Previous in Forum: how to choose fiber optic   Next in Forum: Composite (Analog) cable: mechanical and electrical characteristics
Page 3 of 3: « First < Prev 1 2 3 Last »
How Light Regains its Velocity After Passing Through a Denser Medium?
05/09/2011 9:01 AM
Assume a beam of light is passing through a glass plate and emerges out to the air again.
Here the velocity of light before hitting the glass surface is same as that of once it has come out of the glass. But while it passes through the glass the velocity is less.
Now the question is how does the light beam gets acceleration to achieve its original speed once it gets out of the glass surface?
In reply to #63
Find in discussion
Re: How Light Regains its Velocity After Passing Through a Denser Medium?
05/14/2011 7:41 PM
We can' run out of theories because existence is change and infinite and has some billions of years head start on us.
For the comment directed at me the problem and gaps I was referring to is that not all that is called physics these days is based on theories derived from collection of data as at the beginning of scientific method. It is apparent that mathematicians particularly take off from a line of mathematical exposition in existing experimental proofs trying to reach forward and explain the holes or weirdness. That is certainly what Feynman did as well as Dirac. Of importance for Dirac especially was not the gaps but rather that in working with the math something felt beautiful and therefore must have been correct.
Of course things that felt "beautiful" did so because they tickled intuitive, but not necessarily immediately explicit, sense. Proofs waited on experiment.
But it is a mistake to assert that experimental proofs follow theory, as I believe was said above. Experimental acquisition of data is the historical basis of theory insofar as the scientific method itself derives from the very unscientific alchemists who sans theory collected data.
What you get today is a dialectical relationship wherein the main line, at least until Einstein, is developed out of data from experiment. At a certain point the math that delineates theory begins to generate intuitive lines of math which suggests certain yet unrealized aspects of reality.
I'm not a mathematician, which I regret, so the strongest proof for me of that point is not math but rather the Periodic Table where knowledge of certain elements and relationships pointed to other probable elements including some that have never existed in our time, that is until we made them, such as plutonium and 27 others or thereabouts, because we could see that they likely did exist or could exist.
If there is confusion as to the line of development in re the scientific method, and I think the comment above suggested that, it is because of the manner in which knowledge develops, i.e., in a series of dialectical progressions which, without going into the theory of dialectics can best be explained as being in the manner that Gould, the evolutionary biologist described the path of evolution, i.e., as punctuated equilibrium almost as though unthinking nature experienced intuitive leaps.
Reading Feynman and about Dirac and without understanding the detail of much of what they uncovered it is clear that they experienced intuitive or dialectical leaps because the math leading them felt good or "beautiful."
I don't know how much sense I am making because as usual for me I am looking at the line of development of thought that must accompany development of the practical science. But surely the Large Hadron Collider is a tremendous economic investment to discover what the math says must exist. But, I would say, if the math proves out in actual Higgs particles, reality being nothing more than a line of higher and higher energies going back to big bang, will only pose the next particle punctuation.
I see this as connected to the original question but since almost any question concerning the nature of light or its behavior inevitably veers into quantum uncertainties, and hence philosophy, but I will mark it off topic.
j.
#207
In reply to #63
Find in discussion
06/08/2011 12:24 PM
As regards Feynman's quote: The currently adopted explanation for quantum behavior cannot be understood. The reason is that it is wrong. The UT velocity of 8.935E+16 m/s fully explains why there is "spooky action at a distance" that is the bane of QM. I fail to see why anyone would not want to know all they could about a theory that is fully compatible with relativity and explains quantum behavior, as well. As was indicated earlier, just because what you have learned may be based on wrong assumptions, it doesn't mean that what you have learned from wrong sources will not be helpful in learning the details of the correct explanation. I would not, for instance, have been able to figure out the details of UT without understanding something about string theory, light, matter, energy, and relativity in their current forms.
