Previous in Forum: What's an Acceptable Vent Temperature on Car A/C?   Next in Forum: Rear Calipers Freezing
42 comments
Vehical MPG
03/26/2011 5:09 PM
Engine: 327 CI RPM@60MPH = 3260 Air Consumed = 8,883.5 CI/mile
Air: 13.26 CF/LB = 1728 CI/1 CF = 22,913.28 CI/LB
(13.26 x 1728 = 22,913.28)
Gasoline: 6.152 LB/Gal
Strocometric Air/Fuel ratio: 14.7 LB air: 1 LB Gasoline = 336,825.216 CI Air : 1 LB Fuel
(22,913.28 x 14.7 = 336,825.216)
Air for 1 Gal: 2,072,148.73 CI/Gal
(6.152 x 336,825.216 = 2,072,148.728832)
MPG: 233.26
(2,072,148.73 / 8,883.5 = 233.258144)
Pressure conversion example taken from a math problem text book.
14.7 psi = 103 psi x (14.7/25)*175 = x
175 in3 25 in3
This MPG is with an atmospheric pressure of 14.7 PSI filling the piston displacement on the intake stroke.
Now assuming the engine is operating @ 3260 RPM and were traveling @ 60 MPH, the intake manifold pressure reads 10 In Mercury, the above 2,072,148.73 CI/Gal has expanded to 3,122,458.884 CI/Gal yielding 350.364 MPG.
The above figures are statements of applied scientific facts based on ideal fuel ratio and ideal fuel mileage if all available energy was applied to motivation (neglecting friction). Please feel free to give input and ideas, opinions regarding this calculation.
Why are we still getting around 25 to 32 MPG on the highway?
Re: Vehical MPG
03/26/2011 5:24 PM
"Why are we still getting around 25 to 32 MPG on the highway?"
Who's getting 25 to 32 MPG? The auto industry wants to know so that they can fix that. Its way too high of number!
I don't think your math is exactly correct but still it goes along with may argument of why does a 80,000 pound semi truck and trailer with ten times the aerodynamic drag of a small car and 27+ times the weight only get 1/4 to 1/5th of the fuel mileage at the same highway speeds and driving conditions?
Re: Vehical MPG
03/29/2011 8:49 AM
According to the on-board computer, my 2004 Volvo S60, with the non-turbo 5 cylinder engine on 87 octane gas, gets an average of 29 MPG on the highway, driving 40 miles each way. On the flat at a steady 65 MPH it gets better than 35 MPG. Accelerating while in traffic can drop the MPG to half the normal average.
Driving up a hill at 20 MPG then coasting down the other side at "99 MPG" results in only 40 MPG average. The same with acceleration. Easy on the pedal!
Re: Vehical MPG
03/26/2011 5:40 PM
Because that's reality.
I'm have difficulty with this, "the above 2,072,148.73 CI/Gal has expanded to 3,122,458.884 CI/Gal yielding 350.364 MPG."
You would have us believe that your engine has manufactured more new air than my calculator can compute?
Re: Vehical MPG
03/26/2011 6:15 PM
The increase in air volume is the reduction in air pressure from atmospheric to the 10 inches of mercury. For the same quinty of air (by weight), there is an increase in displacement with the reduction in air pressure.
Re: Vehical MPG
03/26/2011 6:24 PM
And how does this affect stoichiometry during combustion? The 10"Hg is only in the intake manifold. Nothing happens there.
Enlighten me.
Good Answers: 137
Re: Vehical MPG
03/27/2011 9:41 AM
But at 10" mercury the quantity of air by weight is not the same as at atmospheric pressure. The volume stays constant (= engine swept volume), it's the the pressure and mass of air that change.
Cheers.........Codey
Re: Vehical MPG
03/26/2011 6:24 PM
At one intake stroke per 2 revolutions, 327/2 x 3260 = 533,010 in3/mile. (Not 8883.5)
Oxygen constitutes 20.9% of air.
Adjust further arithmetic accordingly.
Good Answers: 137
Re: Vehical MPG
03/27/2011 9:36 AM
Ref my post 1 minute ago, just noticed you'd also said it.
