Previous in Forum: Excess Air and CO   Next in Forum: What is Lightning?
9 comments
Quick Fix Adhesive How to Remove Strains
10/01/2010 1:56 AM
How I can remove strains of quick fix solution from my spectacle lance? I tried Thinner, CTC, spray used for freeing jam bolts even toilet cleaner without success.
Re: Quick Fix Adhesive How to Remove Strains
10/01/2010 8:23 AM
Spectacle lance? Do you mean spectacle lens, as in eyeglasses?
If the lens is glass, try acetone. If plastic, try isopropyl alcohol. In both cases only use a pure cotton cloth to wipe the surface and be sure to rinse off any dust or previous solvents first.
10/02/2010 1:16 AM
Did you mean Cyanoacrylate (Instant) Adhesives popularly known as quick fix instant adhesives?
Google gives you plenty of leads for removal of the cured adhesives.
As suggested by Usbport ensure the material of the lens, whether glass or acrylic, before trying any stain remover solvent.
Good Answers: 109
10/02/2010 5:08 AM
Best and easiest is warm (70...90°C) water with a little dish-cleaner or soap added.
This may take an hour or so to get into small gaps.
We use this routinely in precision mounting/demounting parts to be turned with excellent roundness. NO clamping forces will not introduce elastic or plastic deformations.
RHABE
10/02/2010 9:45 AM
If the surface to be cleaned is glass or metal a product called GooGone works well. Quite amazing I think it uses citrus oil with some other solvents. If it is Cyanoacrylate soak in warm water and detergent it will usually come off. I have used both systems with good success.
10/03/2010 12:06 AM
Take it to the optician, they have the requisite grinding - polishing machine. Take a quote for new lens that might be cheaper than rectification.
Knowledge sharing is a WIN-WIN situation
Good Answers: 42
10/03/2010 9:55 AM
Try liquid phenol with or without formic acid. You can get the same from chemical laboratories of institutes. Beware about handling phenol without contact. use brush.
Another simple option could be trying the use of salicylic acid based skin ointments, soak it for 30to 60 minutes, rinse and check.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 42
10/04/2010 5:31 AM
Hydrogen Peroxide acidified with Formic or Acetic acid again is a good solvent for hardened resins.
10/03/2010 3:46 PM
Have you tried nail polish remover?
Cheers
Joe
10/07/2010 4:49 AM
Thanks to all of you for the response, I am tring now one by one. sure one of it will give me the result, I will aslo let you no what worked.
Register to Reply 9 comments
Joe Sparky (1); krishnan.ng (1); mountk2 (1); RHABE (1); roy hammy (1); s.udhayamarthandan (2); Sanjayvt (1); Usbport (1)
You might be interested in: Drain Cleaning Machines, Pipe Flanges, Rotary Dampers
