Previous in Forum: Need Help Finding the Right Adhesive   Next in Forum: Woodfired Boiler For Home Radiant Heating?
24 comments
Harvesting Energy for Seagoing Vessels
01/29/2011 11:58 AM
ok2. I'm not to fluent with sustainable technology. so I need suggestions to integrate it into ships, best if it can be integrated with bulk carriers and container ships coz they have the least amount of ppl and most amount of space to work with. there will be no need of ergonomic designs.
there will be several reservoirs that I can think of, wind power, the sun, the movement due to waves and the heat from the engine system.
if possible there should not be increase in air or water resistance.
an idea I came up with is power from pressure of the cargo to the vessel. if I'm not wrong there is something like when pressure is exerted on it, there will be electric generation. no idea what it is called. next would be the new bladeless wind turbine. if it can swivel according to wind direction that would be great, then there is the sun. I discovered in this forum bout a system that can freeze food better if the sun is more intense. then bout the temperature difference generation of electricity. (the idea is reducing power needs that have to be readied before the voyage ie fuel, coal, etc2)
until the battery systems gets better, most likely each of the systems would be very limited to like daytime use etc2. seagoing vessels are on going for 10-20 years straight, they are not cars so...even if the harvesting is still minimal that would mean a lot can be harvested.
If there are battery systems available for massive amounts of energy to be stored for long voyages. they even can sell e- to other countries when the vessels gets into port.
if this idea is possible the need of fuel for electricity could be reduced. less of that more of this. then the technology could be expanded for normal people.
Ships are like small countries, they have almost every support system available for human life. so its a great area to improve. they can handle the starting cost of research so that normal ppl can have better items for less in the future.
Re: Harvesting Energy for seagoing vessels
01/29/2011 12:13 PM
"no idea what it is called"
It's called piezoelectric generation.
I'd have to call a "blade less wind turbine" an oxymoron.
Keep thinking.
01/29/2011 12:21 PM
01/29/2011 12:50 PM
One might rig-up some sails, perhaps?
01/29/2011 1:11 PM
See post #2.
01/29/2011 4:01 PM
There's a crabber for ya!
01/30/2011 2:17 AM
have u seen a vid from tedtalks where there is a dude from san fransisco who is researching using kites to harvest wind power? the larger the wing span he can get his hands on the larger the power generation. control systems are conducted with actuators pre programed to keep the kite in the air. I have no idea the principle of where he transfers wind energy to e- from. springs?
Kick ASS
01/30/2011 2:09 AM
they are called supersails. not bounded or constructed in the same structure of the ships but they are small bots with control systems that tows the main vessel, will require several of them to work. and the thing is that will be concerning the propulsion systems which will be concerning the main mover.
I'm considering of supplying choice by creating new auxiliary power plants for unharvested resources. consider this, what was fossil fuel considered as b4 the creation of internal combustion engines? they were just muck that oozed out of the ground, used either to start a fire or maintain it. boilers still used wood till they had any idea to use processed natural gases. fossil fuel are concentrated energy of the sun, harvested by living things ages ago and compressed under great pressure.
so is the wind and movement of the seas, they are also moved by the sun.
Kick ASS
Good Answers: 114
Re: Harvesting Energy for Seagoing Vessels
01/29/2011 10:59 PM
If you drop the right electrodes into the sea, it works like a battery. Research it.
01/30/2011 1:20 AM
I understand that. the thing bout that idea is it will also be like fuel system where u will need to bring something that has energy stored and will have a product of energy and thingamajigs that will be an equal to CO. so if used in huge number will bring impact at the same scale of internal combustion engines and other fossil fuel powerplants. maybe ur view of the byproduct being an innocent thing to just leave in the sea coz it is huge. maybe the early engineers of internal combustion engines thought of CO and lead with the same views but they were wrong weren't they. not forgeting there are laws under IMO what could and couldn't be thrown into the sea. a
I know there are rogue currents in the seas that has yet to be harnessed except it bring problems of hull deterioration due to electrochemical reactions. that was an idea as well but not interested to develop it cause it will be limited to the Shipbuilding industry only. let that be researchd by somewhere else.
