Previous in Forum: Bakal Pressbrake Problem   Next in Forum: Class II Hazardous Area Classification
Refresh My Knowledge - Wiring Diagram
05/17/2011 8:50 AM
Dear folks,
was looking for a Wiring diagram for a 3/4 HP, 3 phase exhaust fan on American Roof.
Timer is delay start. This wiring diagram has to incorporate an Electromagnetic Timer by TORK or equivalent.
Also I still find that I have to register again to answer a question. Please correct me. I appreciate the picture sent to me but it also requires to register again on my own question. I just wanted to clarify a counter question-- answer that question to get the wiring diagram.
Please help quickly.
Thanks
Re: Refresh My Knowledge - Wiring Diagram
05/17/2011 9:21 AM
Why start a new thread when this one's Wiring Diagram of an Exhaust Fan still working? Just answer the questions there.
05/17/2011 9:48 AM
Quite.
05/17/2011 9:49 AM
If there has been little to no response to the original posting, it may be that no reader is able to help. Re-posting won't change that.
Good Answers: 266
05/17/2011 5:09 PM
If you did not log in. You will get that message to register
05/17/2011 11:49 PM
In your control circuit, assuming the timer is an octal socket relay:
L1 of supply to Off-On switch; other terminal of switch to terminal 7 on socket, and jumper to terminal 8 (common).
Terminal 6 (NOTC) to motor starter coil; other terminal of coil may already be wired to overload relay; other terminal of overload to terminal 2 on socket, and then on to L2 of supply.
There may be variations from this, but it is a very common setup. The relay coil and motor starter coil voltage must match the supply voltage.
But why does there need to be a delay on start?
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
05/18/2011 8:10 AM
maybe the oil should be pumped to all mechanical moving parts before it starts rotating
Canada - Member - New Member
05/18/2011 10:30 AM
Here is a link to a Tork timer wiring layout.
The reason for the timer is likely to cycle the exhaust fan at different times of the day.
http://www.nsiindustries.com/Repository/Files/WSerINSTALLOP.pdf
Elroy
Knowledge makes what was impossible, seem easy.
Register to Reply 7 comments
Elroy (1); hithuanand (1); lyn (1); ozzb (1); PWSlack (2); Tornado (1)
