Previous in Forum: Problem with Danfoss Inverter VLT-5000   Next in Forum: Exe MCCB
10 comments
The Concept of the Load Angel
02/24/2011 2:47 AM
Hi
I am getting confused in the concept of the load angle under full load conditions,so please I need help and my question is
What is the load angle under full load conditions? is it true to consider it 90 degree as the generator is working with max. power.
Thanks.
Re: The concept of the load angel
02/24/2011 2:57 AM
The "load angel" is a fictitious spiritual "concept" with no known basis in reality.
Good Answers: 18
02/24/2011 3:45 AM
Hi Tornado,
I hope you haven't shattered his belief in "Guardian Angles"
John
Best advice I can give as you get older "Never miss an opportunity to relieve yourself"
02/24/2011 3:52 AM
What's a "guardian angle"? 5, 10, 15, 20°, or further on up? (I suppose I would vote for 180°.)
02/24/2011 4:41 AM
'Guardian angle' is the angle at which the guardian can be most conveniently read on a tube train without incomodiating one's fellow passengers old chap.
Good Answers: 18
02/24/2011 5:11 AM
lol
John
Good Answers: 18
02/24/2011 5:20 AM
Maybe 90º is the "Right Angel? (I think we had better "call it a day" on this one before it gets very silly)
John
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
02/24/2011 3:53 AM
90 deg ? where did find it ? please tell us your case
One system
02/24/2011 5:24 AM
Load angle cant assume such high values. More so because if it goes beyond 90 degrees, we will not be able to find a stable point on the load angle curve which can satisfy the Equal area Criterion. So it is kept low so that even if there is a considerable amount of disturbance in the system, the system still remains stable (the angle oscillates between two points until the disturbances are damped off.)
mscs
02/24/2011 7:01 AM
The work load determines the angle.Angels are not real because they cheat. More the excitation in DG angle tends to reach 90 degree.
Good Answers: 244
Re: The Concept of the Load Angel
02/24/2011 8:50 PM
Anonymous Poster (1); jesw55 (3); loadshare (1); msamad (1); MSCS (1); Tornado (2); user-deleted-1105 (1)
