Previous in Forum: DP Transmitter Range   Next in Forum: DP Transmitter Under Closed Vaccum Column
9 comments
Good Answers: 804
Level Sensing in Large Hot Wax Tank
12/06/2010 6:18 PM
Hello,
I'm looking for ideas and opinions on technology options for sensing level of a large tank of hot wax. The user has tried ultrasonic and found it lacking, mainly he says because the tank is large and when the level gets low, the transmitter is so far away from the heat of the wax that condensation forms inside and it dies. He wants me to find another solution, but I honestly think this is a near perfect ultrasonic application, I'm just looking for one that offers maybe a heater option for the transmitter itself to avoid any internal condensation forming.
Other ideas / comments?
Pathfinder Tags: level monitoring Tank ultrasonic
Re: Level Sensing in Large Hot Wax Tank
12/06/2010 6:46 PM
Suggestion: weigh the tank; mount it on 3 weigh-cells.
12/06/2010 7:34 PM
TDR Radar level transmitter.
12/06/2010 8:08 PM
Maybe some self-limiting type of heat tracing around the existing sensor, if the configuration permits.
Good Answers: 183
12/07/2010 6:41 AM
PWSLACK suggestion is THE best. You could use 3 or 4 load cells depending on structure. The only remark to be done is that this approach is good ONLY if wax specific weight is constant if your customer wants to know the level. If he used the level to determine the content then the solution offers the lowest uncertainty.
Good Answers: 19
12/08/2010 12:06 AM
A local wax manufacturer uses top mounted Guided Wave Radar for process tanks with jacketed steam heat.
12/08/2010 1:22 AM
I sometimes think that some people tent to choose overly complex solutions for simple issues.
Think guillotine - think catch to hold the blade up, think handle and rope to release catch, to allow the blade to drop, and another rope and pulley to lift the blade backup.
I am assuming that the wax tank is to store hot wax for making candles, or patterns or for some other one way process...
What is wrong with basic technology like a float?
There is also two issues:
1. The known amount of wax being extracted from the tank, and
2. The level at which the tank needs to be refilled...
The easiest way to monitor this is the have a periodic check - based upon the regular consumption or extraction of wax from the tank - like a daily plant check at the start of each shift...
One can use a simple window or windows into the tank to see the max and minimum levels of the contents (like a dip stick) which goes well with the daily inspections.
And one can also have a basic float switch to automatically activate the refilling of the tank by dropping in blocks of wax from a conveyor or chute...
Good Answers: 12
12/08/2010 3:41 AM
You can use one that is used in Glass Furnace. It is up/ down moving probe attached to 360' potentiometer, voltage value is recorded/ registered only when probe just touches wax (capacitance sensor). I worked on such level sensors and are very reliable.
Subramanyam
Good Answers: 58
12/08/2010 9:06 AM
If you are pleased with the performance of the ultrasonic system, I would find a way to either make it condensation proof or eliminate the root cause of the condensation problem(the condensate). If you switch to another measuring system (that may not work as well) you may find a similar failure mechanism.
12/08/2010 10:08 AM
KTEK makes a laser gage that would work great in this application. www.ktekcorp.com and look into the LM80 or SS140 if you need explosion proof environment.
Remember, no matter where you go, there you are.
Register to Reply 9 comments
Anonymous Poster (2); Bud (1); kvsubramanyam (1); LJGremillion (1); nick name (1); PWSlack (1); Tornado (1); welderman (1)
