Everyone is aware that electron movement under a magnetic flux follows Flemings left hand rule. Lot of literature is available on this. I have been exploring possibility of applying this to improve breakdown voltage in insulators. I did come across after lot of search that a paten was taken by Cheng et al Patent no 3.963,858 on 15 June 1976."High voltage electrical insulator adapted to prevent flashover".
- Around 1976 composite insulators were not available. Hence the patent speaks about embedding permanent magnets in ceramic insulators.
- Ceramic insulators are brittle and hence wall thicknesses are usually high.
- Hence the surface field strength of embedded magnets is low and hence the effect of magnetic field on deflection of electrons is also low.
- However in composite insulators, this concept can be easily applied - as it involves a process of injection molding of silicone around a fiberglass rod.
- Fiberglass discs with magnets embedded with a particular pattern / density can be made by magnet manufacturers.
- Magnet manufacturers are not composite manufacturers and composite manufacturers are shy of approaching magnet manufacturers- unless there is a strong market pressure to develop new products.
- For the same string length, break-over voltage can be increased or margin of safety could be improved.
- Is there any reason why such magnet embedded magnet composite insulators have not been developed?