Being peer reviewed requires you to have peers
The Engineer
Good Answers: 129
Find in discussion
05/13/2011 5:26 PM
Also, I once wrote a blog entry that touched on some of this stuff, if you're interested. You may come across things you don't understand in the post, but I try to give colloquial explanations along the way. At the very least it's an attempt at answering your question about particle/wave duality.
http://cr4.globalspec.com/blogentry/2237/Fermions-and-Bosons
In reply to #64
05/14/2011 8:18 PM
Roger,
I was reading through the blog you referenced and came up with this..
"There are thousands of people with ideas, some of which may be right, but if they can't express them as formulas that can be checked, those ideas aren't very helpful."
So which came first, the chicken or the egg, that is material reality or the idea and formula ostensibly reflecting material reality? My take is always that the formulas, when correct, are an abstract expression reflecting general reality, but not concrete reality itself. In saying that I am not unaware that in a certain sense abstraction is more concrete than reality insofar as it reflects all reality, i.e., universal reality.
Couldn't resist. I'll now read the two slit.
j.
Good Answers: 204
In reply to #60
Find in discussion
05/13/2011 8:03 PM
ga. concise.
Good Answers: 67
05/14/2011 5:07 AM
Lot of discussion already took place on the topic and off the topic. I am not an expert on light but in simple terms I want to explain "how does the light beam gets acceleration to achieve its original speed once it gets out of the glass surface" with following example:
Suppose I am going on a flat road in a car with a particular constant speed, say 100 km/h, keeping accelerator at constant position. Now suddenly on the road a uniform gradient of say 30 degrees came. Even though accelerator position is fixed, speed reduces because of more resistance from the gradient. After crossing the inclined road again flat road comes and car regains the same speed as earlier because resistance is over. I think the same analogy applies to light. Molecules of glass are offering resistance while light is passing through it, so speed is reduced. Experts pardon me, if wrong.
In reply to #72
05/14/2011 6:20 AM
I gave you a GA, and I'd add (as explained by others on this thread)--the "gradient" is due to energy from the light beam causing electrons to vibrate (or vibrate faster).
The Engineer
Good Answers: 129
In reply to #72
05/14/2011 9:41 AM
Here is why your analogy doesn't work.
In your system you are providing a constant force in that your foot on the accelerator produces a constant stream of gas into your engine which produces torque to constantly accelerate your car. If your car isn't constantly being accelerated, it would stop.
Light isn't being accelerated. Light moves at c because it has no mass. This is a very important point of relativity. So when Engineer Artist asks us "how does the speed of light change" they are asking a profound question.
The answer is it doesn't. What happens is the light interacts with the solid which produces light that interferes with the original light and produces the illusion of slower light. When the light is out of the material that interference stops.
Google Book Explanation
An Analogy Using Double Slit Interference
Here's something comparable that I think people have a better handle on. What if someone asked you "why does light split up after passing through a slit?". The answer is it doesn't. The light is there at the locations that appear dark, even though you can't see it, it is just interfering with itself. (see diagram below)
#208
In reply to #74
06/08/2011 12:28 PM
This is incorrect. If one photon at a time is send to the slits, the same interference pattern is seen, so this explanation cannot be correct.
Re: How Light Regains its Velosity After Passing Through a Denser Medium?
05/14/2011 4:51 PM
I'm not sure how accurate this is, but photons passing through non-vacuum medium would reflect off of or be deflected by the atoms of the medium, and thus travel in zigzag paths. Velocity along the zigzag paths would remain c, but aggregate motion in the "forward" direction would be slower. Upon emerging into vacuum, the velocity in the "forward" direction is still c.
In reply to #75
05/14/2011 5:10 PM
Problem with that model is that there's no reason why they (or the majority of them) should all come out parallel with the incoming ones.
Anonymous Poster #4
#86
05/16/2011 1:36 PM
I appreciate science to a certain level. But a good analogy for the ultimate value of science is this:
A guy buys a "cool" car to attract all the beautiful women. After driving around and finally getting one to get into the car, he immediately turns all his attention to the car, spending all his time trying to figure out how it works. Finally, the woman gets out of the car and leaves, and he doesn't even notice.
The Engineer
Good Answers: 129
#90
In reply to #86
05/16/2011 2:31 PM
Yes, because scientists never have wives and families. Good point.
