Previous in Forum: Recycled Oil Wastage Usage   Next in Forum: Should We Be Led by Discontentment Forever?
38 comments
Energy Storage; Is a Fuel Cell a Battery?
12/01/2010 9:56 AM
In an electric vehicle
It seems like onboard storage of some type is a necessity. If a fuel cell is more responsive (able to meet high demand/short duration loads) than an electrolytic metal battery, and packs a higher energy to weight ratio, does it also qualify as a good energy receptor? Even hybrid generators can be much more efficient in a steady state generating mode than throttling to meet demand, so maximum energy efficiency seems dependent on steady state on board generation. Is this rational?
Re: Energy storage; Is a fuel cell a battery?
12/01/2010 10:08 AM
The key things in self-propelled vehicle design are:
  • Power-to-weight ratio, which determines performance, and
  • Energy-to-weight ratio, which determines range, and
  • Aerodynamic profile, which also determines range.
It doesn't matter if it's a fuel cell, a tank of dinojuice or porage oats that supplies the power, frankly.
Good Answers: 243
12/01/2010 10:30 PM
Excellent answer PW.
I think the Original question was really "can you run the fuel cell backwards? (energy receptor~ storage battery.)"
OR not. I could be wrong.
Your energy to weight answer covered it implicitly, I would state explicitly that the key with FUEL is energy density. That is why we will not see commercially viable Hydrogen cars in North America. Hydrogen contains about 1/24th of the miles per volume of Gasoline.
1/24th.
that means 24 tank trucks delivering fuel to your local "filling station" to give consumers the same number of miles as 1 tanker of gasoline.
Milo
Good Answers: 150
12/01/2010 11:06 PM
And if Milo's supposition is correct, that the question is if a fuel cell can run backwards, the answer is no.
Who is John Galt?
12/03/2010 3:17 PM
Is that 1/24th at STP or at say, 3000 lb?
12/03/2010 3:19 PM
Sorry, should have used psi instead of lb.
12/03/2010 3:23 PM
Maybe its per mole. Oops my mistake. I forgot. Only back of the envelope calculations permitted here to reduce wasting time .
Good Answers: 243
12/03/2010 4:08 PM
Actually guys, If you were doing a pointy headed academic peer review, you'd independently confirm my number. Why take my word for it?
However: "At 5,000 psi of pressure gaseous hydrogen only has a density of 0.25 pounds per gallon or one twenty fourth the density of gasoline. Gasoline and diesel are far superior fuels to hydrogen in this regard." Here is a publically findable link, look at last line of Myth 4:
http://www.dalefield.com/slspartners/hydrogen_fm.html
I chose to use this value for my quick approximation BOTEC as it is the pressure for the tanker trucks of Hydrogen that i see on the roads, and is a cognitive equivalent of a Gasoline tanker truck. (ie a truck of hydrogen is a cognitive equivalent of a truck of gasoline) However, perhaps if we were more precise in the brand of truck...
If you guys want to talk about the higher btus per pound of hydrogen, you will need to do a very good peer reviewable job of explaining how you are going to hold that pound in that one 500th of a pound of palladium...
Peace
Mil
Good Answers: 130
12/03/2010 5:11 PM
Hey here's an idea - why not bond 4 of the little rascals to something that also burns?
Hey, it might even liquefy at a fraction of the pressure and 'with luck' come in at around 2/3rds the density of gasoline?
Good Answers: 243
12/03/2010 5:17 PM
<giggles>
Milo
Good Answers: 150
12/03/2010 5:23 PM
Oh there you go making sense again! STOP THAT!
Who is John Galt?
Good Answers: 130
12/03/2010 5:44 PM
What! Stop interrupting - I'm busy trying to find my "secret ingredient" in this colorful table - HeHeHe - then I'm off to the Patent Office.... HHOHHOHHO! <that should put them off the scent>
Good Answers: 243
12/03/2010 9:32 PM
BAD DOG! milo
Good Answers: 130
12/03/2010 10:16 PM
Huh? you shouldn't yell at yourself. You'll finish up falling in.
Just got back; ran into this guy with a 'vortex' thingy, that separates good enthalpies from naughty ones. AND for just €10,000, to get it up and running, (and luckily I'll be soon getting 2.3 million from this nice Nigerian widow lady), I reckon we could use it to process my kryptontetrahydride®©patent pending
Re: Energy Storage; Is a Fuel Cell a Battery?
