitors are constructed from two conducting aluminum foils, one of which is coated with an insulating oxide layer, and a paper spacer soaked in electrolyte. The foil insulated by the oxide layer is the anode while the liquid electrolyte and the second foil acts as the cathode. This stack is then rolled up, fitted with pin connectors and placed in a cylindrical aluminum casing. The two most popular geometries are axial leads coming from the center of each circular face of the cylinder, or two radial leads or lugs on one of the circular faces. Both of these are shown in the picture.
Polarity
In aluminum electrolytic capacitors, the layer of insulating aluminum oxide on the surface of the aluminum plate acts as the dielectric, and it is the thinness of this layer that allows for a relatively high capacitance in a small volume. The aluminum oxide layer can withstand an electric field strength of the order of 109 volts per meter. The combination of high capacitance and high voltage result in high energy density.
Most electrolytic capacitors are polarized and require one of the electrodes to be positive relative to the other; they may catastrophically fail if voltage is reversed. This is because a reverse-bias voltage above 1 to 1.5 V[1][2][3] will destroy the center layer of dielectric material via electrochemical reduction (see redox reactions). Following the loss of the dielectric material, the capacitor will short circuit, and with sufficient short circuit current, the electrolyte will rapidly heat up and either leak or cause the capacitor to burst. This is because, if the aluminium foil with a layer of aluminium oxide on it is made negative the oxide ion will get reduced and will convert into oxygen gas generating a high pressure and hence may burst open the capacitor.[citation needed] This is same as the electrochemical principle in an electrolyte with 2 electrodes.
To minimize the likelihood of a polarized electrolytic being incorrectly inserted into a circuit, polarity is very clearly indicated on the case. Also, the negative terminal lead of a radial electrolytic is shorter than the positive lead and may be otherwise distinguishable. On a printed circuit board it is customary to indicate the correct orientation by using a square through-hole pad for the positive lead and a round pad for the negative.
Special capacitors designed for AC operation are available, usually referred to as "non-polarized" or "NP" types. In these, full-thickness oxide layers are formed on both the aluminum foil strips prior to assembly. On the alternate halves of the AC cycles, one or the other of the foil strips acts as a blocking diode, preventing reverse current from damaging the electrolyte of the other one. Essentially, a 10 microfarad AC capacitor behaves like two 20 microfarad DC capacitors in inverse series.
Modern capacitors have a safety valve, typically either a scored section of the can, or a specially designed end seal to vent the hot gas/liquid, but ruptures can still be dramatic. An electrolytic can withstand a reverse bias for a short period, but will conduct significant current and not act as a very good capacitor. Most will survive with no reverse DC bias or with only AC voltage, but circuits should be designed so that there is not a constant reverse bias for any significant amount of time.
the other links i posted that you havent botherd to look at.
  • Electrolytic capacitor - Wikipedia, the free encyclopedia - 04:26 1 History; 2 Construction; 3 Polarity; 4 Electrolyte .... Most electrolytic capacitors are polarized and require one of the electrodes to be positive .... of electric charge stored per unit of potential difference between the plates. ...
  • Capacitor - Wikipedia, the free encyclopedia When there is a potential difference (voltage) across the conductors a static electric ... charge on each conductor to the potential difference between them. ... A more compact construction began to be used of a flexible dielectric sheet ..... Electrolytic capacitors offer very high capacitance but suffer from poor ...
    en.wikipedia.org/wiki/Capacitor
  • Electrolytic capacitors That is, it is a good insulator only in one direction, and in the other it conducts electricity. ... Normally carried out at the rated top temperature to the capacitor, ... Figure 2: Construction of a wound aluminium electrolytic capacitor .... differences between tantalum and aluminium electrolytic capacitors. ...
    www.ami.ac.uk/courses/topics/0136_ec/index.html
  • Capacitor types and their uses: Radio-Electronics.Com Electronic capacitors are one of the most widely used electronic components. ... The differences between the different types of capacitor can mean that the circuit ... In essence the construction of an electronic capacitor is very simple, ... In some capacitors the plates may be flat, and normally these capacitors ...
    www.radio-electronics.com ›
  • FaradNet Book "Electrolytic Capacitors" Chapter 1 3 Apr 2000 ... Construction of Matter: Molecules: Atoms: Electrons: Electrical Capacitors ... The difference between solids, liquids and gases is in the degree of ... impelled in one direction, out of its normal position in its cell, ...
    www.faradnet.com/deeley/chapt_01.htm
  • Electrochemistry Encyclopedia -- Electrolytic capacitors A relationship between the charge flow through the system and the amount of product (in this ... Construction details of a wet aluminum electrolytic capacitor ..... These capacitors usually have a series resistance near one milliohm, ... In a normal discharge capacitor application, the capacitor is charged slowly, ...
    electrochem.cwru.edu/encycl/art-c04-electr-cap.htm
  • Electrolytic capacitor: Definition from Answers.com The voltage applied to them must be polarized; one specified terminal must always have positive ... 1 History; 2 Construction; 3 Polarity; 4 Electrolyte ..... What is the difference between electrolytic capacitors and normal capacitors? ...
    www.answers.com/topic/electrolytic-capacitor-1
  • Capacitors Electrolytic capacitors are polarised and they must be connected the ... Note that there are no gaps between the colour bands, so 2 identical bands actually appear as a wide band. ... Their value (in pF) is normally printed without units. ... 1030 and so on because for these values 10 is a very small difference, ...
