Previous in Forum: Used Tires Recycling   Next in Forum: Air Compressed Engine
81 comments
Good Answers: 204
Modifying a Forklift
12/26/2010 12:20 PM
Just a thought experiment. How can one increase the lift capacity of an hydraulic forklift without modifying the original design? (not that one should of course... and no I'm not planning to do this...)
but if you had to..., how would you do it? Is it impossible without completely redesigning the forklift hydraulics, etc. I think adding counterweight and stiffeners would be an obvious necessary step... so the question is how to multiply the forces?
for example, would altering the chain 'pulley' diameter at the top change the leverage ratio? (more power, but less speed) ??
Thanks,
Chris
Pathfinder Tags: forklift modification
Re: modifying a forklift.
12/26/2010 12:37 PM
The size of the pulleys will not matter on the amount of force produced, its the number of moving lines that make the force and length multiplications. Now the maximum load that the pulleys themselves can support does depend on the pulley axle size and pulley material.
Good Answers: 204
12/26/2010 1:12 PM
Okay thanks.. I was unsure about it.. but now I'm better. I know we have discussed block and tackle stuff before on cr4 years ago..
Good Answers: 204
12/26/2010 7:46 PM
To revisit the pulley size idea... if the pulley size increases or decreases, and all other things remain the same... then as the cylinder extends, the pulley rotates more or less based on the diameter of the pulley?? For each unit of distance travel in the cylinder, then the circumferential travel of the pulley is pi x d. (chain travel)
so if I want more power, then don't I get more power with a smaller circumference ??(less chain travel, but the same cylinder travel)
perhaps I'm still confused. it sometimes takes a lot to dislodge incorrect notions.
12/27/2010 12:20 AM
When two pulleys of different sizes are connected by chains (or belts) you have a difference of speed and torque, with the smaller, higher speed pulley having less torque.
In this case, both pulleys really act as one, although the two do help balance forces for non-centered loads.
If you look carefully at the chain, one side (the right side in your illustration) does not move.
At any given point, the highest non-moving link of the chain acts as a fulcrum. The pulley acts as a lever rotating about that fulcrum. Since the hydraulic cylinder pushes up on the center of the pulley, the pulley/lever has a mechanical advantage of 0.5, regardless of diameter. Ignoring friction and the weight of the chain, The cylinder must push up with a force twice the weight of the fork assembly plus load. The fork plus load move exactly twice as fast as the end of the cylinder. Twice the speed x half the force = the same power at input and output.
Good Answers: 204
12/27/2010 11:00 AM
I'm up now... morning coffee in hand... thinking about what you have said all night.
so I'm going to have to learn this one more in depth, as my "stubbornness" chip still won't let it go. I'll get back to you.
thank you
Chris
12/28/2010 5:10 AM
I'm up now too (woke up at midnight and couldn't sleep - its now 2AM, and I'm NOT a night person)
Perhaps this will help.:
I sure wish we could post PDFs...That's as big as I could get it.
A car's tires don't rotate around the axle unless they are slipping, they rotate about the continuously moving point of contact with the road. Similarly, the chain sprocket does not rotate about its axle, but rather about the point of contact of the non-moving part of the chain with the sprocket. The free-body diagrams at the top show the forces and lever arms, with the fulcrum at the right. (Very similar to 34.5's post 55)
I hope this helps.
Dick
Good Answers: 204
In reply to #63
12/28/2010 12:01 PM
that is so awesome I'm speechless!!!
thank you
obvious ga, and simply the best explanation for us slower moving night creatures..... lol
chris
Good Answers: 204
In reply to #63
12/29/2010 11:09 PM
Dear Mr Warner,
Thank you for the pdf. Let me heap more praise on your effort, as in the higher resolution image, it gets even better!! I am humbly thankful for your time and knowledge. It is superb.
Chris
In reply to #72
12/30/2010 12:39 AM
Thanks! I appreciate that!
Dick
12/27/2010 5:04 PM
No!
Good Answers: 130
12/27/2010 5:23 PM
You know this lifting one ... so you know twice as much rope is moved per unit of lift.