Re: Vehical MPG
03/26/2011 7:46 PM
My math says that a 327 CI engine turning at 3260 RPM would use around 304 cubic feet of air a minute at full throttle in theory. However to get roughly 10 inches of vacuum that would need to be considerably reduced, as in light part throttle driving, perhaps around 1/4 throttle yielding a rough estimate of around 75 CFM air flow.
Given that one gallon of gasoline has approximately 39 KWH's of energy and a 4000 pound car traveling at 60 MPH could conceivably be using around 300 watt hours per mile that would suggest that at 100% efficiency a gallon of gas could move that car roughly 130 miles.
Take into account an non emissions compliant engine of efficient design can be around 30% efficient that car could in theory get around 39 MPH realistically. With an emissions compliant engine that has around 20% or less efficiency you would get roughly 26 MPG or less average fuel economy like we see today.
But thats just my math.
Good Answers: 137
Re: Vehical MPG
03/27/2011 9:35 AM
You're right, I was going to post that but you got there first! 304 ft3 = 525300 in3. OP's figure 8,883.5 CI/mile is a factor 60 out.
Good Answers: 137
Re: Vehical MPG
03/27/2011 4:03 PM
If it were a constant mass of gas expanding from 30" mercury absolute (zero vacuum) to 20" mercury absolute (10" mercury vacuum) your volume figures are about right. But it reads more like you mean 10" mercury absolute, which would give expansion ratio 3 x, not 1.5 x.
But in any case, as indicated in #9, the volume flow stays constant, the mass of air (and fuel) go down in proportion to the absolute pressure. And where is the 10" mercury from? Without checking in detail, it looks like the pressure is lower than 10" mercury, giving lower fuel input and the sort of fuel consumption seen in real life.
Re: Vehical MPG
03/27/2011 10:29 PM
just posting to be entertained
Good Answers: 110
Re: Vehical MPG
03/28/2011 1:18 AM
Your math is wrong from the very first line.
All the rest is therefore wrong too, but even if the math were correct, the logic is wrong. All you need to calculate fuel efficiency for any car is 1. the hp required for the test condition (calculated from aero drag, grade or acceleration, rolling resistance, and transmission losses) and 2. the bsfc of the engine at that hp.
Modern gasoline engines have peak efficiencies in the range of 30% to 38% (with the Prius at 38% being the exception). Most of the rest hover around 30-32% (in bsfc terms: about .4 lb/hp-hour).
Engines from the days of the 327 had efficiencies of 25% (the same as current non-emission-controlled engines, like general aviation aircraft engines.) The Prius is therefore 50% more efficient than the old Chevy engine, at peak hp in each case. However the Prius operates at a much larger percentage of its full load more of the time (due to the cumulative effects of a small engine and hybridizing)*. So while a 3600 lb 1962 Chevy Impala got 12 miles per gallon, a 3100 lb Prius gets 50 mpg. (In the Car Life test the 409 Impala got 10-13 mpg, and did a blistering 14.9 quarter mile, a time that an ordinary Toyota Camry V6 can beat today. The electric Nissan LEAF, considered anything but a performance car today, gets to 60 in 8 seconds, just .7 seconds longer than the 409 did in 1962.)
* (The Chevy, when producing 20 hp (about 10% of its maximum of 160 real hp) to go 60, is about 10% efficient. The Prius is over 30% efficient at that same power level.
Because you're driving the wrong car. Get a Prius if you want 50 mpg. Get a Hyundai Elantra or Ford Fiesta if you want 40 mpg. If you want 40 mpg in an SUV, then develop an engine that runs at 70% efficiency. If you want the 350 mpg you seem to think is possible, then just develop an engine that runs at 300%-400% efficiency.
Think big. Drive small.
Re: Vehical MPG
03/28/2011 3:32 AM
As long as the almighty 14.7 parts of air to 1 part of fuel ratio is utilized, you are correct.However, I can prove that regular pump gasoline can be safely converted to 100 parts of air to 1 part of fuel.With vaporized gasoline an engine will actually run much cooler and produce much more power.However leaning out a traditional atomized fuel system will result in a loss in power and possible engine damage.But all of the "experts" will go out of their way to tell me that I'm wrong.To them I ask why is it that a gasoline powered engine requires more frequent oil changes, spark plug changes, and increased wear as compared to an engine that operates on natural gas or propane ? On a molecular level there really is no difference between gasoline propane or natural gas.Only the dispersal.That's the difference between atomization and vaporization of petroleum.But again, all of the college educated "experts" will continue to go out of their way to tell me that I'm wrong ! If Ignorance is bliss, these are very happy people !