05/18/2011 5:56 PM
Same thing happens with electricity, travels down a wire at velocity X and is emitted from an antenna, it speeds up and if it travels to space it reaches the 299,999Km/sec or so. Antenna lengths change 5% between sea level and space.
Sooooooooo.......my question is, how can they accurately measure the distance to the moon within mm's when the speed of RADAR or even LASERs is not constant?
The Engineer
Good Answers: 129
#153
05/19/2011 11:15 PM
RCE,
I'm willing to continue. But if you are made uncomfortable by Kramarat's comment we can do it privately by CR4 mail. Or we can stop. Let me know.
Roger
In reply to #153
05/19/2011 11:51 PM
As the two of you have probably deduced, despite my repeated claims to leave I still lurk in this thread. Before the two of you slip off into privacy mode there is a comment I wish to add in a much more sober state than I am now and with more rest. Work tomorrow will be a bear though so don't expect my comment until lunch time EDT.
#176
06/06/2011 12:33 PM
This question, as well as many others, can only be answered easily with Ultrawave theory. Light is composed of two waves, an electrically charged wave and a magnetically charged wave. One of the waves always travels at c and the other travels at a velocity approx. equal to 8.935E+16 m/s, both in two dimensions. When traveling through a medium, the orientation of the waves changes and the propagation through three dimensions is altered, either slowing down or speeding back up as conditions warrant.
The ultrawave view of matter and energy answers the question of how light (energy)and matter are interchangeable. It also explains how light can be slowed down with a laser beam, or even stopped and restarted. If you would like to know more, visit ultrawavetheory.org.
In reply to #176
06/06/2011 12:46 PM
Which one moves at 8.935+16?
In reply to #176
06/06/2011 1:45 PM
OK, I did a quick scan of your link on this concept of Ultrawave. This theory seems to be at least a branch if not an oblique tangent of string theory. (Please, gently correct me if I'm wrong.) To answer RCE's question, this theory states that the Ultrawave moves at 8.935E+16 m/s (u) while the observed other wave of the photon propogates at the velocity known as c. u>>>c This is an absurdly faster velocity than light. Light takes about nine hours to travel the the average diameter of Neptune (about 1E13m) while the Ultrawave can travel this in less than a millisecond. Without studying this proposal, it seems obvious that the Ultrawave does not travel in a straight spacial path. If it did then it would very quickly dissociate with the speed of light wave.
But this is not my real questions for you, but here they are:
  • What phenomena does Ultrawave theory predict to happen that the Standard Model theory predicts will not happen?
  • Can we observe this phenomena today with our technology? If we can observe this, have we observed this?
  • Has this proposed theory been peer reviewed?
In reply to #178
06/06/2011 2:42 PM
as an addendum, I would ask who peer reviewed it just for clarity?
Also, as he indicated that light is made of two wave components, electic field and magnetic field waves, and that one of the two waves move at 8.935E+16. Which one moves at that speed? which was leading toward the dissociation of the wave comment, once he explained soemthing more.
#195
In reply to #178
06/07/2011 12:46 PM
Yes indeed the ultrawave travels at a much faster rate and in a sprialing path, which follows the c velocity to create either a torus (particle) or tube (photon or neutrino); you'll have to read more to get the details.
As far as evidence goes, it is circumstantial at present. The way that galaxies show evidence of invisible matter content (exotic dark matter) in the way that they rotate and hold together is easily explained with ultrawaves; again, you need to read more of the book.
One of the responders (sorry I forgot to check) got it right when he said that the electric versus magnetic portions was what caused the observed displacement, but he was also wrong that it takes a tortuous path, it must travel linearly even to the point of reflection.
How can you have a peer review of something that no one knows anything about? You have to try to understand a subject before you can comment about it. Unfortunately, no one else has bothered to do this other than a few amatuers.