12/02/2010 7:46 AM
Thank you all, the answer is then no, a fuel cell is not a battery?
Your hydrogen storage reply is in direct proportion to to storage pressure, is it not? So you can store twice as much hydrogen in one cubic meter at 10,000 psi as at 5000 psi?
Finally, I am not talking about energy density alone, because on board generation can alleviate storage requirements. My question revolves around maximizing generation efficiency, or production density, if you will, along with energy storage density.
Good Answers: 243
12/02/2010 7:52 AM
on board generation? Sorry, won't be going with you on this trip. The energy needed for onboard generation would be much more efficiently used to drive the wheels directly without losses by transforming. You are dangerously close to perpetual motion with the snippets of your concept revealed here. Milo
Good Answers: 150
12/02/2010 8:03 AM
No onboard generation won't alleviate anything, because mass is mass is mass. The mass of water is greater than an equivalent volume of gasoline, and still only holds 1/24th the energy. And you still have the energy losses involved with electrolysis and compression and storage. And the only way to store a significant amount of hydrogen is cryogenically and the equipment to do that is not cheap, or light. Rockets get away with it because they can leave that equipment on the ground, and they are inherently less safe than a car going down a road.
And do you really want to be riding in a vehicle whose fuel tank is pressurized to 10Kpsi? or riding in a car next to one? or be a firefighter or rescue person who has to cut someone out of one, especially if it is on fire? This is the mistake so very many academics make when they expound on the coming hydrogen economy. they haven't thought about the details. They have succumbed to the lure of the idea without examining it with a critical eye.
Hydrogen will NOT be a significant vehicle fuel in our lifetimes. mark my words. I predict some pie in the sky politician will force a company to field one, and it will be involved in a crash and the results will be gruesomely spectacular and they will either be voluntarily taken off the market, or banned by the authorities.
Oh! The Humanity!
Who is John Galt?
12/02/2010 8:54 PM
Great graphics... I am still laughing.
rcf-jr - If there was anything hard in life, there would be a lot of people out of work.
12/02/2010 10:25 AM
Fuel is not a power storage device. It is chemical reaction chamber in which hydrogen and oxygen reacts giving electron and water as by product. This electron generated is transported to storage facility which is battery or capacitor or at use facility which is cell phone, computer or camera for example.
Masyood
12/02/2010 11:02 AM
The advantage I see from hydrogen fuel cells is the pristine waste products produced and that the energy released is electricity itself. If electricity is the energy form one is looking to get then not having to go through another energy transmutation can make this worthwhile. But as you mention later, a fuel cell is not capable of reversing the energy exchange. The concept of on board hydrogen generation from hydrocarbons does address the density storage problem of using gaseous or liquid hydrogen. However, one must now deal with the other carbon waste molecules generated by removing the hydrogen atoms from the hydrocarbon.
But I diverge from your point that I agree with. The primary advantage I see that electric vehicles can implement is the possibility of storing mechanical energy by dynamic braking instead of just throwing away the mechanical energy one has in the moving vehicle itself. So if one includes some super capacitors to store energy combined with a fuel cell to transmute chemical to electric energy to both top off the capacitors and to fight drag then there may one day be a more efficient electric vehicle than an ICE vehicle. Unfortunately the details on how one does this is far from being realized in a mass market design.
12/02/2010 11:41 AM
Palladium metal is good tank for storage of hydrogen safely. If super capacitor-and SOFC based fuel cell linked together then we get optimized MPG from any fuel we need and waste will be mainly water and carbon dioxide
Masyood
Good Answers: 243
12/02/2010 11:51 AM
" Palladium metal is a good tank for storage of Hydriogen safely."
At over $700 per troy ounce for PALLADIUM metal , even a teeny tiny tank better hold a whole crapload of hydrogen to be cost effective?
Milo
12/02/2010 1:06 PM
Used to be $230 per T.O. Think of this I would have made more than double of my money if I had this storage facility. joke!!
There are other metals and ceramics will also do but not as efficient as Palladium is but is good candidate
Masyood
Good Answers: 243
12/02/2010 1:10 PM
I hear you friend!