Gary T. Kirkland
Reply Off Topic (Score 3)
Good Answers: 110
Re: Vehical MPG
03/28/2011 1:05 PM
They don't need to go out of their way. They can do it as a matter of course. The only thing burning in a gasoline-fueled engine is vapor, (the millions of tiny liquid droplets having been converted to vapor by the combustion chamber heat). In a modern engine effectively all the fuel burns: none goes out the tailpipe*, none goes into the oil, and none magically disappears. (This is true when making statements that could imply a 1 mpg difference either way. Only when we are talking about making changes that produce .1 mpg and less do the slight variations having to do with liquid vs vapor come into play: the period right after starting is an example: this is why there has been an effort aimed at getting engines to warm up more quickly and to go into closed loop operation more quickly... now, many cars are in closed loop by the time they reach the end of the driveway.)
You will find that people schooled in combustion science are realists, and will only begin to "believe" you when you present dyno data showing the results of your modifications. There is already a load of dyno data that shows that you are not remotely close to being correct, in any respect... so your challenge is to show why you are right. The fact that SI engines produce less power on propane and natural gas (both vapors at the time of induction) should give you a hint. (... And a simple Wikipedia search would show you that propane, gasoline and natural gas are not molecularly equal, as you incorrectly claim.)
Science and religion are different things.
But please carry on in your research. Then, after you have good dyno data, publish your results, and let us know where the study has been published. Until then, no further response is required from you -- we don't want to drain away your valuable time. The internet can be a time sink.
To be treated as something other than a troll in this forum, you need to say not that "I can prove..." but instead to provide proof. Also your statement (I can prove that regular pump gasoline can be safely converted to 100 parts of air to 1 part of fuel.) would be more interesting if went a little beyond something that any seventh grader could prove. Put a drop of gasoline in an appropriately sized box, wait a while: you'll have a 100:1 air:fuel ratio. Engineers would say "So what?" Making an engine run on such a ratio without simultaneously producing the expected 7 fold reduction in power would be a good trick, and would be something we would be interested in reading about in the literature. (For your research, read about diesels. There, you can see that power output is essentially and directly tied to the amount of fuel burned, and that at low power output the air fuel ratio is very high, because the throttle is full open all the time. Also read about HCCI engines.)
You should also try to come up with something to separate yourself from all the many frauds who have been advertising fuel vaporizers through the decades. Perhaps you could provide links to the various studies that have shown that fully vaporized fuel at 100:1 is well outside the spark-ignitable range. Then clearly and concisely show how you have overcome this fundamental problem (compression ignition?). This sort of clear explanation would be beneficial to your cause. Studies with hydrogen gas augmentation to improve ingnitability of very lean mixtures show that excess air ratios of 1.15 and higher lead to misfiring, and that augmentation can reduce misfiring (but with hydrogen injection, at no net gain in power or efficiency, and at considerable cost in terms of complexity and operating cost).
Good luck with your project, and do stop back in after you have links to some published data we can look at. Please don't let us take you away from your research. Remember, they said "it can't be done" to Madoff, but he did it.
BTW, CR4 has a long history of attracting frauds in the fuel efficiency business. (Why they pick here, of all places, is baffling -- are they masochists?) You should make sure that you present your info with good solid data to avoid the perception that your are just another in a long stream. I look forward to reading your journal articles.
I wish you bliss.
* This is true, even if you remove the catalytic converter. Even without the converter in place, modern engines are incredibly clean burning, and emit tons of CO2 (a normal and required product of combustion) but tiny amounts of criteria emissions (undesirable byproducts of combustion). Emission regulations are set so stringent because they can be easily achieved with three-way catalyst, but also because they are still too high for cities, many of which remain smog-choked because of automotive (and industrial) NOx emissions. Go to countries where emissions standards are lax, and your eyes water.
