Previous in Forum: Insulation   Next in Forum: Addition of Three Line Powers
9 comments
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Cause of Rlectromagnetic Radiation From a Current Carrying Conductor
09/04/2010 3:30 AM
There is a loss of power from current carrying conductors in the form of electromagnetic waves also. For the production of a electromagnetic waves there should be a electric field & magnetic field (Also should be dynamic). They both supports each other for the propagation. I think magnetic field is created from current flow through the conductor. But from where electric field is created? According to my view every conductor has small impedence and these impedence can create potential difference and can provide a differential voltage drop along the conductor. Whether this differential voltage drop along the conductor causes electric field or not. If not please tell me the reason for electric field.
If you can't find a way, make one........
Good Answers: 181
Re: Cause of rlectromagnetic radiation from a current carrying conductor
09/04/2010 6:30 AM
Having read your other posts in the communications section I would suggest.
A/ do your own homework
B/ try Google
As for 3 6/7th looks on Google for "The Goons + Buebottle" (from communications section post).
Some of the older members may remember the Goons.
09/04/2010 6:38 AM
Dear Tony,
I tried in google already, but i didn't get the answer for my quetion.
Good Answers: 181
09/04/2010 8:04 AM
Have a look for
Ohm's Law (volt drop)
Fleming's rules (magnetic flux)
Electrostatic & Corona effects (potential around a conductor)
09/06/2010 8:47 AM
My question is simple, whether differential voltage drop along the conductor causes electric field or not.
Good Answers: 60
Re: Cause of Rlectromagnetic Radiation From a Current Carrying Conductor
09/06/2010 10:23 AM
Sorry cant be bothered to answer as you dont read my posts or links so i am out of here. Bye Bye
09/07/2010 12:11 AM
Dear Peter,
Please understand that now in that forum there is about 35 comments now. I feel regret that I canot find that post from the all. That is why I asked you please reply via the correct forum. Be friendly.....
Accidentaly I found this website and I understood that this is the place to ask my all boubts also it is very interesting. Look in my all forums some persons teased me regarding the standard of my questions. But they couldn't provoke me. Many of them who is working in electrical area do not know some basic facts like this.
I tried in google by typing ''difference between negative and positive plate'', but I didn't get the answer. But you simply found the answer (also in case of display specification). That is the rhythm of searching......
Anyway let me continue to discuss with you, because you have good knowledge and have good helping mentality also. You are ''Guru'' and just understand that I am a 23 years old guy and now started my career............
09/06/2010 11:31 AM
I think your understanding is essentially correct. The summation of all the infinitesimally small voltage drops gives the total electric field.
Following is a quote from the Wikipedia article on electric fields. (See also the article on magnetic fields).
  • According to equation (1) above, electric field is dependent on position. The electric field due to any single charge falls off as the square of the distance from that charge.
  • Electric fields follow the superposition principle. If more than one charge is present, the total electric field at any point is equal to the vector sum of the respective electric fields that each object would create in the absence of the others.
  • If this principle is extended to an infinite number of infinitesimally small elements of charge, the following formula results:
  • where
  • ρ is the charge density, or the amount of charge per unit volume.
Your questions here (at CR4) have all been quite good, despite the assertions of others. They are by no means "too fundamental" or beneath us in some way. On the contrary, your question (for example) on multimeter digit resolution showed that most respondents were, in fact, clueless. There is tremendous value, in my opinion, to going beyond the obvious and continuing to ask "why?" (The best scientist devote lives to this.) I can assure you that you do not need to go very far down the path of such questioning before getting into areas that few (to zero) scientists and scarcely any engineers really understand. Those with only a tenuous grasp on the fundamental physics involved are often the first to criticize questions as being "too simple".
I can make electric and electronic devices work, but know almost nothing about how these things work on a fundamental basis. As far as I can tell, it's all magic.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
09/07/2010 1:27 AM
Thank you so much MoronicBumble for your help.
09/08/2010 11:26 PM
That means if the current passing through a superconductor, there will not be EM propagation from the conductor. Is it right?
Register to Reply 9 comments
justinanto1987 (5); MoronicBumble (1); peterg7lyq (1); TonyS (2)
