Previous in Forum: Calibration of DP Transmitter   Next in Forum: How do I calculate Polaris TUC for my location
30 comments
Entity Parameters
01/03/2011 11:15 PM
Voltage,Current,Capacitance & Inductance are considered as Entity parameters.
I understand the effect Voltage & Current but can anyone explain me what effect it will have if Capacitance & Inductance of ( transmitter+ cable ) is higher than that of Barrier Capacitance & Inductance ?
Be happy :)
Re: Entity Parameters
01/03/2011 11:20 PM
"Entity parameters"? What have you been smokin'?
01/03/2011 11:32 PM
Tornado,
I am looking forward for soem technical assistance!!
Be happy :)
01/04/2011 8:34 AM
Then stop working on it and get some proper training.
01/04/2011 3:01 AM
I have never heard the term 'entity parameters' either.
It sound like someone is adding random words to make an already compelx subject even more baffling.
In future I shall call bread 'an entity foodsuff of the wheat based variety', I'm sure that will simplify my purchasing experience.
Drop the word 'entity' it is meaningless hogwash in my inflated opinion tautology.
Unless you can find a compelling distinction between entity and parameter in that context?
They are not even parameters of an entity, they are parameters which depend on external conditions.
01/04/2011 3:36 AM
Quite simply, the cable will store sufficient energy to make an incendive spark, which is exactly not what is wanted in an intrinsically safe circuit wandering into potentially explosive atmosphere. The circuit becomes intrinsically unsafe and the effect could be devastating...
http://en.wikipedia.org/wiki/Intrinsic_safety
01/04/2011 3:42 AM
I am still not clear abt it.
Capacitance / Inductance is higher on Transmitter+Cable side.
So when this is connected to Barrier with lower values ,What effect it will have on barrier?
Be happy :)
01/04/2011 6:19 AM
None on the barrier.
Everything on the spark that is generated when something happens in the hazardous area, because the cable is storing too much energy.
Do not attempt to install, test or modify electrical circuits in potentially explosive atmospheres without having received appropriate training! The entire facility might otherwise be at risk!!
01/04/2011 4:16 AM
My opologies, it appears 'entity parameters' is indded a clearly defined expression.
Although I still think it's liguistically obtuse and dubious.
Maybe some explanation of context would have been helpful and saved us having to google it?
01/04/2011 4:27 AM
You can refer to ISA Technical Report 12.2. This concept is nicely described in it.
Be happy :)
01/04/2011 4:28 AM
Be happy :)
01/04/2011 9:35 AM
I went here - seems to be some good basic information.
01/04/2011 5:06 AM
Can you please repeat that?
01/04/2011 6:20 AM
Pardon?
01/04/2011 6:29 AM
OK agreed that cable should nt store enough energy to generate spark.
specification says :
Cable Capacitace + Transmitter Inbuilt Capacitance ≤ Barrier Inbuilt Capacitance
Cable Inductance + Transmitter Inbuilt Inductance ≤ Barrier Inbuilt Inductance
My ques is : "What will Happen if this condition is not fulfilled ?"
Be happy :)
01/04/2011 8:33 AM
As above.
Either this:
or this:
Please make sure that all CR4 readers, including guests, are well out of the area before doing it.
Good Answers: 116
01/05/2011 9:06 AM
I do not believe specification writes what you think it does.
  1. The barrier has a maximum SAFE total capacitance/inductance for the external circuit on its "hazardous area" side. That is the sum of capacitance/inductance of cable, transmitters and anything else. The barrier's own capacitance/inductance "in-built" will usually be far less than its maximum safe values given on its approval certificate.
  2. A greater capacitance could cause a spark which can ignite a flammable atmosphere.
  3. A spark could then cause the events graphically pictured by other posts.
  4. "What will Happen if this condition is not fulfilled ?" - When the dust has settled and the government investigation is complete, YOU will be the one listed as a contributer to cause of the fire/explosion.
01/04/2011 6:34 AM
Then Your system is not suitable use in Zone 0/1
01/04/2011 8:36 AM
Or Zone 2 either!
01/04/2011 11:36 PM
OKK....So when I have to use
Either Cable with lower values of Capacitance & Inductance OR
Barrier with higher Capacitance & Inductance
And when I m using Barrier with higher Capacitance & Inductance , how does barrier ensures that evrything remains safe?
Be happy :)
01/05/2011 4:12 AM
The question is absurd.
Stop working on the project and get some proper training.
01/05/2011 5:58 AM
Sorry bit I dont agree that my doubt is baseless.
See I am gonna use trasmsitter with some inbuilt capacitance , inductance value.
I am gonna use cable with some defined values of capacitance , inductance value.
And certainly its going to store some energy in it !! Do you deny that ?
And as per ISA std. (TR 12.2) no std. permissible values of capacitance , inductance are given..
So the only way remained to check IS calc for my loop is by checking all these values wrt each other ..
Be happy :)
01/05/2011 10:20 AM
Codswallop.
Stop working on the project and get some proper training before there is a fire, explosion, equipment damage, injury or fatalities.
Good Answers: 116
01/05/2011 3:43 PM
A barrier data sheet does not list what you call an "inbuilt capacitance value" and "inbuilt inductance value". It lists the maximum SAFE capacitance and inductance values of the circuit external to the barrier on its hazardous side. If the sum of cable and transmitter capacitance exceeds the value on the IS certificate for the barrier then the circuit is no longer safe. Similarly for inductance.
There are no universal safe values because they depend on the actual voltage and current a specific barrier allows. Please read Post #21!!!
01/05/2011 10:31 PM
Understood...Clearly...
I misunderstood the barrier concept..after reading ur post..i read some catalogs..now its pretty clear ..thanks
Be happy :)
01/06/2011 3:09 AM
.....and the training?
01/06/2011 3:17 AM
wil surely take up sometime...
presently we hav already placed order for transmitters, cables n barriers so just cross checking these parameters loop wise.
Distances bw field instruments n control room are very short..like @ 200 mtrs at the max. so its not gonna add up much of capacitance & inductance...
Still checking all loops thoroughly to avoid any possible hazard!!!
01/06/2011 3:19 AM
.......and the training?
<sigh> This is an explosion just waiting to happen...
01/06/2011 3:29 AM
Are you aware of any online training facility?
Do suggest ...
Be happy :)
01/06/2011 3:34 AM
Try Measurement Technology Limited or SIRA (usual disclaimers).
It is important that appopriate training is completed before anything is ordered and installed, because it may be incorrect. The problem with on-line training is that it does not provide the pops, bangs and clouds of smoke that the one-to-one training that the above two providers have used so memorably to illustrate the hazards.
Good Answers: 116
01/06/2011 7:15 AM
I hope you are not too "sore" at us for keeping on! I agree entirely with PWS advice on getting Measurement technology and SIRA literature. On training, if you are the designer, a safety audit would make lack of training a "top line non-compliance" and consequences would include the Director who refused to sign the training budget. If someone above you is trained, you have every right to get them check what you do and sign to approve it. So push for some training.
Register to Reply 30 comments
67model (3); Anonymous Poster (2); Mikerho (1); msn (9); PWSlack (11); Tornado (2); user-deleted-1105 (2)