Re: Vehical MPG
03/28/2011 10:52 AM
Not sure of the basis for your comment "Engines from the days of the 327..." The 5.3L used in current Chevy & GMC pick-ups, SUV's, Camero, et al is 327 c.i.d.
Good Answers: 110
Re: Vehical MPG
03/28/2011 11:42 AM
I gather you are rather young.
The 327 was produced from 1962 to 1969. It has a 4" bore and a 3.25" stroke, and has more lore associated with it than perhaps any other Chevy engine, having been the standard Corvette engine for that period, and having been a favorite swap for hot rodding almost anything. It's calculated displacement rounds to 327 ci. It is a member of the generation 1 "small block" Chevy engines.
The 5.3L engine's displacement is 325 ci. There is not a single significant component that the two engines share (and of course, there is nothing remotely like the same "lore" -- you don't hear songs on the radio about 5.3 liter engines). http://forum.miata.net/vb/showthread.php?t=274715
Re: Vehical MPG
03/28/2011 1:25 PM
I wouldn't say that just because some newer models of vehicles are getting more efficient that it honestly equates to every newer vehicle being equally efficient. Just the same saying that just because some old engine designs are very inefficient that it means that all older engine designs are as equally inefficient.
We have about 20 -30 years of emissions compliant engine designs where far far too many became well noted and well known for being absolute fuel pigs despite their lack luster power or vehicle mass numbers.
I for one have been around a few too many mid sized cars built between the late 1970's all the way up into the early 2000's that despite having half the mass and half the Hp of many old full sized pickups still got similar fuel mileage numbers.
On top of it I would hardly call the Prius a outstandingly efficient vehicle considering that in the late 70's and early 80's they typical Volkswagen Rabbit Diesels, along with many others, where pushing the same average fuel economy numbers with similar lackluster body size size and engine power despite having zero hybridized drive train design to maximize their efficiency.
Good Answers: 110
Re: Vehical MPG
03/28/2011 2:45 PM
No. But fuel efficiency is a market driver in many vehicles, and in those where the market is close and competitive, the engine efficiencies from one car to the next are almost identical, both in steady-state dyno rests and in epa cycles. That's because the manufacturers design to the EPA tests, which happen to correlate with (synthetic) average real driving (because it was based, long ago, on data logging from actual driving sessions.)
You'd be hard pressed to find a typical SI car engine (in which efficiency is an issue (filter out Ferraris, Hummers, etc) in which the peak efficiency differs by more than 1%-2% on either side of 31%. There is no conspiracy by the car manufacturers to make less efficient vehicles, and the things that I am doing to my little prototype engine to improve its efficiency are the same things I am doing to improve its emissions. Stated another way, my only realistic route to high efficiency also happens to be the route to low emissions. This trend is what gives us average, feature laden family sedans that can blow the doors off old 409's, 389, etc. (and even late eighties "super cars" -- Motor Trend tested family sedans against of Ferraris, etc, and the family sedans won.)
Find a bsfc chart from any production SI engine of the 50's, 60's, 70's, 80's, 90's that is better in either peak or breadth of peak than a current engine. Can't be done.
The Rabbit diesels were a fraction of the mass of the Prius, yet still did not get the same fuel efficiency as the Prius in the same tests. (The 1985 Golf diesel gets 31 city , 41 highway... stunningly worse in the city case, given the low mass, to much worse, in the highway case, than the Prius.) And obviously, the Rabbit is a diesel. The current VW diesel engine is more efficient than the Prius engine, but the Prius engine is in a class of one for SI engine efficiency. The major reason why the Volt gets crummy mileage (it's not enough heavier than than the Prius to justify its dismal mileage [37 vs 50 mpg]) is that it's engine is lower efficiency. Chevy readily admits the engine is a POS that they found on the shelf, and that they spent development time on other things.
The current Prius is in the same weight class (3100 - 3500 lb) as a light 62 Chevy (Biscayne, manual trans, 283, no air). The Chevy got 15 mpg, the Prius gets 50. That's a large difference in vehicular efficiency.
Re: Vehical MPG
03/28/2011 2:59 PM
Sorry but I have driven a Prius and unless you intentionally drive it to get high mileage it gets about the same mileage as any other car its size.