Flipped over, and the cylinder pushing up - instead of W 'lifting' - and twice as much 'chain' is 'moving' (lifting) per unit stroke of cylinder.
So the cylinder is lifting twice the mass of payload, carriage and tynes - and traveling half as far.
The diameter of the pulleys is about chain life.
(and the ones in the pic need some maintenance)
Good Answers: 204
12/30/2010 1:03 AM
this of course, was the correct answer... but I needed a bigger hammer to get through the dense matter...
Good Answers: 130
In reply to #74
12/30/2010 2:31 AM
They're both correct Chris, but rest assured I'm more than happy to have help beating stuff into you (and it was much clearer on the diameter question)
Good Answers: 204
In reply to #75
12/30/2010 3:15 AM
Good Answers: 42
12/27/2010 12:50 PM
About 40 years ago as a student I worked for a heavy moving company. They would design machines for specific jobs.
An example was an "acordian" flat bed truck that could be extended to about 100 ft. Another was a stearable bogey for particularily long lond loads (fairly common now).
One job was to remove and replace lathes at an old technical high school. The doorways where narrow and low. They bought a small lift truck that would just fit the width, then cut the mast down to clear the head room. Extended forks and about 500 lb of added counterbalance and they had a successful machine. Their mechanical engineer was brilliant.
As a joke one day the shop crew used a big 50 ton Hyster and picked up one of the truck drivers cars and put it on the roof of the shop. However, someone else not knowing this, delivered the Hyster to a job site later in the day. -----several days later the driver was able to retrieve his car!
The right sized machine makes the job easy!
Good Answers: 204
12/27/2010 1:27 PM
thank you for that!
chris
Re: Modifying a Forklift
12/26/2010 12:54 PM
My experiences with forklift's has been that the factory design will typically lift more than the counter balance of the machine itself can handle. That being a 2000 Lb rated fork lift will lift 3000 - 4000 lbs but it tends to lift its back end off the ground and tip over forward at some point as the load raises higher or gets further out on the forks.
Mechanically a forklifts design of the mast and hydraulic system has a peak working limit far beyond it rated limits so simply turning up the pump pressure will give you more lifting capacity. You just don't have the same overloading safety factors in the system as before.
Good Answers: 204
12/26/2010 1:19 PM
so if you had a system that could shift the counterweight dynamically (or preemptively) more to the rear, that the forklift could safely lift more? (or alternativelly, have some forward stabilizing legs put down?)
chris
12/26/2010 2:17 PM
At one place where I worked the common practice was to stack 8 - 10 50# bags of sackcreate on the tail and four of us 250# guys would hang off the sides and back. We could easily pick up 5000# with a 2000# rated forklift just as long as it was up close to the boom and never went over 6 inches high or was on soft ground!
Still I recommend using the correctly rated machines to do the jobs they where built to do. Gross overloading is just asking for problems that could result in injuries and possible deaths.
12/26/2010 3:24 PM
I'd run this by my insurance risk manager, first.
There are two reasons there are limits on this stuff in the first place.
1. It helps keep sane people from over-stressing the equipment.
2. Lawyers.
Good Answers: 204
12/26/2010 3:36 PM
okay... I agree.
perhaps this is too much of a homework question anyway...
cheers,
Chris
Good Answers: 150
12/26/2010 10:53 PM
you could always replace the counterbalance with one made of lead or DU....
Who is John Galt?
Good Answers: 204
12/27/2010 11:06 AM
that would put more weight in a smaller space.. which would be good for counterweight. but are they safe? I have no experience with DU. Is lead or DU paintable or would it have to have a plastic shell?
thanks,
Chris
12/27/2010 10:46 AM
Yes, I worked at TIEM, and we used a tilt table for stablitly testing. This involved giant weights that were calibrated by an outside company that had amazing giant forklifts that separated at the middle so that they could double the length of the forktruck once on site. This made it possible for them to lift amazing loads.
