We are trying to hydro a vessel that is 40 ft in dia. and the water level will be appx. 40ft. high. The problem is that we can not get the water from point A to point B. We have a water tank we are trying to suck water out of and by using a 3" water pump and transfer that water with the pump into the new tank. The problem is that the water transfer is very slow. In the last 12 hours the new tank only has 6 ft of water in it. We are transfering the water about 800 ft. from point A by 2 1/2" fire hose, the pump is located close to the input line on tank B. The pump should be able to transfer 200GPM, but at this time I don't think we moving 1/4 of that. Any suggestions. We are going to change pumps as soon as the stores open in our area.