I am not the only one who has found that out, I just happen to be more vocal about it.
Here is my personal experience and review of having driven one like a normal person that actually likes to get some place in a practical time frame.
http://cr4.globalspec.com/thread/63109
Good Answers: 110
Re: Vehical MPG
03/30/2011 12:34 AM
Individual personal experiences are not useful as a measure of the efficiency of a car model... they measure driver behaviour, location, weather, terrain, tire inflation pressure, gasoline age and formulation, altitude, etc. Only slightly better are dyno runs on variable load machines that can be held at a constant load (If you use 45 mph and a 3% grade, you can get close to epa numbers.) Better, by far, are the EPA test cycles run in an EPA certified lab. The last are the only tests that come close to being repeatable and representative of the actual performance of a car model rather than the driving technique of an individual. They include starts, stops, acceleration, deceleration, idling, etc... all the facets of real driving in a highly repeatable format in which speeds and loads are monitored second by second.
My Honda van gets 6.2 mpg sometimes and 99 mpg at other times. Somewhere in between is an average for me. Somewhere else between those numbers is an average for someone else.
The average of 136 Prius drivers who sent in personal results on 2010 Priuses was 48.5 mpg, extremely close to the EPA rating of 50 mpg. The average of 14 Camry drivers was 26.6 mpg, also extremely close to the EPA rating of 26 mpg. For the Corolla: 29mpg EPA, 32mpg for average of 24 users. Again, very close. For most cars, if the user results are averaged to balance the lead foots with the grannies, (and if there are 10 or more respondents) the number comes very close to the EPA numbers.
Re: Vehical MPG
04/11/2011 5:29 PM
"Individual personal experiences are not useful as a measure of the efficiency of a car model... they measure driver behaviour, location, weather, terrain, tire inflation pressure, gasoline age and formulation, altitude, etc."
Unfortunately I and most of the rest of the world of people who drive tend to measure fuel efficiency or lack there of by what, when, how, and where we drive and at the most basic core that part where we pull into a gas station and spend our money only to find that the idealistic estimate numbers rarely if ever are close to what the factory said they would be.
I don't care what the factory tells me my vehicle should get. I care about what it does get and by what means can I change that number to my advantage by any modifications to the vehicle as practical.
Re: Vehical MPG
03/28/2011 2:56 AM
•I would like an answer to a question.Please look at the attached Photo below of my Gasoline Vaporizer.With the aid of a low pressure Air Compressor, Vaporized Gasoline at 100 parts of Air to 1 part of Fuel,intended to power an Engine, is instead safely ignited to prove that it actually works.Notice the colors of the flame.It goes from Blue to Yellow to Orange.This is the very same flame color pattern of a bic butane lighter.This is proof that there is really no difference between Butane and Gasoline.With Vaporized Gasoline, even the largest SUV could easily get 50 + MPG, and emit a fraction of the Emissions of an EPA-OBD II mandated fuel system, which operates at 14.7 parts of Air to 1 part of Fuel.Also, with Vaporized Gasoline, there's an increase in power, as well as much longer engine life.And the resulting Flame has a much lower combustion temperature than Natural Gas, or Propane, both of which burn Blue.Hydrogen burns even hotter.The problem with such a high combustion temperature is that an Engine has to be modified to withstand it, which is very expensive.Again, not so with safely Vaporized Gasoline.In the past, Vaporizers relied on engine heat to function.With the additives in today's Fuel, that's all but impossible.My unit uses low pressure Air to do it's thing.But there is another problem.All Gasoline powered vehicles from 1996 to the present are required to pass the EPA-OBD II vehicle emissions inspection.All such vehicles have on board oxygen [O2] exhaust sensors.These O2 sensors are set up to detect a level of polluting Exhaust Emissions that would indicate that Fuel is being metered into the engine at 14.7 parts of air to 1 part of Fuel.This is detected by the level of polluting Exhaust Emissions registered when a vehicle is connected to an OBD II Emissions Analyzer for it's annual Emissions Inspection.Anything below 14.7 / 1 would result in an