The biggest thing to consider is ramps and such. As stated earlier, almost all forktrucks can lift the counter weight off the ground. The trucks are rated for the load they can lift and still go down a standard ramp without tipping over. And if you experiment, wear a seatbelt. If it goes over, you should stay in the over head guard. Most fatalities happen when people try to jump off and the guard gets them. Its counter intuitive, so the seat belt keeps you from acting on your instincts.
Never use a superalitve when a diminutive would suffice
Good Answers: 204
12/27/2010 11:13 AM
sounds like you have good insights into the forklift design industry... tell us some more stories please.
and yes, my forklift training included videos of guys cut in half by the operator roll cage as they tried to jump off..
thanks,
Chris
12/27/2010 5:13 PM
Also, many forklifts come in several capicities on the same frame, so a lighter rated forklift may be able to be "upgraded" by changing a few parts, not the least of which would be the counter weight.
If a lift is at it's max, easiest way to increase the capacity would be a bigger lift cylinder or smaller pump. Either will increase the lift and reduce the speed proportionally.
At least in the USA, (Please don't get into the rude American thing, I simply don't know the specific laws and rules in other countries. I am not saying other countries don't have good safety programs) it is only legal to modify a lift truck if you can get approval of the changes from the original manufacturer. -- JHF
12/26/2010 2:13 PM
Go for it! I wanna see the "Caption This" submission.
Good Answers: 204
12/26/2010 2:34 PM
yaaaa... no... I have my forklift cert... and training on the 'triangle of forces', etc...
and I take safety pretty seriously on this issue...
I'm asking for other reasons... and not trying to create trouble for anyone.
I'm a firm believer in understanding all the forces and workings of mechanical systems before trying to 'improve' them for specific applications. I don't mind the stern warnings of what not to do...
but is there a safe and right way that one can modify these things for increased lift.. that is what I'm asking. (without rebuilding the hydraulics)
Chris
chris
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
12/26/2010 2:38 PM
OH yes, thanks for the LOL today, good but OT
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
12/26/2010 4:46 PM
One thing I didn't mention (because I thought someone else would) typically the hydraulic ram is moving the secure point of the pulley so that the end of the chain moves twice as far as the ram. This means that the ram must provide at least twice the force to lift the fork assembly and lift mass. So if you need to lift more mass less than half the height you could detach the chain from the fixed (non-lifting) junction and reattach the chain to the lifting junction along with the other end of the chain. Now as long as you do not have a problem with tipping over you will be able to lift with everything (but the fork platform) seeing and exerting no more than the anticipated load.
Good Answers: 204
12/26/2010 5:12 PM
I'm not picturing it... can you make me a quick sketch in paint, or provide a picture please?
thanks,
Chris
12/26/2010 6:06 PM
Forgive me I do not have your talent or tools for graphic design.
The pulleys have moved the same distance (blue versus white fill) but in the configuration on the right the lift has only moved half as far as the left.
Good Answers: 204
12/26/2010 7:48 PM
so you are essentially saying to eliminate the pulley action, and go with a straight push by the cylinder.
12/26/2010 8:55 PM
Yes, that is exactly what I'm saying. In the pulley systems I've seen on fork lifts the pulley increases the travel length so that a 3 foot ram can raise a lift 6 feet. In the initial picture you present I believe the ram end goes inside the box between the two pulleys.
Good Answers: 204
12/27/2010 11:07 AM
thank you. that is one option on my short list then.
cheers,
Chris
12/27/2010 5:19 PM
GA! I didn't think of that, but exactly right! Again, GA
Good Answers: 69
12/28/2010 2:25 PM
Yes, it's true, but if you do that in practice, the 1-side pull of the chain will put radial forces and stress on the shaft of the ram, wearing all seals in no time. You would need to mount a stiff rail and slide the fork platform on bearings thru it.
Oh, wait, I think a mastil is already part of the lifting mechanism, but anyway, you need to re-locate (center) the ram in order to reduce the side pull of the chain.
Yahlasit
Good Answers: 145
12/26/2010 5:07 PM
Forklifts hydraulics generally (certainly in later model units) have a safety release valve that will bleed off the pressure in the system once the safety margin of the lift is exceeded. You could "tinker" with that for the desired result.