Yesterday almost always seems to have been the best tiime to buy.
How come we never recognize that today is yesterday for tomorrow?
Milo
12/02/2010 1:13 PM
The problem is not that today is tomorrows yesterday. The problem is should one buy or sell today.
Once again stating the obvious.
Good Answers: 150
12/02/2010 12:02 PM
Er, no it isn't.... it is HIGHLY permeable to Hydrogen because it catalyticlly breaks down H2 into atomic H which then passes through the membrane.
Who is John Galt?
12/02/2010 12:05 PM
I see that palladium is capable of absorbing a large amount of hydrogen. I saw at Wikipedia and other cites that it can absorb a quantity 500 times its volume with only a slight increase in its volume. I'm not sure what that phrase means though because nothing was mentioned about a pressure for the hydrogen. I also do not see how one releases the hydrogen. I did find that this is "on going research" because there is still debate over where the hydrogen goes. Some think a hydrate gets formed but that implies water, others that mild changes happen to the crystal lattice that traps the hydrogen without any chemical bonds happening.
Regardless, this certainly is promising research but it is not ready for mass production.
Good Answers: 150
12/02/2010 12:20 PM
My understanding of the process is that the hydrogen atoms settle into the interstitial spaces in the crystal lattice structure of the palladium. In order to release the hydrogen it has to be heated, and I'm not sure how fast or efficient the release of the hydrogen is. I suspect that a certain amount of hydrogen will remain in the lattice and not come out. I also suspect what is released is H, not H2, which is very difficult beast to contain.
Palladium membranes are used as filters to separate Tritium from He-3 (which is a decay product). Tritium will pass through and be absorbed, He won't.
Who is John Galt?
12/02/2010 12:51 PM
Yep, that is one of the proposed mechanisms I saw in scanning the web. I also saw a few that tested palladium coated on nanoparticles to maximize surface areas. That implied to the researcher and me a catalyst type of reaction happening instead. All of the links that I found agreed that the precise mechanism is not fully understood. I suspect that allowing elemental H to become H2 though is not a big problem. Hmm that would be an exothermic process though which would then presumably release more H.
I repeat, this is promising research. I have no idea when and if it will become viable.
Good Answers: 243
12/02/2010 12:29 PM
Hi redfred. That 500 times number gives us something to work with.
How about a very crude back of the envelope approximation of the costs using that number?
Let's Assume 1 oz of $700 palladium can hold 500 times its weight (I'm thinking Volume is even worse!) in Hydrogen. And that gasoline mpg is 40. (just for the sake of discussion.)
We know that hydrogen is 1/24th the mpg of Gasoline.
so 1 oz of Palladium times 500 =500 oz of hydrogen held; 500/24= 21 ounces of "gasoline equivalent"
21 oz/128 oz/gal=0.16gal ; 0.16 gal times 40 mpg=6.56 miles
So that one $700 piece of palldium will hold the equivalent mileage in Hydrogen of 6.5 miles of travel.
Assuming 40 miles per gallon benchmark for gasoline, we get to pay $700 for just the capacity to hold less than 10 miles worth of driving.
100 mile range = 100 miles / 6.56 miles per oz = 15.24 * $700 per ounce =$10670 Just to hold the hydrogen fuel.
Nothing about Balance of Plant-Pumps, compressors, valves and regulating equipment, tubing, fittings, just palladium at todays prices. No inflator for price increase based on mass market demand...
PASS.
BTW, I know I am playing fast and loose with "ounces" here, but for a crude approximation, it serves its purpose. And I used weight, I'm guessing that Volume would make an even sorrier prospectus. I'll leave that for someone else to do. Back to my Charting!
Milo
12/02/2010 1:07 PM
Wow have you gotten impatient here. Its doing precisely that style of quick sloppy math that both stimulates perpetual motion fantasies and stagnates valid research.
Good Answers: 243
12/02/2010 1:13 PM
I will not argue with you over that,. but in a world with limited resources, Quick sloppy math might help us make some early decisions about what is worth spending time or resources on.
I work for an industry that has not been able to solve the 24 : 1 ratio between wage rates here and in Asia.
Thanks for the thoughtful reply.
