Previous in Forum: Efficiency of PM DC Motor Used as Generator   Next in Forum: MV Distribution Board
16 comments
Good Answers: 32
Using a 12V Battery Charger in Reverse as a DC to AC Converter
11/30/2010 4:41 PM
I have an Exide 1000 forklift battery charger. I was wondering as to the practicality of using it in either with a solar or wind powered generating system to rectify a 12volt DC input to a 120 or 220 single phase output by basically reversing the input/output to the diodes or the actual diodes or some other method.
I seem to recall that most charging units use a set of blocking diodes to rectify the AC current to DC. Anyone have a suggestion on how to do it or a reason why it would not be practical or even possible?
Spinco
Re: Using a 12V battery charger in reverse as a DC to AC converter
11/30/2010 5:05 PM
Trying to use a battery charger in reverse as an inverter, is like trying to bring someone back to life by removing the knife from their heart. Doesn't work that way.
The bridge diodes take the AC to a varying DC, with caps to smooth it out. An inverter has to take the DC and reproduce an AC waveform. Entirely different circuit.
11/30/2010 5:10 PM
Nope. It is a completely different circuit topology converting DC to AC (inverter) than to go from AC to DC(battery charger, power supply).
In a power supply the non-linear nature of a diode is used to dramatically change the frequency spectrum of a nearly pure single frequency signal into a collection of frequencies that have a dominant DC component. A low pass filter network (capacitor) then reduces significantly the non-DC components. Running a DC signal through a diode does not generate an AC signal.
Now I'm not saying that a clever engineer couldn't use the parts of your forklift power supply to make a low voltage high current oscillator that then stepped up though the existing transformer to 120VAC. But just reversing your diodes is not going to do it.
Re: Using a 12V Battery Charger in Reverse as a DC to AC Converter
11/30/2010 6:39 PM
Just buy an inverter. They're as cheap as chips.
11/30/2010 9:50 PM
True, this way the batteries in the forklift can still get charged.
Such an enormous machine just to lift a fork.
12/01/2010 10:03 AM
People had been working for ceturies to:
12/01/2010 10:07 AM
Oh No!
You should know better than to even hint at perpetual motion.
Some cool drawings though.
12/02/2010 1:38 AM
I love the top drawing, especially. With just a few more pieces, it should work perfectly.
Si hoc signum legere potes, operis boni in rebus Latinis alacribus et fructuosis potiri potes!
Good Answers: 12
12/01/2010 12:53 AM
Not possible. It is just AC to DC converter. You need DC to AC inverter do achieve this. The modern small power home inverter using a new technology called "Bi-directional line interactive SBS" using this technology of using same transformer for conversion and inversion. Much information available on web.
Subramanyam
12/01/2010 5:17 AM
I suspect that you understand that it doesn't quite work that way now!
Tell us exactly WHY you want to do and CR4 will help out with How?.....
Good Answers: 32
12/01/2010 10:15 AM
Because it was there (left over when I had to close a business) and because I had some thoughts on building a small wind generator.
Everyone has pretty much confirmed what I felt was the case all along but I figured if there was a way someone on CR4 would know it and pass it along.
Don't know till you ask!!! Time to put it on eBay.
Thanks for the responses.
Spinco
12/02/2010 9:54 AM
"Time to put it on eBay."
And that's how you turn a battery charger into an inverter!
12/02/2010 10:11 AM
LOL!!!
And truly correct too!!
Good Answers: 32
12/02/2010 10:23 AM
No, that's how you get it out of your garage and make a few bucks on it.
Spinco
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
12/01/2010 12:31 PM
but you can use an UPS to convert DC to AC, most UPS's go out becouse of battery failure anyway and that's what you take out and wire the DC to. Oh yes, disconect the buzzer
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
12/02/2010 10:34 AM
1.from 12volt DC you have to convert to 12 V AC by half bridge inverter with 2 power transistor or full bridge inverter 4 power transistor and additional flywheel diode will be advantage for switching.see simple typical connection on power electronic book or web
2.you have to make simple circuit to trigger the base of each transistor/switching. and adjust the frequensi to 50hz by R-C (with potentio to adjust resistance to get correct time:20 ms)
3.after that you need a filter capacitor to make a good sine wave.12 volt Ac
4. increase the voltage 12 volt ac to 220 vac by step up transformer
i was done same way and succesful in the laboratory during power electronic class
12/04/2010 9:30 PM
Use inverter insted of battery charger. This will solve your problem.
Register to Reply 16 comments
active (1); Almansoura (1); Andy Germany (2); Haajee (1); Kilowatt0 (2); kvsubramanyam (1); kwcharlie (1); MoronicBumble (1); PWSlack (1); redfred (3); Spinco (2)
