Previous in Forum: ARC Welder   Next in Forum: 50 cy Motor Run on 60 cy Power.
8 comments
Turbine
12/11/2010 7:21 AM
maximum energy of a turbine
Re: turbine
12/11/2010 8:57 AM
6,250,235 therbligs.
Re: turbine
12/11/2010 11:57 AM
....is a function of the properties of the fluid(s) passing through it.
Re: turbine
12/11/2010 3:32 PM
...not to mention the size of the turbine....
Re: Turbine
12/11/2010 7:22 PM
Why can't the webmaster for this site delete these posts ?
Re: Turbine
12/11/2010 7:43 PM
Good question, especially if you're the same "Guest" as the OP.
Good Answers: 181
Re: Turbine
12/12/2010 9:07 AM
The maximum energy is when the rotor breaks out of the turbine housing. You can't get a higher output than that!
Re: Turbine
12/13/2010 9:11 AM
Size of tubine (sq.m) X transformer size x cable diameter / # of outlets being used.
This will give an aprox. size.
Good Answers: 32
Re: Turbine
12/15/2010 10:36 AM
In a nutshell it:
equals (maximum energy input x turbine efficiency at maximum energy input) - (friction losses) - ( shaft driven output losses [i.e. oil pumps, governor systems etc.] ) - transmission losses at shaft output.
Based on the question it's the best I can do for an answer.
Spinco
Anonymous Poster (1); DGCYS (1); lyn (1); PWSlack (1); Spinco (1); TonyS (1); Tornado (2)
