Previous in Forum: Why Riding A Bicycle Requires Less Energy Than Going Afoot?   Next in Forum: Non-Invasive True BP Measurement?
9 comments
Active Carbon for Aquatic Use
05/29/2011 2:22 PM
Can I put ground barbecue carbon instead of active carbon into my aquarium?
Any major difference for water treatment?
Thanks
Re: Active carbon for aquatic use
05/29/2011 3:27 PM
How much did your fish cost?
I'd go to a pet care forum and ask them.
05/29/2011 7:13 PM
Perhaps pure hardwood charcoal, but definitely not the processed briquettes. They contain some chemicals that might be harmful to fish. I wouldn't take the risk.
Re: Active Carbon for Aquatic Use
05/29/2011 10:33 PM
If the briquets have lighter fluid built in, will the neon tetras glow brighter?
Good Answers: 203
05/29/2011 10:52 PM
NO! Charcoal contains many contaminates. Charcoal is produced by the pyrolysis (heating with a lack of oxygen) of wood usually hardwoods but sometimes any type of wood. It drives off the moisture content of the wood and the water within the wood cells.
Wood can contain contaminants incurred during its growth and handling during and after cutting. It can also contain substances from its processing.
Charcoal briquettes intentionally contain other than pyrolysis wood. They usually contain low-grade coal, wax, saw dust, starch binders, miscellaneous chemicals and usually no charcoal.
Activated carbon such as that used for aquarium filters and water treatment is an entirely different material. The only direct similarity is that they both have the same base element, Carbon.
Personally, I wouldn't attempt this substitution unless I wanted to get rid of the fish.
Good Luck, Old Salt
Good Answers: 117
05/29/2011 11:24 PM
try this little experiment.... run tap water over BBQ charcoal.. note the colour of the water!
Then ask yourself this question.... "would I want to swim in this"?
Charcoal is carbon. Activated charcoal is charcoal that has been treated with oxygen to open up millions of tiny pores between the carbon atoms. According to Encylopedia Britannica:
The use of special manufacturing techniques results in highly porous charcoals that have surface areas of 300-2,000 square metres per gram. These so-called active, or activated, charcoals are widely used to adsorb odorous or coloured substances from gases or liquids.
The word adsorb is important here. When a material adsorbs something, it attaches to it by chemical attraction. The huge surface area of activated charcoal gives it countless bonding sites. When certain chemicals pass next to the carbon surface, they attach to the surface and are trapped.
Activated charcoal is good at trapping other carbon-based impurities ("organic" chemicals), as well as things like chlorine. Many other chemicals are not attracted to carbon at all -- sodium, nitrates, etc. -- so they pass right through. This means that an activated charcoal filter will remove certain impurities while ignoring others. It also means that, once all of the bonding sites are filled, an activated charcoal filter stops working. At that point you must replace the filter.
BBQ charcoal, is pressed into shape after the addition of other chemicals to make it burn brighter and produce more heat and it's NOT treated with oxygen, it's deprived of oxygen during the basic part of the manufacturing process.
Good Answers: 11
05/30/2011 6:38 AM
I am assuming your are trying to mitigate the pricey A-Carbon filters rather than building a barbecuarium for your fish, since you didn't mention throwing some T-Bone steaks in there and filling it with cold Budweiser.
Zeolite it pretty cheap, and the type mined in the US is good at removing ammonia and other contaminants from water. It has a very high surface area for adsorption, but not as high as A-Carbon. You might want to use it as a prefilter before the carbon filter as this will give you a much longer life on the carbon. Also, the zeolite can be re-used, I believe, as it does not require being recharged like carbon filters. But it's so cheap, why bother. I understand from a friend involved in the N-disaster in Japan that they are pumping the stuff into the flooded reactors to trap a lot of the radiated nasties from the million or so gallons of water sitting aglow.
Also, you might consider a small UV light filter which is a simple DIY project. LED's area available for this purpose...mind the shielding so as not to expose the little fishes or their owner to UV radiation or they could go blind and not be able to find the charcoal lighter or the cooler.
Out of curiosity are you in the Kentucky neck of the woods? Good luck little fishies.
05/30/2011 10:17 AM
Would UV light filter destroy useful bacterial, such as nitrifying and photosynthetic bacteria as well?
Good Answers: 11
05/30/2011 12:58 PM
Of course they would be destroyed, if they were subjected to the proper UV light source for sufficient time. But the colonies which are existing in areas that are not subject to a UV source would still be alive and there would still be the benefit of these colonies in the nitrogen process. If your filtration system is doing a good job of filtering out the nitrogen from waste, uneaten food etc. then the number of beneficial microbes decreases.
It's about maintaining a balance so an algae bloom is avoided which will turn any aquaculture toxic. This is true for in-home systems as well as mother-nature systems like Diamond Lake here in Oregon. This otherwise pristine lake was overrun with the tui chub that feasted on the beneficial algae leaving the blue-green algae to bloom, creating a dead lake.
05/30/2011 2:16 PM
All good points from Oregoon.
I just went through the process of starting a new aquarium (nothing extraordinary, just a little 10 gallon unit), so let me share some of what I have learned... and maybe save someone the frustration I went through.
Charcoal filters are unnecessary in a healthy tank. Only a basic particle filter is required, and it need not be changed regularly, only rinsed-out when it gets clogged. Even then, it should be rinsed in treated/conditioned water. If the filter must be replaced, let it float in the aquarium for a day to allow the bacteria time to inhabit the new filter.
If you do desire a charcoal filter, activated charcoal is pretty cheap when purchased in bulk. I paid about $10 for a pound -- and that was at a pet store.
Register to Reply 9 comments
brich (1); lyn (1); old salt (1); Oregoon (2); pantaz (1); Tornado (1); Usbport (1); youngken (1)
