Previous in Forum: Phosphate Hide Out   Next in Forum: How to Make a Safe Herb Garden Within Creosote Planter Box
51 comments
Can Fiber Glass Resin Bond to Wood Fiber?
06/12/2011 4:30 PM
I want to build a simple aquarium (about 2.4mx2.4m in area) to grow cheap fish.
I decide to use plywood with some steel brackets to assemble this box as structural element.
And then I will apply weather sealant at all joints / gaps to avoid major leakage.
If plywood contacts with water all the time, I believe it will create a high moisture content to plywood and may cause seepage later.
I don't want to use waterproofing paint because it may be harmful to fishes.
If I apply glass fiber resin on plywood without glass fiber net, it will be very simple.
Anyone knows the resin can bond to plywood or not?
Thanks
Re: Can fiber glass resin bond to wood fiber?
06/12/2011 5:01 PM
Yes, it will bond to wood quite well.
06/12/2011 5:22 PM
I assume you're going to use marine ply.
I'd recommend using some glass matting with the resin - it will add a lot to the structural strength, particularly along the joins.
Probably a good idea to apply a coat or two of resin on the outside (including the underside) - the environment will almost certainly be very humid, and all you can do to to protect the wood will be well repaid.
06/13/2011 7:52 AM
If its to be all wood, marine ply is the best as it resists being boiled without de-laminating for at least 24 hours if I remember correctly. I do believe its a resin that bonds the plys together in the first place.
A good design that will resist the pressure of the water is VERY important. It should not need any nasty chemicals to seal if made correctly, but fill it with water and let any surface chemicals leech out for some weeks before using it for fish.....underwater plants may enhance the process. Read up on the web before starting......
06/12/2011 5:45 PM
Don't use any kind of wood for the walls. Use plastic, metal or glass.
Seal it with aquarium sealer.
No wood!
If you use wood, the "resin" will bond, but the fish will die.
Good Answers: 145
Re: Can Fiber Glass Resin Bond to Wood Fiber?
06/12/2011 9:18 PM
Might I suggest you use fibreglass bathtubs. It will save you some fabrication.
They're cheap second hand hand, and being fibreglass easy to add plumbing to for filtration etc..
Like Lyn says, don't have bare timber as your tank walls, the timber treatment will kill the fish...
06/12/2011 9:31 PM
Glass fibre resin also leaches chemicals in to the water, this will not improve the health of the fish.
06/12/2011 9:43 PM
"Fiber glass resin" is actually polyester resin, cured with methyl ethly ketone peroxide.
There is no fiber, or glass in the resin.
06/13/2011 6:29 AM
Glass fibre resin is just a common way of reffering to polyester resin.
It can be used with epoxy resin and various other resins.
In this case epoxy resin or glue would do a better job than polyester resin.
06/13/2011 9:29 AM
Common, perhaps. Incorrect, none the less.
06/13/2011 8:44 PM
Only in your understanding.
06/14/2011 10:31 AM
Yes, language does have a way of evolving, I guess.
Good Answers: 44
06/15/2011 12:29 PM
Not all polyester is glass fibre resin, but all glass fibre resin is polyester. N'est ce pas?
Good Answers: 110
06/15/2011 12:55 PM
Non. Ce n'est pas vrai.
Epoxy, vinylester and polyester are all common glass fibre (fiberglass in the US) resins.
Think big. Drive small.
Good Answers: 44
06/15/2011 1:01 PM
Merci
06/15/2011 3:27 PM
Wrong.
Did you forget Epoxy resin for example?
And although I am no expert, I do believe there are some other "resins" around, but I am open to correction on that point.
Glass fibre is often the material that gets bonded by a resin, usually 2 part.......though nowadays there are other "materials" that can be impregnated with a resin (Carbon fibre is also one I believe).
Polyester resin is the cheaper of the two that I know about and is usually used for large things like car bodies or boat hulls.
If you look on Wiki here:-
http://en.wikipedia.org/wiki/Carbon-fiber-reinforced_polymer
You can read this as the first couple of sentences that your comment is about 100% wrong!! Here is a copy:-
Carbon-fiber-reinforced polymer or carbon-fiber-reinforced plastic (CFRP or CRP), is a very strong and light fiber-reinforced polymer which contains carbon fibers. The polymer is most often epoxy, but other polymers, such as polyester, vinyl ester or nylon, are sometimes used. The composite may contain other fibers such as Kevlar, aluminium, glass fibers as well as carbon fiber.
The rest is also very informative as well, do read on!!
Good Answers: 44
06/16/2011 9:47 AM
I think the question, not statement, I made was okay. Every hit that comes up for glass fibre is from a country under the crown. I think it is basically lost in my translation. We don't call it glass fibre in the U.S., we call it fiberglass which covers all of the materials you mentioned (less carbon fiber, wonder why we don't call that fibre carbon?).