Milo
12/02/2010 2:17 PM
In a world of limited resources, research that might save some of those resources should not be stopped because of sloppy math. Similarly before any significant funding should be allocated reasonable math must be presented and scrutinized for peer review of errors to be rooted out. Inconsiderate weight assumed calculations of the lightest element and molecule possible seems like a bad place to start.
Good Answers: 243
12/02/2010 2:39 PM
On a forum where no one seems inclined to do any quantification at all, Back Of The Envelope Calculations are appropriate for sensemaking.
Peer review is wonderful and welcome, and my BOTEC's remain uncorrected by anyone with more time and attention to detail than this poor existentialist has to spare today. My quick calculation shows to be an fools errand unlikely to succeed in the near term approach, economically, project. Interesting technical problem, yes.
Without math we went from assumption 1:this will be excellent tank material to Conclusion 2 Oh crap, this absorbs 500 times its volume This is actually a sponge, not a container.
Makes my "Assumptions" and fast and "sloppy math" seem kinda cute.
I agree I played fast and loose with Weight vs volume. I only worked to one significant digit.
But semiquantitative beats wild ass unsubstantiated claims in my world, and I join you in waiting to see disciplined quantitative treatment- peer reviewed or not.
I'm ok with being the one eyed calculator on the forum of (apparent) non-quants.
Hopefully some peers will take my calculations and teach us all a thing or two.
Milo
Can't Wait for the academic heresy committee to find out I wrote this...
12/02/2010 1:03 PM
It is done based on thermal metering technology. This is still work in progress and I am not involved in this. I know from my days of making resistor inks of silver palladium and palladium ink for thick film hybrid high reliability mother board use and one time had need to fire in formic gas atmosphere and end up other end palladium full of hydrogen and that time on started preaching this and now is the technology going in hydrogen storage.
Masyood
12/13/2010 11:24 PM
Let's look at the pristine waste of hydrogen cars, i.e. water. Hot water. Imagine millions of cars sitting in traffic putting out water as steam or liquid. Now we have permanent rain in our cities, or at the very least permanently wet roads. In the north, we get millions of traffic accidents from black ice caused by hydrogen cars. But not for long. The dirty little secret is that the #1 greenhouse gas by far is water vapor. (They just shrug it off saying it isn't "resident" in the atmosphere, much like my tires don't matter because they aren't "resident" on the road.) So if humans are causing any global warming, the adoption of hydrogen cars will accelerate it. If nothing else, city dwellers can kiss the sun goodbye a la Blade Runner.
12/14/2010 8:33 AM
Although I do believe you are on the right track, ie noxious emissions versus energy expense/fear argument for improving transportation, this is like blaming the sport of baseball for your broken window.
That is a very obtuse argument with no basis in fact. On a comparative basis, if all of the cars on the globe were converted, the amount of water or steam they generate would be an almost unmeasurable percentage of the total standing water. As an additional observation, since we are debating the absurd, is that there would be no exhaust heat induced evaporation of existing water, so it may reduce water vapor concentrations. Any supporters?
12/04/2010 1:09 AM
have to say one of the answers that is a myth that is believed by most of the general public and scientific communities alike and shown here several times is the danger of on board production.
!) firstly Milo is correct energy to produce the hydrogen is equal to the energy produced at burn to drive the wheels the energy(batteries) would have driven anyway though there is a torque argument that is correct, the hydrogen will create more instant power and greater thrust but for a shorter length of time.
2) there is no need to pressurise on board production, you simply build the system with power to production required at the accelerator - increase electric input - increase H output, why would anyone even waste the space? no point.
hydrogen is best served as an inline production with the engine, no batteries required, and cut your fuel by about 50 percent. HHO is safe cheaper, than Icecream to have installed and is best because there is no tax or supplier control so the price can't go up for installs or fuel cells etc. there are basic systems already for sale that work to around 30 percent at the moment. Why wait having conversations about wishing - just do it and upgrade as better models become available.
Good Answers: 130
12/04/2010 1:19 AM
As night follows day - I knew it
Register to Reply 38 comments
34point5 (4); Anonymous Poster (1); Life is Enerventure (1); Masyood (4); Milo (10); PFR (2); PWSlack (1); rcf-jr (1); redfred (7); Rorschach (5); XNuke (2)