Shifting the counterweight in response to the lifting weight would be one way of improving the carrying capacity however, the dynamics of the increase in length and subsequent increase in "swing room" would have to be thouroughly understood by the operator or else they'll start knocking the furniture about more than usual.
Naturally there are a number other factors to increasing the carrying capacity of a forklift including the tyres, wheels, bearings, axles, fixing points of the mast to the chassis etc.
I guess it all depends on how much you want to upgrade the carrying capacity to.
Good Answers: 204
12/26/2010 5:14 PM
when I suggested a dynamic counterweight system.. I would also include an interlock so that it only can lift such loads when not in 'transport mode.. but only in a fixed 'safe' lifting stance.
thanks,
Chris
Good Answers: 145
12/26/2010 5:42 PM
It's not enough for a forklift to lift a weight but it has to be able to move it as well. So the counterweight would need to be extended to counterbalance the load whilst underway. No biggy just appropriate training for the operator.
Good Answers: 204
12/26/2010 6:56 PM
well yes.. but the danger and instability increases with the height above ground of the load... so I'm thinking it would be pertinent to limit the travel while the load is up.. but perhaps you are right and that won't be the best plan.
thanks
Chris
Good Answers: 203
12/26/2010 10:53 PM
There are some forklifts designed with an adjustable (fore and aft) counterweight on them. They tend to be larger ones, probably rated at 8K lbs and above, and used by riggers who have to navigate through narrow aisle in plants to remove/install machines. They are sometimes used in conjunction with other rigging tools such as "roller skates", dollies, rollers, etc. to get the biggest capacity from an underrated or smaller foot print forklift.
When lifting near or exceeding the capacity of the fork lift always tilt the mast back as far as possible to put the center of gravity further back from the front drive wheels, which are the fulcrum.
There are many ways that a fork lift can be used in conjunction with other devices to move objects that weight considerably more than capacity of the fork lift. I would explore that path before I would overload a fork lift. A good rule of thumb is that if the load exceeds the hydraulic capacity (no lift when the up lever is pulled) or the whole unit tilts forward and lifts the rear end up then you have exceeded the practical capacity of the fork lift.
Have you ever seen a fork lift with one fork lower than the other? That's because the capacity was exceeded and the lower fork bent. Tough to pick up a pallet or most other loads when the forks are not even.
Also fork lifts tend to fail in less time when they are abused/overworked as compared with when their capacities are respected.
Good Luck, Old Salt
Good Answers: 204
12/27/2010 11:03 AM
thank you
do you have more info or links to the additional equipment used? (ie rollerskates)
cheers
chris
12/26/2010 11:46 PM
If I am understanding what you want to do is: Adapt the forklift to lift a much heavier weight than the rating of the FL up while being stationary? I get the picture in my mind of lifting a heavy transformer (or other equipment) from the floor straight up and attaching it to the steel rafters of the building. If so, you can not change the chains as you would lose the lifting height. This would possibly create a serious breach in the chains/pulleys/axles and depending on the age of the lift and wear and tear. Could be a serious accident waiting to happen. It would be best to rent a lift for the day to do this job function. Safety always has to be #1 for all involved in a job like lifting heavy objects more than 3" off the floor. Some things you can get away with, not lifting heavy objects without the right lift capacity. I still have all my fingers and toes. Heavy equipment operator for 35 years. 0 accidents! 0 lawsuits!
"Real Bass Players" do not use picks
Good Answers: 204
12/27/2010 11:02 AM
yes... safety.
but this is purely hypothetical, so I'm able to put my genie hand on the vehicle to hold it in place while it lifts, and that is sufficient.
I'm just wanting to figure out a mechanism given certain initial conditions.
cheers,
Chris
12/26/2010 8:17 PM
This pulley arrangement multiplies the fork travel x2 compared to the cylinder, in return for dividing the cylinder force ÷2; no change in power. A bigger pulley just rotates less; same stress on axle.