I worked at Westport Shipyard in high school, I know how fiberglass works, thank you very much. I cut enough of that stuff to cover Washington state (seems like, anyway).
06/16/2011 12:26 PM
Sorry, but your previous comment (the one I previously replied to) was still wrong and you made it "worse" by now demonstrating that you should have known better after hearing where you worked at one time!!!
Your comment was:-
Need I say more? I have underlined the offending words....totally wrong. Though the start of the sentence is still questionable.....depending exactly upon what you were trying to say of course....
(By the way, I speak French good enough to understand the French and nothing was lost in translation on my end, maybe you yourself didn't understand it? It means, "Is it not?)
By the way, this blog is not exclusively for US citizens (SURPRISE!!), its for Engineers of any race creed or colour, living somewhere on Planet Earth. So get used to different spellings, they are different not wrong!!!
Even in the US surely you know that Fiberglas(s) is a trade name... So by using that name, you are inadvertently advertising one company's product, but apparently you didn't know that....you are not alone!!! Good marketing!!
So it is still incorrectly but "popularly" known as Fiberglass........so you are just using the popular name....no problems there, except that you generalize the resins as only being of one type alll under that same name (as many lay people do!), but as we are not really so "lay" here, its usually a good move to use the correct terminology.....
You can get properly and correctly clued up here:-
http://en.wikipedia.org/wiki/Fiberglass
Then you will be as well informed as the rest of us about the glass side........
By the way, there are several resin types (I only know of two off hand, but there are more!) that can be combined with Glass Fibre (or carbon fibre), ONE of which is polyester, a good link is here:-
http://en.wikipedia.org/wiki/Polyester_resin
Another one is Epoxy here:-
http://en.wikipedia.org/wiki/Epoxy_resin
If I can be of any further help, please ask, but some others here are actually in the industry, so to say, they will have better and fuller infos than I have posted......
Have a great day
Good Answers: 44
06/16/2011 12:45 PM
Damn dude...I said fiberglass, not Fiberglas, the latter being trademarked.
I don't really care where you think you get off in trying to educate me...I wasn't the OP, I don't have any questions.
whatever
06/16/2011 1:04 PM
It was your STATEMENT I was taking to task, your statement that I quoted in my last post was incorrect.......
I will give up trying to educate you a little bit as I don't think you will EVER understand that what you wrote was so incorrect!!!
Look this up....maybe you will then understand better....
Matthew 7:6
Good Answers: 44
06/16/2011 1:21 PM
Education note: Those sentences ending in a question mark are interrogative, i.e., a question.
end of lesson.
I am neither a dog, nor a pig...I prefer Ezekiel 25:17...with a bang!
Take me to task, big boy...
06/16/2011 1:41 PM
Its a great and quite recently it's become a well known quote, but as in your comment that I took you to task for, it fails completely to bring anything positive or useful to your side of the argument...
OH SORRY, we all already knew that!!!
Good Answers: 44
06/16/2011 1:47 PM
CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
06/16/2011 1:51 PM
Well done.
Try a channel where you understand the lingo better.....Sesame Street?
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
06/16/2011 1:57 PM
"Well we'd have to be talkin about one charming motherfreakin pig!"
06/16/2011 1:49 PM
Andy give up, you are trying to get blood out of a stone, and a very thick stone at that!
I liked your links with regard to fiber glass and resins (Wiki is really great!), cleared up several points for me, so thank you kind sir.
Do not get on my case for posting anonymously as I do not want the local Cubans jumping on my head for no reason as well, they get SO excitable down here for no apparent reason at all. You miss all that in Europe I guess, lucky you. So-long Pard!
06/16/2011 1:53 PM
Thanks but what is a "Pard", is it positive or negative?
Good Answers: 120
06/12/2011 10:33 PM
Raising a volume of fish in a small space requires careful controls or the fish will die from their own excrement, and many more things are needed.
Aquaculture
Per Ardua Ad Astra
Good Answers: 39
06/12/2011 11:14 PM
Hemispheres give high water volume with least material. Polyester resin over plywood is rot prone. Explore various kinds of tanks already available. What kind of fish? What country/climate? What feed? Catfish? There are guides for raising food fish.
Align culture with nature...
06/12/2011 11:15 PM
Polyester resin bonds poorly to a wood substrate unless styrene is added to decease viscosity and enhance saturation of the wood.
To an optimist the glass is half full, to a pessimist it is half empty, but the engineer knows that the glass is twice as large as it needs to be.
Good Answers: 11
06/13/2011 12:28 AM
A stronger and cheaper, and, by all accounts less toxic to your stock would be to build a ferro-cement "aquarium"...what you are building is a small pond for raising food.
This is an easy two-person job, or even one, with thin-sheaf plywood or fiberboard to act as the assistant holding back the mortar on the opposite side of the person applying the mortar. Also, you can shape it so there are no corners etc. to trap fish crap and make it easier to clean. Here's a link to a simple project like yours.
