Previous in Forum: Mechanical Engineering   Next in Forum: How Do I Get H2O Pressure At Top of a Hill
Automatic Air Vents
01/10/2011 1:49 PM
The closed loop piping network, such as that of chilled water system usually has an Air Separator in the Pump Room. Furthermore, Automatic Air Vents are provided at the highest points (Pipe Risers) to expel air before it even reaches the Air Separator. Sometimes the horizontal piping must be offset upwards to avoid other services and installations. Are Automatic Air Vents essential at these small (one foot high) offsets, or can the water push the air towards the Air Seperator (like it does in open to atmosphere systems such as domestic water supply)?
Re: Automatic Air Vents
01/10/2011 2:15 PM
Even if high flow could "wash" the air out of such an inverted trap, the problem would be apt to recur. Ideally, piping that depends on grade should have priority over other services; but if not, I think you need an automatic air vent in each location llike this.
(At least that's cheaper than lift stations for improperly sloped sewage lines.)
01/10/2011 3:02 PM
It depends upon flowrate.
Register to Reply 2 comments