excess level of polluting Exhaust Emissions being generated.This will result in a failed Emissions Inspection, as well it should.But, with a vaporized fuel mixture of 100 parts of Air to 1 part of Fuel, the result will be far less polluting Exhaust Emissions.O2 sensors are incapable of registering anything far below the established resulting emissions of an air/fuel Ratio of the 14.7/1 level.An O2 sensor failure code will result if such a vehicle is connected to an OBD II emissions inspection analyzer.O2 sensor exemptions are granted for vehicles that have been legally converted to operate on Natural Gas, Propane, or Hydrogen, and are registered as such.But no such exemption exists for Vaporized Gasoline.Thus, it is entirely possible for any vehicle from 1996 to the present to fail an Emissions Inspection for not emitting enough polluting Exhaust Emissions ! Also, since the vast majority of Vehicle Manufacturers wish to sell their Vehicles in the U.S.A., they are made to comply with this EPA-OBD II Law.Thus, this amounts to a World-Wide Issue.I'm convinced that alternative use of conventional Energy, at least in the short term is the way to go.But the Big Oil Corporations, with Big Government in their pockets, are going to fight this every way they can! For even more insight, do a search on [the late] Tom Ogle.Then, go to http://energy21.freeservers.com/bookrep.html . Scroll on down the Page and check out the last few Paragraphs just before the Update.Until this insane EPA-OBD II Law that only benefits Big Oil is changed, the only way to make vehicles more "efficient" will be to make them smaller and lighter. I have contacted, and joined the new Administration's site, www.change.org and they're too busy to be bothered with it.Likewise www.friendsoftheearth.com , www.mike@michaelmoore.com www.algore.org and many other Environmental Organizations as well. Not one of them, nor any Politician can or will honestly answer my question ; " Why is it illegal for any vehicle from 1996 to the present to emit too little polluting Exhaust Emissions " ? I'm not trying to sell anything.Everyone else that's tried to do so has been effectively stopped one way or another.But I must ask, if you truly care about the Environment, can you please answer my question ? No one else seems to be able to do so. Thanks ! Gary.
Gary T. Kirkland
Anonymous Poster #2
Re: Vehical MPG
03/28/2011 6:51 AM
Thank you for the information Gary, you are right on. I hope you get an answer soon.
Reply Score 1 for Off Topic
Re: Vehical MPG
03/28/2011 7:25 AM
I've been waiting for an Answer for over 10 Years ! Again, not one "Concerned EnvironMENTAList, Oil Company Executive or Politician will dare to even attempt to answer my question ! Thanks for the reply ! Gary
Gary T. Kirkland
Reply Score 2 for Off Topic
Good Answers: 137
Re: Vehical MPG
03/28/2011 10:14 AM
Perhaps I'm being a bit slow, but what exactly is the question? Looks more like a lot of statements to me.
BTW are you the OP?
Re: Vehical MPG
03/29/2011 10:57 PM
I also suspected 'Gary T Kirkland' was the OP. On closer inspection I doubt he is.... if he is the OP, he put more thought into the deception than into his '10 year unanswered question'.
The OP did not spell 'vehicle' correctly, Gary T consistently did.
The OP did not spell 'stoikiometric' correctly (I'm not certain i have either,but it is at least phonetically reproduced), Gary T did not attempt it, but his comments strongly suggest Gary T. is unfamiliar with the word.
The OP is proficient in utilization of the space bar and the creation of new distinct paragraphs. Gary T. Kirkland could use some practice in those areas.
Although my intent is to establish a high probability the OP and Gary T are not the same person (and not simply to call out errors) I know that noting spelling or punctuation errors others have made still opens me up to being slammed for similar errors I have made. Fire away, I will not shirk legitimate criticism.
Re: Vehical MPG
03/29/2011 1:21 PM
As someone else mentioned, it isn't all that clear what your question is. It seems that it really all comes down to, "Why won't people who know the subject matter accept the patently false statements that I make which are absent any evidence and contradict basic physics principles?"
You have demonstrated conclusively that you not only lack the most basic understanding of the thermodynamics of combustion and heat engines, you lack even the common sense understanding of the subject (largely an intuitive grasp of the First Law) possessed by the average mechanic.
