Previous in Forum: Charging a Battery Using 240V Instead of 110V   Next in Forum: I’ve Got to Try This!
12 comments
Watt - Home Theatre
12/24/2010 11:08 PM
how you guys explain 6000watts home theatre working under 230V.I doubt the wire to the speaker should be damn thick,agree?
Re: watt
12/24/2010 11:14 PM
At 6,000 watts, your speaker wire can never be too damn thick!
Re: watt
12/24/2010 11:26 PM
i guess there will be an explanation for that.
Re: watt
12/24/2010 11:22 PM
Everything is relative. Cabling thicker than my arm or my **** (bad fred, bad fred ) will be a waste of money. Cabling thinner than spaghetti will be a waste of technology.
Re: watt
12/24/2010 11:38 PM
I doubt that 230 volts are going to the speakers. Whatever the voltage is, you could compute the amps, and then size the wires accordingly.
Re: watt
12/25/2010 12:02 AM
well how do you justify that much power.
Re: watt
12/25/2010 1:00 AM
Whom are you asking? I did not justify that amount of power. Some 10-watt Klipsch horns would probably do as well.
Good Answers: 97
Re: watt
12/24/2010 11:51 PM
The nuisance value to the neighbour is used in the formula to calculate the alleged output of these (monster) home theater systems..
(the reaction force is directly proportional to the square of the original force)
Fortunately there is a from Hendrik to Hendrik present under the tree containing state of the art ear plugs.
Merry Christmas
Good Answers: 181
Re: watt
12/25/2010 4:11 AM
We like to keep things in the family, so with in a week of each other my son and I were issued with Noise Abatement Orders in two separate counties.
Our neighbours don't like us for some reason.
Re: watt
12/25/2010 4:33 AM
CR4 Admin: Comment Moderated
Improper Language/Behavior: Part of this post was modified because it did not adhere to the behavioral policies of this site. Please review the CR4 site policies and FAQ.
Good Answers: 140
Re: Watt - Home Theatre
12/25/2010 3:16 PM
There are more types of wattage ratings in use today then there are manufacturers of gear, not quite but you get the picture...
Continuous power...
Peak Power...
Total Power...
I sure doubt it was 6000 watts RMS.
Here is a link for you to check out.
http://en.wikipedia.org/wiki/Power_handling
12/25/2010 7:46 PM
There is a term PMPO which is Peak Music Power Out Put, it is used by the manufacturers to bluff the customers.
While the 6000 W in your case is PMPO you do not have to worry about the cable size, the nominal sized cable provided by the manufacturer with the equipment will work satisfactorily.
Knowledge sharing is a WIN-WIN situation
12/25/2010 9:43 PM
RMS power still unsatisfactory about the subject
Reply Score 2 for Off Topic
Anonymous Poster (4); Hendrik (1); lyn (1); mountk2 (1); North of 60 (1); redfred (1); TonyS (1); Tornado (2)