12/27/2010 1:16 AM
if the lifting of the fork was entirely by a hydraulic piston then theoretically adding a second piston (two side by side) could enable you to increase the lifting capacity as the weight of the load would be distributed over both pistons- but I am not sure how your forklift lifts the load- the picture shows a chain of sort- I am not sure how that is used... so I have no idea if my idea would work on your forklift...
Good Answers: 130
12/27/2010 1:22 AM
Now I'm really biting my tongue - FFS!
Good Answers: 204
12/27/2010 10:50 AM
Hi DJ,
I think you are right about twinning the cylinder. It would double the cylinder area, and the hydraulic pressure would be the same, so the volume of fluid would drop. All I can think of is ensuring that the fluid reservoir might have to be enlarged.
But again, this is all hypothetical, and I don't have a forklift. I've driven many kinds of them and have an operator cert.
cheers,
Chris
Good Answers: 181
12/27/2010 3:30 AM
12/27/2010 3:41 AM
What a dud! It didn't even go off!
12/27/2010 10:35 AM
"With no weight on the rear wheels, the forklift continued in a straight line, right over the edge."
Good Answers: 204
12/27/2010 11:18 AM
"bombing around on the forklift" takes on new meaning.
talk about "following the ordinance."
Chris
12/29/2010 2:31 PM
Good Answers: 145
In reply to #66
12/29/2010 2:51 PM
I see your forklift accident and raise it with a "Klaus forklift driver" video..
http://www.youtube.com/watch?v=p_h6oAj5p1g
Puts a new perspective on training videos...
Good Answers: 145
In reply to #67
12/29/2010 3:04 PM
Here is the full version
http://www.youtube.com/watch?v=0jmnFARPexw&feature=related
Don't watch it if your squeamish...
Germans, who'd of thought they'd have a sense of humour...
Good Answers: 204
In reply to #67
12/29/2010 3:24 PM
omg... while watching the first one, i came across this.
makes me think a 'dirty underwear' thread might have a few posts...
chris
Good Answers: 60
12/27/2010 6:35 AM
If you increase the lifting capacity, you would have to up rate all the other parts.
the strength of the mast, pivots, axles,wheels,brakes,counter balance,forks,
Just get a bigger truck thats designed for the max load required.
if after you modify a truck an accident should happed you would be in deep sh*t
with the authorities
Byt the way the main limiting factor is the hydrulics and the main lift ram,
followed by all the other components that support the ram,and fork carrige
http://www.google.co.uk/search?hl=en&rls=com.microsoft:en-US&rlz=1I7GPCK_enGB411&&sa=X&ei=eXgYTfKxJIjMhAfdoKS4Dg&ved=0CBkQvwUoAQ&q=design+and+theory+of+fork+lift+truck+lift+hydraulics&spell=1
Good Answers: 204
12/27/2010 10:58 AM
Thanks Peter,
you are right about the consequences of an accident. so a design that doesn't change the basic parameters is required.
you are also right about all the other factors that are part of the design, and would have to be considered. It is a complex operation that may well be equivalent to purchasing a new larger class vehicle.
but this is just a thought experiment, so we get to ignore certain factors, or take them for granted.
cheers,
Chris
Good Answers: 25
12/27/2010 9:19 AM
We would call Tubby to hang off the counterweight if we had a heavy bunk of lumber to move when the big lift was busy. He would stay on if we kept the forks tilted back and lowered on flat ground or frontward up a ramp. He had an infuriating habit of jumping off at the wrong time. This would let the load slip off the forks and the rear end come crashing down on the steering wheels.
Tubby didn't have a high school education, but he understood leverage just fine.
Goodness has nothing to do with it.
Good Answers: 204
12/27/2010 11:10 AM
omg...
sounds like he got an F in school, and is a C in forklift leverage...lol
Chris
12/27/2010 10:25 AM
Being a motorcycle nut, I'd have to add the olde saying about the weakest link in the chain...
Good Answers: 204
12/27/2010 11:15 AM
is the nut behind the wheel?
cheers,
Chris
12/27/2010 1:00 PM
It certainly would!