You would not come to a forum frequented by those who know the subject matter if you were a scammer, so you are obviously sincere. If it's true that you've been asking these questions for over 10 yrs, it's astounding that you have made no progress towards understanding in all that time. My guess is that you are making the same erroneous statements and ignoring the the same criticisms that you were 10 yrs ago. My guess is that you have not once even considered learning the subject matter in all that time because you place your preconceived notions and gut feelings above science.
That makes you what is universally known as a "crank". As with most cranks, you are also a conspiracy theorist. My experience with both is that they are almost totally incapable of ever escaping their flawed reasoning methods. I'm convinced that they (you) possess a cognitive pathology that is surely caused by an organic brain difference relative to the neurologically "normal". I wish you luck.
Re: Vehical MPG
03/28/2011 11:27 AM
Have you succeeded at making an engine run with such a set-up? If so, do you have any Power/Torque, emissions, or BSFC data? Is your 100:1 ratio by weight or by volume? I would be very interested in seeing some documented results.
Sounds like you do not have an adequate understanding of engine emissions and the effects of air/fuel ratio. There are 3 primary catagories that are regulated: Oxides fo nitrogen (NOx), Hydrocarbons (HCs'), and particulates. Changing the A/F ratio will usually reduce one type of emission, but increase one or both of the others. What sort of emissions does your engine produce?
Ultimately, any given amount of any fuel has only a certain amount of energy that can be released during combustion. Today's vehicles (not just the engines, but transmissions, axles, bearings, brakes, aerodynamics, tires, etc) are only able to put about 30% of that energy towards actually moving the vehicle. Most of the remaining 70% is lost as heat. Most of it just goes out the tailpipe as hot exhaust.
Why did you choose to make your post harder to read by not including a space (contemporary) or 2 (conventional) after the period at the end of each sentence?
I imagine you are generally a very happy person!
Good Answers: 114
Re: Vehical MPG
03/28/2011 11:51 AM
ah the classic conspiracy theorist
if there is no difference between Gasoline & Butane , [there is also propane, methane/natural gas] wouldn't all these gaseous fuels yield the same results?
your question isn't legitimate, there is a proscribed procedure for EPA approval of fuel system devices. There is no minimum pollution requirement, nor is it all that difficult to get a variance to the as built rule.
People install newer model engines in older pre-smog rules cars & trucks everyday.
as usual what's missing is any real substantive data about the "vaporizer"
Re: Vehical MPG
03/28/2011 7:28 AM
You don't seem to indicate the energy required to operate the vaporizer.
Re: Vehical MPG
03/28/2011 11:44 PM
The only Energy required to operate the vaporizer is low pressure air.It's all described in the posts I have made.
Gary T. Kirkland
Re: Vehical MPG
03/29/2011 12:57 AM
This is exactly the kind of non-answer that sets everyone off.
Good Answers: 130
Re: Vehicle MPG
03/29/2011 1:09 AM
Hey - What do you mean "everyone"
I'm quite relaxed [these days] reading how everyone else has thermodynamics totally backwards. I love the concept of getting more energy by burning it 'richer' and colder'.
Suppose you've noticed Das is back and concerned about reaching CO2 triple point inside a power station flu.
Re: Vehicle MPG
03/29/2011 2:24 AM
Makes me wonder if the conservatives had thermodynamics removed from the science books. Do they still teach about Heat Engines and the Carnot Cycle? Surely we have re-entered the dark ages.
Good Answers: 130
Re: Vehicle MPG
03/29/2011 3:19 AM
We entered the "media ages" about 1985 - and it has to 'peak' before it 'declines', like Satyricon
Until then it's a fair parable of Domini's values in this
And don't even start me on 'education'
Re: Vehical MPG
03/29/2011 8:38 AM
Re: Vehical MPG
04/14/2011 10:34 AM
this is the question of the millennium!
but I don't think that any of you gentleman's remember to note that most of the energy on the combustion is dissipated on eat, so as your bucks
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
Re: Vehical MPG
04/19/2011 12:34 AM
I presume that you mean "most of the energy on the combustion is dissipated on Heat, so as your bucks".But really in an atomized state of 14.7 parts of air to 1 part of fuel, only 10 % of the fuel is actually utilized.That's why in a "normally fueled" gasoline engine, the oil turns black, the spark plugs foul out, and the engine wears out much sooner than with natural gas or propane.With vaporized gasoline in a state of 100 parts of air to 1 part of fuel this would also not be the case, along with more than doubled fuel economy and much greater performance along with a lowered combustion temperature.But the college educated "experts" don't want to hear it.To them is patently false, along with my photo of a gasoline vaporizer, with the resulting vapor that would normally power an engine instead ignited, burning the same exact color pattern of butane, blue to yellow to orange.