06/06/2011 3:37 PM
Light is considered to have dual character, as particles when considering photonics, and as an electromagnetic wave when studying phenomena such as refraction, reflection, and diffraction, and "interference" effects. The frequency of such waves is a constant (regardless of the medium), as is the energy of a photon of light. Since light slows down in a dense medium such as water, glass, etc., the wavelength actually decreases, while the frequency is constant. Once light exits the medium back into air or "vacuum", the wavelength reverts to its original. Maxwell's equations reveal the out of phase nature of the electric field and the magnetic field, and the progagation of the wave depends on the permeability of the medium. The slowing of light waves in a medium are responsible also for the phenomena of refraction (lens, prisms, etc.), as well as dispersion of the spectrum (due to changes of the refractive index with respect to various wavelengths).
In reply to #180
06/06/2011 5:59 PM
Your synopsis is what I recall. As the frequency remains constant, there is no red or blue shift
#205
In reply to #180
06/08/2011 11:06 AM
Quote: ".. since light slows down in a dense medium"
Where can I find experiments which show that light slows down in dense media James? All I can find are experiments in which light appears to slow down. I think there may be some simple omissions of some experimental parameters. We can reduce the frequency of radiation, or limit its penetration in dense media until it is completely absorbed, but we cannot "slow it down". We can make it go around corners and reflect it, thereby increasing the effective distance it travels, and the time it takes to get from A to B, but light is not going any slower than before. Light is stripped of energy and maintain only the longer wavelengths, but it is still not going any slower!
I would love to see some experiments (to prove Albert wrong about C at last!)
Slow light, it ain't light. The opposite is also true ..
In reply to #205
06/08/2011 12:31 PM
I don't know where you would find an experiment concerning light, but it is a common factor in radio communications.
My understanding is the frequency remains constant but the wavelength changes. If the frequency changed, the colors would also change.
#211
In reply to #209
06/08/2011 8:34 PM
I understand that if the frequency remains the same, so does the speed. Only the wavelenghts are changed , or stripped?
In reply to #211
06/09/2011 8:53 AM
NO. The wavelength becomes shortened, meaning in one period the wave travels a shorter distance, hence the speed in the medium is less. I refer you to Maxwell's equations for the progagation of radiation.
#213
In reply to #212
06/09/2011 10:00 PM
I have a problem with "slow light" and "decelerating and re-accelerating light" when there is no experimental evidence to conclusively prove it. Mathematics can be adapted to fit: mathematics is a language with a lot of shortcuts and it would not be the first or last time. There are many who would argue this to death, like if their god, or flag had been offended, but I am not interested in the argument for its own sake, just the exploration. Below are some observations.
The dual wave-particle description of light stems from relative observations, but this theory is still debated because of the paradoxes which it created. I would prefer a singular and general description of light, even though I understand the evident present difficulty and limitations of languages.
Anything energetic must imply an electrical potential, and this potential is dualistic by nature: how can duality be described without qualifying the state of the observer? If we must include the observer, and we must do so to have an observation, we must then describe its relationship to the observed; this instantly creates infinite probabilities because of infinite possible viewpoints; an expanding universe of probabilities, much like the observable physical universe. This gets us straight into metaphysics; trying to avoid it we use mathematics and end up in mental electrical-dualistic creation of infinite potentials; and around and around we go again.
This exercise points perhaps to a law of expansion for all which is observable (physical and non-physical); and unfortunately, or otherwise, we are back into the previous trap, just looking at vastly different details, a different universe still governed by the same trinitarian "law".
Sounding too religious? No problem: label it all differently, use another language and terminology, look from a different time-space coordinate and all will be well, for a short while.
I guess that these questions on light can remain open while the experimental data is incomplete, which may well be forever, given the probabilities. Lets just enjoy it anyway ..
In reply to #213
06/10/2011 2:24 AM
Why can't there be two models that explain a paradoxical phenomena. Bohr knew that the atom could not contain electrons in orbit around the nucleus. Yet this simplified model explained many things about the atom that it is still taught in public school. Do you really think that the Bohr atom structure should not be taught and the only atomic model taught should be Schroedinger's wave equation of the probability of an electron around the nucleus? The dual properties of light does seem to be a paradox to many but they are both just models of how light works. Who knows, there may already be an elegant single model for light that explains how light can both act as a particle and a wave. It could just be such a complicated model that until you've mastered a very esoteric mathematical skill set the simpler dual model must suffice.