12/27/2010 3:57 PM
I like both the moving the counterweight back idea and the front supports idea. The "extra" counter weight could possibly be mounted on the side(s) of the FL with a mechanism that would move/push it to the rear as needed or even as part of the lift mechanism. The front "temporary" supports could be made with heavy duty castors mounted so they could do some movement and provide front support as well. This would need some thought so it would clear the front forks.
My thoughts so far without losing any sleep yet! (don't get your fur caught in the mechanisms! )
Good Answers: 130
12/27/2010 5:04 PM
12/27/2010 5:03 PM
No!
Good Answers: 114
12/27/2010 6:26 PM
This would limit the width of the load but take care of the tipping.
Use the top of the verticals as fulcrums for beams with ropes or links to the forks and moveable counterweights out on the back. Think Dutch bridges.
12/27/2010 9:29 PM
How can one increase the lift capacity of an hydraulic forklift without modifying the original design? All of your options are a change to the design! Think about your question!
Good Answers: 145
12/27/2010 9:34 PM
I rather think that Chris is "Bench Racing" and so is looking for relevant information to improve his knowledge on forklifts per se rather than actually doing something "silly".
Good Answers: 204
12/27/2010 11:03 PM
yes, actually a friend asked me... so I was curious what could be done.. but i think we are down to just a few options. I just wanted to be somewhat comprehensive in my thinking, and what better place to find out than cr4?
Good Answers: 130
In reply to #60
12/27/2010 11:34 PM
Well if you want to design one, move the front axles as near as possible to the load center of gravity.
This is always a compromise on wheel diameter against the floor/road characteristics, but the axles are the fulcrum, so every bit forward is a 'double effect' on 'tail weight' leverage.
Good Answers: 204
12/28/2010 3:15 AM
I like the one you showed earlier... with the 'outriggers' in front... I'm just wondering if those could be assistive scissor lifts somehow that can be brought to bear once the forks are in place.
thanks
Chris
12/27/2010 10:33 PM
Touché.
12/29/2010 9:43 PM
Or, you could always simply call in John Hutchison to "lighten" the load in the first place.
(just a bit of "off-center" humor )
Good Answers: 204
In reply to #70
12/29/2010 11:07 PM
Good Answers: 145
12/31/2010 3:42 PM
The "duct tape" method of modifying the specifications of your fork lift system:
Adding a counterweight to the forklift. Please note effective application of plastic buckets, recycled concrete and a huge eye bolt.
Supporting CG of load through use of auxiliary CG support device.
I don't know if I want to say "I don't deserve credit" or "please don't blame me", but the photographs were posted on a CR4 link by Bill Fay at http://www.frenchriverland.com/ a few months ago.
If you think the OSHA inspector would be unhappy with this you should have seen the pictures where the dogs were running the fork lift.
Bruce
In reply to #77
12/31/2010 3:59 PM
As goofy as that might look, I would guess that nothing was actually overloaded in that set-up. It could make a good class exercise to explain why or why not. (Can't do any calcs w/o knowing the weight of that ring gear assembly.)
Good Answers: 204
In reply to #77
12/31/2010 4:15 PM
excellent thank you!
03/08/2011 8:52 AM
The table weighed 8700 pounds. The truck is owned by me personally. The truck was not damaged in anyway and I got the job done. If your worried about my safety, please see:
http://frenchriverland.com/livermore_falls.dwt
Bill Fay
03/08/2011 8:55 AM
PS: Both the Lab and the English Bull Dog are DOSHA certified!!
Register to Reply 81 comments
129CBRider (1); 34point5 (5); Anonymous Poster (5); Baphom8 (1); beriberi (1); BruceFlorida (1); chrisg288 (30); DJElectfire (1); dkwarner (3); frenchriverland (2); GW (1); Insatiably_Curious (1); Jimh77 (1); kwcharlie (1); lyn (3); old salt (1); passingtongreen (1); peterg7lyq (1); philroth2252 (1); redfred (5); Rorschach (1); tcmtech (2); Tobugrynbak (5); Tom_Consulting (1); TonyS (1); Tornado (4); Yahlasit (1)