Kick ASS
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
01/29/2011 11:05 PM
A Japanese adventurer designed a small boat "motor" that utilized the action of the waves to propel him thousands of miles in the Pacific Ocean. That might be combined with the wind turbines and solar power. Computer software could coordinate everything to work automatically. A smaller conventional engine could prevent getting stuck in the doldrums, and only used as needed.
Fuel prices would have to go much higher to spark interest in commercial vessels. Ships use very poor quality fuel to save money. Check out the smokestacks.
Good Answers: 39
01/29/2011 11:41 PM
As evidenced in so many ways, ship owners are rapacious competitors, and very uninterested in anything but payback, and no doubt these great ideas require capital investment with long payback times. Sailing kites work, for high-minded Scandinavian companies. California is banning high sulfur bunker C fuel near shore. If you want to save the world, advocate for taxi-bus. Look it up.
Align culture with nature...
Good Answers: 25
01/30/2011 2:14 AM
Putting wind turbines on board makes good sense if you can prevent them from interfering with the operation of the vessel. Wind is generally stronger offshore than onshore because there are fewer obstacles and turbines, unlike sails, can be used for providing ship's service power as well as propulsion. I haven't gone into detail on this, but I suspect that when all the numbers are run it would make sense to use wind for ship's service power primarily, and as a propulsion booster in a diesel-electric propulsion plant (which I think is fairly rare at present). This could be a big money saver on ships with heavy ship's service power use - refrigerated vessels come to mind.
Sails and propulsive kites have to be watched and trimmed, and the kites have to be quickly taken in in a dead calm before they fall into the ocean. Ruggedized vertical-axis wind turbines, on the other hand, can be made to furl automatically in a "blow," and to operate entirely automatically in normal weather.
01/30/2011 6:21 AM
As I understand it, the kite systems are highly automated in operation and self retreiving in the event of low wind.
IMO, There are several advantages to capitalize on with kites including stronger and more reliable wind at altitude, minimal changes to the vessle for low cost retrofit and interoperability with existing ports, and efficiency with fewer conversions of energy from harvest to use.
I don't have a good grasp on one thing you mentioned; the ruggedized VAWT that is self furling. In the context of wind turbines, I understand 'furling' to mean 'turn out of the wind' (typically at high windspeed to protect from overspeed and reduct tower load by presenting a reduced profile) and have only heard it used describing HAWT.
VAWT are designed to be indifferent to wind direction, so it seems unlikely VAWT will have any luck pointing away from the wind or reducing profile during gusts.
Please enlighten me.
Good Answers: 25
01/30/2011 9:19 AM
"I don't have a good grasp on one thing you mentioned; the ruggedized VAWT that is self furling. In the context of wind turbines, I understand 'furling' to mean 'turn out of the wind' (typically at high windspeed to protect from overspeed and reduct tower load by presenting a reduced profile) and have only heard it used describing HAWT."
In sails, furling simply means dropping the sail and rolling or folding it up. Turning it out of the wind is called "sheeting out." What I meant by furling is taking a more or less standard Darrieus "eggbeater" turbine and stretching the blades flat against the central mast by extending the top of the mast. The blades, when operating, are flexed into a natural equilibrium shape called a troposkein; there's no reason why they can't be made flexible enough to lie flat against the mast when not in use. I thought this up ages ago, honest... the folks who wrote the Waterworld screenplay stole it from me!
01/30/2011 7:32 AM
Turbine? Your payback will be limited.
Sails will push you UP-WIND
Turbine will push you DOWN WIND. This will work fine if you want to go back to where you came from...
Never trade luck for skill.
Reply Score 1 for Off Topic
01/30/2011 8:04 AM
'....Turbine will push you DOWNWIND. This will work fine if you want to go back to where you came from...'
Where is this place where winds always blow towards shore and captains destinations are always upwind???
At any rate, sails cannot sail directly upwind, whereas a turbine powering a prop can sail directly upwind.