#216
In reply to #215
06/10/2011 2:53 AM
I agree, provided it is understood (as you, I and many others do) that a model is not gospel, and that this fact is made clear even in public schools. With the popularization of science there have been many theories and hypothesis made to look as absolute truths, promptly altered or debunked by the next great idea. Dogmatic assertions should have no place in science and the education of free, but susceptible minds. Science would be better off never understating the fragility of its knowledge, rather than assume that untrained others are incapable of understanding anyway.
#210
In reply to #205
06/08/2011 12:36 PM
There was an article where light had been slowed down to a rediculously slow speed of twenty some meters per second in a material or gas using lasers. You may find it if you search for slowing light with lasers. I haven't checked myself.
Hobbies - Fishing -
In reply to #210
06/09/2011 10:16 PM
Bose-Einstein condensate. Seems to me light never slowed down, it only had a very long, convoluted bath to get from a to b. So it took longer.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Anonymous Poster #5
#183
06/06/2011 7:14 PM
The short answer is refraction, light will travel in a straight line until matter that is solid or less denser such that of glass. The light as passes through the glass the speed does not change but will travel a longer distance due its refractory as oppose to straight-line distance.
In reply to #183
06/06/2011 7:44 PM
or until it passes near a local masive body such that the gravity well bends the light path.
In reply to #183
06/10/2011 8:36 AM
According to the fiber optic folks, you are correct. They use a refractive index of approx 1.5 for a velocity of approx 200,000 KM/S
#186
06/06/2011 9:51 PM
Light is light and to be so it always retains constant speed, because it is its nature, or it just would not be in the state we call "light"; a simile would be the difference between milk and cheese (lol), or helium and gold. When light travels through a theoretical vacuum it makes no adjustments to its trajectory (it does not take detours around the magnetic fields which bend its path). The denser the medium, the stronger and more tightly packed the fields, the more detours. The farther the distance through this mass of fields, the greater the energy is dissipated as heat. This is why lights bends within a lens (refraction). In conclusion: light does not slow down and then accelerates: it simply goes around more bends and it gets from A to B slower than if it had been travelling in a straight line. We just did not notice the path's complexity. The common description of "light slows down in a medium denser than vacuum" is deceiving and was probably originally coined as a metaphor.
#190
06/07/2011 4:00 AM
The mathematics or the physical picture?
Ok, spare the math for a while. If you think of the dense medium as sand and the light beam as marbles, it does not make sense. If you think of the medium as a hill and plateu, then the marbles go up the hill, lose speed, but gain potential energy, travel at (lower) constant speed in the plateu, and then travel downhill to gain their initial speed. The energy (of the photon-marble) is always the same. But you must change your perception of solid matter and geometric dimensions.
aegeannavigator@hotmail.com
In reply to #190
06/07/2011 3:53 PM
To understand matter you must understand light, and the converse is true. Why impose primitive models for nature, when ultimately sophisticated models that accurately and precisely describe nature are already in place?
#206
In reply to #197
06/08/2011 12:08 PM
What you call "sophisticated models" I call "overcomplicated models". The physical models based on UT more accurately and more precisely describe nature.
In reply to #206
06/10/2011 1:58 PM
Someone has obviously sold you a bill of goods. Sorry for that to be the case. Go read some physics, if you can read.
In reply to #218
06/10/2011 9:18 PM
Mr. Stewart:
Here are two places to you may look.
www.transition.com/transitionnetworks/resources/en/PDF/fiber_wp.pdf
www.madsci.org/posts/archives/2001-02/983369337.ph.r.html
If you do a search for "velocity of light in fiber optic cable" you can find more.
But they say the phenomena is the result of refraction.
In the communications field we use a piece of equipment called a TDR used to be HP, now Agilent. One of the settings deals with velocity factor in the media you are testing. They come in several flavors, Optics and conductor. You must enter the velocity factor as provided by the manufacturer to get valid readings.
