Previous in Forum: Windows7   Next in Forum: IE9 Fail!
12 comments
Simulink C5505 ECG
05/30/2011 1:46 AM
hi,
I have C5505 EVM, and I am doing ECG implementation on it. So far I have successfully got the results of ECGs. Now I am trying to interface the Kit with the Matlab/Simulink. i achieved signals Simulink using Instrument Toolbox in simulink but the output is all noisy. i also have to differentiate between ecg leads signals for further analysis. Please if anyone can advice me on this...
Talha.
Re: Simulink C5505 ECG
05/30/2011 1:54 AM
Just make sure your EKG doesn't go all haywire from consumption of any MethLab products....
05/30/2011 2:24 AM
hi tornado,
please if you have any real advices for me... it would be great help. i am really stuck here...
05/30/2011 2:37 AM
I apologize for being cavalier, but the unexplained acronyms and jargon in the OP left little choice.
05/30/2011 3:39 AM
ok ok...i explain to you...
i have C5505 DSP kit from Texas Instruments. I have achieved the ECG on it through C codes. Now i am trying to view the signals on Matlab or Simulink for further analysis and tests. i am now interfaced with the Simulink. But i am not getting the desired results...
So i am open to any suggestions...
05/30/2011 10:54 AM
So define:
  • EVM (Electronic Volt Meter?)?
  • ECG ???
05/30/2011 12:13 PM
ok ok so i am bad at acronyms...
its EVM= Evaluation Module( its a DSP kit from Texas Instruments.)
ECG = Electrocardiography
Now as you can see now i have to interface the EVM with Simulink.... Now ECG has 9 channels so i have recognise each one of them...
05/30/2011 8:04 PM
The answer is simple - contact the Simulink vendor and/or Texas Instruments! That is what they are there for.
05/30/2011 10:47 PM
hi,
yes you are right... i fact i have contacted both of them but the nothing has worked out for me so far. i am looking for help in serial communication in simulink cause my DSP is connected through RS232 port...
06/01/2011 10:29 PM
As for the request or requirement... I am redefining my problem...
So here it goes...
I got the good signals of ECG, on my PC with the PC application supplied by the TI. Now how can i interface the kit with the Matlab/Simulink??? I have tried different toolboxes of simulink but in vain. Also i tried to use Instrument Toolbox's Serial Recieve but every thing jumbled up or whenever i see the output on scope they are all having high amplitude... In a word i don't know how to interface the kit or recieve the serial data on simulink....
Please advice me on this...
06/01/2011 10:40 PM
So after rethinking, i am stating my problem again...
So here it goes...
I got the good results of ECG on my PC with the help of PC application as supplied by the TI. Now as to interface the kit with Matlab/Simulink through serial port, i am facing problem. In plain text, i dont know how to do it. i have tried the Instrument Toolbox's Serial Receive block but in vain. When ever i see the output in scope its not the desired value. So i am stuck here badly...
Please advice...
06/02/2011 1:05 AM
Hi talhak,
There is a lot of mainstream engineering advice here. However, there may not be many who use the specific combination of tools you are using.
I would try to find a forum specifically for Matlab/Simulink.
I found a few:
http://www.matlabtutorials.com/mathforum/index.php
http://www.eng-tips.com/threadminder.cfm?pid=576
http://www.mathworks.com/matlabcentral/
06/02/2011 11:52 PM
Thanks Mikerho,
i have already pasted my posts there. but is there a forum which is a bit more regular cause i am cant proceed with out some help in this front...
Regards...
Register to Reply 12 comments
Mikerho (2); rhkramer (1); talhak (7); Tornado (2)
