Previous in Forum: Machine Speed   Next in Forum: Neutral Connection
8 comments
Relation Between Number of Poles and Speed
11/01/2010 3:43 AM
Dear sir
I would like exactly to know why the synchronous speed decrease when number of Poles
increase
Good Answers: 181
Re: relation between number of poles and speed
11/01/2010 4:52 AM
Have you looked in CR4 search or Google?
If you had you wouldn't be asking the question.
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
11/01/2010 5:22 AM
N = 120f /p whwre N= Speed in RPM, f =Frequency and p = numbe rof pole
Good Answers: 130
11/01/2010 5:38 AM
Well I not sure you could add more Poles, or if you did, why it wouldn't still rotate 365¼ times per orbit.
11/01/2010 6:07 AM
A reduction in the number of Poles would speed up the economics of Europe.
Good Answers: 130
11/01/2010 7:03 AM
Or a reduction in those permitted to use them?
Re: Relation Between Number of Poles and Speed
11/02/2010 1:42 AM
In fact i'm appreciate your answers but i need the physical meaning of the relation
between the no. of poles and speed
Good Answers: 130
11/02/2010 2:33 AM
Ok if you mean poles in an AC electric motor - the motor poles will be 'synchronous' with the generator pole passes.
Or run "pole for pole" with a 2 pole* generators' shaft speed (*as generators are conceptually simplified as).
If you have 60 Hz then a 2 pole motor will synchronise at 3600 rpm. 50Hz = 3000 rpm.
So if you have 4 poles in the motor - the "pole for pole" takes 2 generator revolutions to provide 4 "pulses", so the motor will run at half generator rpm (1800) (1500).
8 poles = 1/4 - and so on.
In reality, unless the motor is specially designed to be 'synchronous' - there is slip and slip due to load.
So typical rated rpm will be 2800 or 1450 for 50 Hz and whatever
And that's what that math in post #2? was telling you.
Whereas "Pole", being a proper noun, is another topic.
11/02/2010 2:15 PM
The n poles of a motor are arrayed around a circle, each pole equivalent to 360/n degrees. For each full wave of AC, two poles pass by any point on the circumference (one for the + part of the wave, one for the - part). The rest is just arithmetic: rpm = (120 x Hz)/npoles.
Register to Reply 8 comments
34point5 (3); Anonymous Poster (1); eng.hmk (1); nascon (1); TonyS (1); Tornado (1)