I realize you are in Lubbock, did you ever work in Coral Gables or Chicago suburbs? With your attitude, you would be a perfect fit.
#241
In reply to #218
06/15/2011 12:38 PM
Typical response from someone who does not know anything about the subject matter. Ultrawave theory can make sense of any aspect of nature I have attempted to explain. It can even account for the NASA tech brief concerning "optical batteries". I have no more time to devote to this thread, so don't bother to reply. If anyone wants to learn a simpler and more logical way of looking at the universe then I recommend they look at UT rather than the Standard Model.
Anonymous Poster #6
#242
In reply to #241
06/15/2011 12:51 PM
Typical response from a narcissist
as if you are the only one reading or participating in this discussion
Good Answers: 130
#220
06/10/2011 9:32 PM
Just an observation 200 odd post on;
If you disregard how light got into the 'denser medium' and the whole traveling through part - and just ask 'at what speed does light radiate from any emitting surface?" (into air or vacuum) - the answer is rather self evident.
06/11/2011 1:38 PM
Light remains a paradox. Ripples on a pond, sounds through a media and light...? are manifestations of the harmonic movement of tiny particles. IMHO if something has zero mass it doesn't exist. So matter is also a paradox.
Bobguz
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
In reply to #224
06/11/2011 2:21 PM
Your theory, thoughts, words, and attitude have no mass. Therefore they do not exist. Since your thoughts do not exist, you do not think. Now taking the obverse of René Descartes famous quote "Cogito ergo sum" this then means that you do not exist. Since you do not exist, you have no mass. Congratulations, you've just achieved the Weight Watchers record of complete weight loss.
In reply to #225
06/11/2011 2:38 PM
Smug, arrogant and ignorant describe most science in most ages. Bobguz
#233
In reply to #224
06/14/2011 12:38 AM
I like the idea of resonance as it may be applied to light. I suspect that resonance could help to describe why light appears to slow down as it transverses a medium denser than vacuum, and why the trajectory changes when it enters the medium at an angle different to 90° and why there is a change in wavelength depending on the medium elements composition.
In fibre optics the refractive index of 1.5 is inversely proportional to the estimated speed (200.000 m/s through glass cable?), with some wavelength change (color) from origin, hence the need for medium purity. The light travels through the cable at a constant speed; if it was "slowing down" the speed would gradually decrease; this does not happen. Provided the energy is not completely absorbed the light travels at a constant speed caracteristic to that medium (all elements have a caracteristic wavelength) .
The wavelength changes could be called immediate upon entry into the medium and scatter and absorption dependent on impurities and molecular geometry (reflection). Does the wavelength change? Resonance could explain how this could happen. Or should we say that some wavelengths are absorbed and others pass through because the orbits are wider or smaller that the element's atomic field? I propose that the "orbit" of the wave (I see the energy propagating as an helix, multiple helices in a variety of wavelengths,) becomes captured by same size "orbits", while others are unaffected and pass through the medium. Impurities in the medium would imply other elements (different atomic structure) which would absorb other "orbits", because they are present in its structure. In my mind we should also consider how gravity fits into this, but I don't want to go that way here.
"At the microscale, an electromagnetic wave's phase speed is slowed in a material because the electric field creates a disturbance in the charges of each atom (primarily the electrons) proportional to the permittivity of the medium."
I can see nothing wrong with the above and we don't need another esoteric model to explain it, just some experiments to get rid of the "light slows down" expression which seems to be so stuck in so many statements from this discussion and media science reportage.
When I first posted the comment below, I had two "Off topic" marks; they seem to have now disappeared (#184). I would abolish the off topic system, as it is rife with missuse and it does not add anything to the debate: to declare any statement off topic, members should provide their explanation.
"Light is light and to be so it always retains constant speed, because it is its nature, or it just would not be in the state we call "light"; a simile would be the difference between milk and cheese (LOL), or helium and gold. When light travels through a theoretical vacuum it makes no adjustments to its trajectory (it takes no detours around the magnetic fields which bend its path). The denser the medium, the stronger and more tightly packed the fields, the more detours. The farther the distance through this mass of fields, the greater the energy is dissipated as heat. This is why lights bends within a lens (refraction). In conclusion: light does not slow down and then accelerates: it simply goes around more bends and it gets from A to B slower than if it had been travelling in a straight line. We just did not notice the path's complexity. The common description of "light slows down in a medium denser than vacuum" is deceiving and was probably originally coined as a metaphor."
