Previous in Forum: Air Cooled Heat Exchanger Design   Next in Forum: NPT Tap Calculation
Fan Speed
11/19/2010 10:16 PM
how to find the fan speed when air flows through a duct at 100CFM. axial fan. 10 degree blade inclination.
Good Answers: 97
Re: fan speed
11/19/2010 11:18 PM
Dimensions? ? ? ? ? ?
Re: fan speed
11/20/2010 1:57 AM
fan with 4 leaf. leaf inclined at 15 degrees to the plane perpendicular to the shaft axis. at tip the length is 2 inch and as it converges to the centre it becomes 0.75 inch. the shaft dia is 1 inch.
Good Answers: 137
Re: Fan Speed
11/20/2010 10:35 AM
Presumably it's direct-coupled. Look at the motor nameplate.
Re: Fan Speed
11/22/2010 11:14 AM
......and if it isn't, multiply the motor speed by the gearing or belt ratio to obtain the fan speed.
Re: Fan Speed
11/22/2010 9:42 PM
the fan is free to rotate. it gets its power from the air hitting its blades. No motor or gear is preset.
Anonymous Poster (2); Codemaster (1); Hendrik (1); PWSlack (1)