    www.kpsec.freeuk.com/components/capac.htm
  • Reforming Electrolytic Capacitors One of the early attemped applications of the electroltyic capacitor was in conjunction ... The essential difference between the electrolytic and nonelectroltyic .... It is essential, however, to select for its construction a material ...
    www.vcomp.co.uk/tech_tips/reform_caps/reform_caps.htm
  • [PDF] Aluminum Electrolytic Capacitors - General Technical Information File Format: PDF/Adobe Acrobat
    The difference between forming voltage and operating voltage, the so-called ... An Al electrolytic capacitor constructed in the way described above will only operate correctly if ..... rating of the Al electrolytic capacitor under normal operating .... If a capacitor in one of the series branches fails and causes a ...
    www.epcos.com/.../Capacitors/AluminumElectrolytic/.../PDF__GeneralTechnicalInformation,property=Data__en.pdf;/... this will be my last posting on this matter and any other matters you ask about as you dont read the information i post.
09/06/2010 8:50 AM
Thank you very much..
If you don't mind please give answer for the question containing in the following link.
http://cr4.globalspec.com/thread/59488#newcomments
It is better to reply via the correct forum.
Good Answers: 60
09/06/2010 10:24 AM
No sorry i will not answer, as your not reading my answers and links, if you cant be bothered neither can i
Good bye
09/07/2010 12:08 AM
Dear Peter,
Please understand that now in this forum there is about 35 comments now. I feel regret that I canot find that post from the all. That is why I asked you please reply via the correct forum. Be friendly.....
Accidentaly I found this website and I understood that this is the place to ask my all boubts also it is very interesting. Look in my all forums some persons teased me regarding the standard of my questions. But they couldn't provoke me. Many of them who is working in electrical area do not know some basic facts like this.
I tried in google by typing ''difference between negative and positive plate'', but I didn't get the answer. But you simply found the answer (also in case of display specification). That is the rhythm of searching......
Anyway let me continue to discuss with you, because you have good knowledge and have good helping mentality also. You are ''Guru'' and just understand that I am a 23 years old guy and now started my career............
09/06/2010 9:35 AM
Electrolitic Capacitors: Bothe electrodes are Aluminium BUT the dielectric is Produced using an electrolite and a DC voltage to deposit Aluminium Oxide on one of the faces. Aluminium Oxide is a very good Isolator (dielectric). Thus the capacitor is formed and because of the chemical and polarisation used to form the dielectric, YOU MUST KEEP THE POLARITY when in use. IF THE POLARITY is reversed, you reverse the reaction and the deielectric is depleted from one side to transfer to the other side... Not very good since there will be a moment where the deielectric has gone before reforming again... and the voltage being used is too high for the process... you will have a spark across and destroy the capacitor!
Good Answers: 60
09/05/2010 8:03 AM
Taken from the last but one answer of mine.
does the below mean the amount of counts taken to disply the digits on a 5½ digit ?
09/05/2010 8:57 AM
Thank you so much for your helping. But there is also one more type display, for that the most significant digit is represented by 6/7. What about this?
eg: Gossen Metrawatt Metrahit World (3 6/7 Display)
You can find it in the 3rd page of the brochure that is given below.
http://www.gossenmetrawatt.com/resources/tt/metrahit_world/db_gb.pdf
Good Answers: 60
09/05/2010 10:02 AM
Is the below correct ? taken from page 3 ?
Taken from
Display / char. height 7-segment characters / 15 mm
Number of places 36/7-place , 6000 steps ( what does this mean ?)
Measuring rate 3 measurements per second
further info on meter
https://www.distrelec.hu/ishop/Datasheets/whMETRAHIT2_manual_en.pdf
09/05/2010 10:18 AM
Right; but not 36/7, it is 3 6/7.
Re: Resolution of Electronic Display
09/08/2010 8:32 PM
Hi Justin,
The data-sheet you posted did NOT say the resolution was 12000 digits. I think it means that 12000 is the maximum reading you can get on it's 4 & 1/2 digit display. Some would call that 20% over-range.
-S
09/09/2010 12:32 AM
Anyway for or a 4.5 display most significant digit can show 0 or 1 and the other 4 digits are capable to show the value up to 9. So the maximum value should be 19,999 or 20,000. But in the manual it is given as 11,999 / 12000. This is confusing.........
Give me a solution for this.
09/09/2010 7:41 AM
Although the 4.5 digit display is capable of showing 19,999, the analog-to-digital converter inside the unit can only convert analog values up to 11,999, so higher values never appear.
09/09/2010 12:35 PM
Really good explanation...........
Thank you so much.....
What about 3 6/7 display? I didn't get answer for that question.
09/12/2010 12:38 AM
Glad I could help ... As to the 3 6/7, I have only the slightest idea: the manual says there are 6000 steps, meaning 0 through 5999. Thus the first digit can be anything from 0-5, so there are 6 possibilities. why it says 6/7 instead of 6/10 or .6, I have no idea!
For whatever it is worth, I have never seen this brand of DMM, but they appear to be of excellent quality, base on what I have seen in their manuals. A three year warranty is impressive!
Register to Reply 41 comments
dkwarner (5); justinanto1987 (17); LAA_Lucke (1); peterg7lyq (16); StandardsGuy (1); stevem (1)