Although the above uses pretty simple metaphors, I still believe it describes what happens without complicated and exclusive terminology, or maths. Given that this discussion include participants from a number of disciplines and just interested individuals, I see as a fair deal containing the maths to an absolute minimum, or at least translating it into something like diagrams for everyone to see with an opportunity to understand.
In reply to #233
06/14/2011 3:06 AM
200,000 km/s through glass cable
#235
In reply to #234
06/14/2011 4:46 AM
sorry ..
thanks John
In reply to #233
06/14/2011 8:14 AM
Re: (it takes no detours around the magnetic fields which bend its path)
The first time you posted that I pisted to ask if the "no detours" was a typo, and you said yes (iirc)--you haven't changed your mind, have you? (I don't expect that you have--I just think you ought to correct it here, also ;-)
#239
In reply to #236
06/15/2011 6:28 AM
It should read: "it takes detours" I haven't changed my mind it is still taking detours.
In reply to #239
06/15/2011 8:35 AM
Thanks!
I guess the explanation that resonates most with me at the moment is the one that talks about some of the energy from the light beam increasing the energy of the electrons in the material as light goes in, and then being restored to the light beam as it leaves the material. But, I'm not sure. And, there doesn't seem to be a clear consensus in this thread (or one definite convincing right answer)--of course, I may not know enough to recognize the one right answer if it is presented to me.
And, as I think someone else suggested in this thread, there could be more than one answer, e.g., one answer for light as a wave and one answer for light as a particle ;-)
#250
In reply to #240
06/16/2011 4:55 AM
I considered the dual aspect of light for awhile, but, like many others, I have come to being dissatisfied with it's description. I have been looking for ways in which I can dismiss the hypothesis of photons being diverted from a straight path in dense media (relative to a vacuum trajectory, therefore increasing distance), but I cannot come up with any experiment that proves otherwise, and instead, every experiment seems to support the idea, provided we get rid of the preconception of light actually slowing down and we replace it with "appears to slow down". I realise that if we measure a piece of optic fibre and time the travel of light through it, the time increases compared to its travel in a vacuum. I only have a problem with the "light slows down, then accelerates", because slow light does not exists as light, react as light, illuminate as light! We already know that light can bend around gravitational fields, geometry should then suffice for the explanation of distance/time.
"some of the energy from some of the energy from the light beam increasing the energy of the electrons in the material as light goes in, and then being restored to the light beam as it leaves the material as light goes in, and then being restored to the light beam as it leaves the material"
Your above it's probably a more attractive proposition, but maybe the less elegant idea is all we need for an explanation.There is no evidence that light somehow regains any of the energy lost though the medium: whether the loss was towards ultraviolet, or infrared. What is left over is what could pass through, the rest is gone into the medium. "some of the energy from the light beam increasing the energy of the electrons in the material" as you pointed out (you are half right). This is particularly clear in light-induced chemical reactions and in the practical optical applications.
We are almost back to the questions of: "what is energy?" Is it simply matter accelerated to C, and the inverse also true? It is certainly implied in Einstein's famous formula and evident in nuclear fission! But is it? The dual nature pops up again because of these questions. What actually happens in black holes? I think that the answer is the same: speed of light the same, larger scale. Is there a mini-black hole in every atom? How big is "mini"? It is calculable, that's how big, but not visible (of course; it's a black hole!).
Our sensory apparatus, and even the most sophisticated test equipment, is composed of larger particles than what we are trying to measure, so we have to choose how we interpret data, and use our imagination to see which possible (not just probable) parameter has been left out, as we CANNOT include them ALL.
I am quite happy for anyone to show me were I may be missing something, and I appreciate any comment.
Maths translations can be made later; ideas is where it all begins.