Gary T. Kirkland
Good Answers: 114
Re: Vehical MPG
04/19/2011 1:57 AM
Back again eh?
you still haven't brought any data or science to the table?
the page you linked to is from 95, where you try to sell your book for $20
Re: Vehical MPG
04/19/2011 11:03 AM
Mr. Kirkland,
Your response makes no sense whatsoever, nor does it answer any of the questions or objections that have been addressed to you. Please respond substantively to the following or concede your utter lack of comprehension of basic thermodynamic principles:
You again refer to "atomized state".
1) Please respond to the repeated correction that the atomized fuel is, in fact, vaporized prior to combustion. How do you justify continuing to ignore this fact and referencing atomization as the cause of inefficiency?
You state that a stoichiometric air/fuel ratio results in only 10% of the fuel being "utilized".
2) Define specifically what you mean by 90% of the fuel not being "utilized". Not burned? 1st Law efficiency? 2nd Law?
3) Why, specifically, is this so? Nothing in the link you gave gives any explanation other than non-scientific mumbo-jumbo.
You state that a stoichiometric ratio results in fouled plugs and engine wear.
4) By what mechanism, specifically, does stoichiometric operation - according to you - cause plugs to foul?
5) How do you respond to the empirical evidence that all modern vehicles with closed-loop control of mixture consistently run for 10's of 1000's of miles, in all conditions, without fouled plugs?
6) By what mechanism, specifically, does stoichiometric operation - according to you - cause engine wear?
7) How do you respond to the empirical evidence that all modern vehicles with closed-loop control of mixture, if properly serviced, consistently run for 100's of 1000's of miles, in all conditions, without excessive engine wear?
You state that 100-1 ratios result in more than doubling fuel economy, more power, and a lower combustion temperature.
8) How do you respond to the loooong proven fact that 100-1 ratios will not sustain combustion at anything approaching engine operating speeds? Nothing you've referenced mentions stratified charges or other solutions. Where is your data that contradicts a century of science?
9) By what mechanism, specifically, does a 100-1 ratio - according to you - result in more than doubling fuel economy?
10) By what mechanism, specifically, does a 100-1 ratio - according to you - result in more power?
11) How do you respond to the fact, known for centuries, that the theoretical maximum efficiency is a function of combustion temperature and that the HIGHER the combustion temperature, the higher the efficiency? By what thermodynamic mechanism do you propose that lower combustion temperatures can increase efficiency?
Your phrase, "than with natural gas or propane" seems to imply that the benefits that you claim for 100-1 gasoline ratios are realized with these gaseous fuels.
12) Is this correct?
13) Can you provide data that NG or propane fueled engines produce substantially more power and/or use substantially less fuel than gasoline engines per unit heating value of their fuels?
You stated that a 100-1 mixture, "burn(s) the same exact color pattern of butane, blue to yellow to orange".
14) What is this supposed to prove? How does it prove it? Why do you reference this observation while ignoring all of the relevant matters?
And finally:
15) Why have you not, IN TEN YEARS, learned one iota of basic thermodynamics?
A failure to respond substantively to these questions is a defacto concession to everyone except diehard cranks.
Anonymous Poster #3
Re: Vehical MPG
04/19/2011 11:58 AM
I resent that accusation
Son of editor Crankshaft
Reply to Forum Thread 42 comments
34point5 (2); Anonymous Poster (2); Codemaster (5); electronick (1); Flee to Me reMote elF (1); Garthh (2); Gary T. Kirkland (5); K_Fry (5); kid73049 (1); KyleT (2); lyn (2); McTech (2); Popfar (1); rcapper (4); tcmtech (6); Tornado (1)