Flee to me remote elf
01/30/2011 9:41 AM
FYI: This is why sails swivel.
And if turbines are the proposed solution, Than he should use a vertical turbine, the main problem with turbines for this application is that they will produce aerodynamic resistance equale more or less to the energy they may produce, problem which is totally in favor, when it comes to stationary turbines. Construction resistance will always be added to the blade speed of rotation and here speed=power.
Sorry I don't believe that turbine power to propel a sea going vessel is feasible.
02/11/2011 2:15 AM
There are many working models of wind driven land and sea vehicles that can go straight directy upwind on wind power alone. The ones i know of all use HAWT not a VAWT. HAWT produce far more power per swept area than a VAWT.
Powering straight into the wind, actually increases the apparent windspeed and thus power available.
What i found very interesting and highly controversial is that it is possible to go straight down wind, faster than the wind.
Before anyone comes after me siting 2nd law of thermodynamics, nothing is violated.
Rigging is modified in that instead of the wind turbine turning the wheels or prop, the wheels or the prop in the water are use to drive what would be a wind turbine as a propeller.
01/30/2011 11:15 AM
WRONG. It is possible to proceed upwind in a sailboat powered by only a wind turbine of realistic efficiency driving a screw propeller of realistic efficiency. The theory was worked out in the late forties, and several windmill-boats have been built and successfully operated to prove it in practice.
01/31/2011 1:37 AM
ur first point is the kind of power I was thinking of, money saver not main movers. Then bout offshore wind farms. is it really that harder than land based wind farms or just a bit different? there would be stability issues that have to be address, but other than that it should require the same specs of coastal wind farms due to the salinity.
Seriously. to design another primary mover to outdo and give a better cost/benefit ratio against the diesel engines of that scale which uses nearly tar-like fuel is a very tall order. not forgetting designing it so that shipbuilders has little problems during installations would require it to either have a research grant billions pounds or have a patronage by the likes of bill gates but has passion like al gore.
Kick ASS
01/31/2011 2:56 AM
Darrieus turbines are very well documented; there's an extensive literature on them from DOE research and Canadian work, plus amateurs who built them for small-scale power supply. They've lost favor with amateurs because it's hard and expensive to get them high off the ground where the good wind is, but this is not a problem on the ocean, where the surface boundary layer is much thinner.
You could gather data with a small, non-retracting Darrieus turbine mounted on the foredeck or some other place where it would be out of the way, or made easily removable. If the results (energy gathered over the cruise) justified further work, a bigger turbine or a turbine array could be installed and connected into the ship's service distribution system (the experimental turbine/generator would just be connected to a dump load for easy removal). The scaling laws for these things are well understood, so the question of whether it is economically desirable could be answered at small scale and low cost.
The turbine itself requires no development. I am not certain that a retraction mechanism would be needed other than to save deck space. If it wasn't, a simple brake would do for stopping the turbine in storms, and those are well known.
01/30/2011 11:25 AM
I have a possibly good invention for sail powered ships.
Make the mast oscilatory in a transverse way and prolong it to the water trough a watertight seal.
The part of the mast under water has the shape of an oar and it works at the venetian stroke style
This vessel advances well completely against the wind by olcillating the sail. But in normal sailing situations it will get a good help from the submersed oar if you let the sail oscilate, that does not detract much energy to the sail.
Chorete.
Good Answers: 12
01/30/2011 12:53 PM
Illustration of Drive Mechanism of Suntory Mermaid 2, which sailed from Japan to Honolulu (7800 km) using solely wave power.
http://yachtpals.com/boating/wave-powered-boat
02/17/2011 11:41 PM
You could coat the bottom of the boat with strips of graphite and metal and turn it into a giant Salt Water Battery. The Sea would be the electrolyte.
Reply to Forum Thread 24 comments
Anonymous Poster (5); Chorete (1); Danial.hussin (4); Flee to Me reMote elF (2); lyn (2); ormondotvos (1); passingtongreen (1); piolenc (2); PWSlack (1); ronwagn (2); Tornado (1); wangito (2)