In reply to #250
06/16/2011 9:26 AM
Thanks for your response! I have no comment (at least, at this time--partly because I need to do some other things).
Good Answers: 130
#252
In reply to #250
06/16/2011 9:41 AM
So how fast is the light going into the tungsten filament, given it comes out at the speed of light?
In reply to #252
06/16/2011 3:15 PM
"So how fast is the light going into the tungsten filament"
I would say it is going at the speed of light going into it. As for how fast it is going while inside the filament that is the debate here.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
In reply to #255
06/16/2011 5:05 PM
I don't think there is any light going into the filament. When you burn a candle and light starts getting emitted, did light enter the candle (or wick, or wax, or even the incandescent gases)?
Anonymous Poster #7
#260
In reply to #258
06/16/2011 5:18 PM
I reckon the electrons whizzing along the wire warmed it up enough to squeeze the phlogiston out. Don't know how it got there in the first place.
In reply to #260
06/16/2011 5:25 PM
Ahh, ok--I forgot about the phlogistons.
In reply to #261
06/16/2011 5:57 PM
Can you still get them at Amazon? As for light bulbs giving off phlogistons, I recall at least one beer inspired discussion "proving" that light bulbs did not give off light, but ingested dark. The proof was the lamps would turn black when they were full of dark.
In reply to #263
06/16/2011 6:45 PM
LOL
Anonymous Poster #7
#266
In reply to #261
06/16/2011 7:12 PM
Hmm. I didn't realize that phlogiston is quantized. But then, I guess 'most everything else is, so I shouldn't really be surprised.
You live and learn.
In reply to #266
06/16/2011 9:11 PM
Ok, so now I had to look up phlogiston theory on Wikipedia. I remember that now, but didn't (and don't) remember the word phlogiston.
A little bit interesting to think about (for me) in the context of some of the comments I've seen recently on evolution theory. We didn't throw out the scientific method when we through out phlogiston theory.
In reply to #260
06/16/2011 5:57 PM
In theory, some form of energy raises the electrons into a higher quantum state, when they collapse back they release light.
Good Answers: 130
#269
In reply to #255
06/16/2011 9:25 PM
"that is the debate here"
And strangely, it is. Whereas the question is clearly; "How Light Regains its Velocity After Passing Through Guinea Pigs"
#268
In reply to #252
06/16/2011 9:19 PM
I do not understand your point, can you please clarify?
Good Answers: 130
#270
In reply to #268
06/16/2011 9:44 PM
You said you wanted to deal in "concepts" so I gave you one. Think of it this way; take 1 excited atom emitting photons - how do the photons know which way is 'out', so go 'faster', as opposed to which way is 'not out', so go slower?
Or is there something about 'not out' that means they take longer?
#271
In reply to #270
06/16/2011 10:24 PM
I think photons are emitted in all directions permitted by the molecular structure of the medium. The escaping photons, the ones which are generated on the surface, or reach the surface, radiate within the restrictions of the molecular structure of air/vacuum, or whatever.
In reply to #233
06/15/2011 3:33 AM
I thought the speed was 200,000 Km/s or 200,000,000 m/s in fiber cable.
#238
In reply to #237
06/15/2011 6:24 AM
You are correct. My error.
Register to Reply Page 3 of 3: « First < Prev 1 2 3 Last »
34point5 (5); a2x=z (1); AegeanNavigator (1); Anonymous Poster (9); Bayes (48); bobguz (2); borazipion (2); chrisg288 (3); cuba_pete (1); davidmac (8); Dr Tom (2); Engineer Artist (5); fhfarooqui (1); Fredski (5); Garthh (1); gsuhas (1); Jack Jersawitz (6); James Stewart (7); Johannescnc (1); JohnDG (6); johnfotl (5); jt (1); JWthetech (8); kay williams (2); kramarat (5); Lab Rat (1); leveles (2); lighthasmass (1); lyn (2); MRH620 (1); PaulS (16); pritam (1); rbixby (5); RCE (43); redfred (29); rhkramer (23); SWB123 (3); thall (1); Tornado (6); Usbport (1)