Good Answers: 42
06/13/2011 1:38 AM
I volunteer at a community fish hatchery. We had donated to us a "tank" made out of 3/4" plywood covered both sides with "fiberglass". The wood eventually rotted out and the whole thing crumbled. The rot probably occurred over 5 years. Wood just does not like being encapsulated in fiberglass. (I know, there are some canoes made this way. They look very beautiful, but I suspect they are out of the water 95% of the time.)
We also use large round tubs, just over 8ft diameter and about 42 inches deep. They are made of "fiberglass" and have lasted at least 20 years.
We also use poly tanks of similar size, about 1500 gal. They appear to last extremely well also and were not particularly expensive.
Good Answers: 110
06/13/2011 1:48 PM
Actually, the success of modern canoes, and other boats like this depends upon the resin. Modern wooden boats built with epoxy resin are substantially more waterproof than a standard run of the mill "fiberglass" boat (which are made with polyester resins -- which we wooden boat builders think of as garbage).
Polyester should not be used with wood. The resin itself absorbs water, and it is a poor adhesive for wood. (That has not stopped manufacturers of "fiberglass" boats from using it as a wood adhesive, nor from using wood cores, which eventually become saturated and rot.) A properly built modern wooden boat made with the correct resin and fabrics does not have these problems.
06/13/2011 4:23 AM
I guess that this is off topic based on the op's original questions as the answer to his question is plain yes.
However, why don't you make up your marine ply box as you intend and then line it with a butyl liner as one would when preparing a fish pond in the garden?
This would be the easiest solution to building your aquarium.
06/13/2011 7:35 AM
The polyester resing will adhere to wood but first mix some clear resin and thin it with styrene and apply to the wood let cure then go ahead and apply the resin, I would definitley use some fiberglass mat or cloth and roll out any bubles. Lyn is correct in the resin leaching chemicals into water and may not be compatible with livestock. If I was doing this I would use an epoxy resin costs more but remains slightly flexable and this prevents most cracking and water migration into the wood. Also less toxic since it does not gas off as much as poly resin. Leave one side of wood clear of resin to allow moisture to evaporate and keep off the ground. Not sure of size of tank you are building but there are lots of used container vessles available both in plastic and metal. Good luck..
Good Answers: 58
06/13/2011 8:32 AM
youngken,
Maybe OT but -
I don't know what your budget is but one option could be one of these or something similar:
Obviously, if you choose this route, you can probably find a much better price locally by shopping around.
Source
Good Luck!
Good Answers: 21
06/13/2011 11:25 AM
There are many things to concider when looking at the design of a fish tank. Some points to think about.
When the fish...excriment builds up on the bottom of the tank you need to get rid of it somehow with the fish still in the tank or else they will die from the toxins.
What type of fish are you keeping? Some need deeper tanks than others, some need wider tanks than others. Some fish species can get stressed if they are in the wrong environment and will die.
You need to filter your water or have a continuously replenishing supply. If you have a large tank how can you ensure your design will supply fresh water to all parts of the tank. If you get this wrong you can get build up of crap in certain areas or stratifying water levels.
Do you need access to the bottom of the tank for drainage? Can you build the tank into the ground and have underground pipes? Do you put your tank up of a stand? If so do you need a tank with legs?
There are many more variables wrt fish keeping on an industrial scale. If you are thinking about it then put in a lot of planning before buying equipment. As well as your tank you may need, pumps, filters, UV sterilisers, heating, cooling, lighting, protein skimmers, syphons, oxygen generation, degassers, an unbelievable amount of piping and everything else which goes with running industrial plant.
I was part of a 4 man team which built a cod hatchery 9 years ago and it is a complicated business.
06/13/2011 4:02 PM
If I use a family type inflatable swimming pool to grow fish, do you think OK?
Anyone has tried like this? Is it durable?
Thanks
Good Answers: 21
06/14/2011 3:22 AM
I don't know anything about these pools but I would say there is one problem I can see straight away. You don't want a tank which has any crevaces or corners. Crud will build up in these and poison the fish.
We had GRP tanks about 4 cubic meters in capacity for the juvenile fish. Cod juveniles are tiny, about 1 mm length when hatched so we used the small tanks with a low flow rate. As they grow then you put them in bigger tanks as the biomass/water ratio is government regulated. At the size we put them out to sea we used 20 cubic meter GRP tanks.
I think you'd stuggle with one tank as a minimum you'd want two so you can clean one and prepare it while the other was holding the fish. We had 56 tanks and on that scale you need tanks which are easy to clean but even if you have only 2 I can guarentee that you'll curse yourself if you pick the wrong one.
06/13/2011 11:44 AM
This is the place you want to do your research.
I've spent more time reading about pond construction than I have about solar heating!
The place is busier than CR4..
06/13/2011 12:46 PM
What a waste.
06/14/2011 2:38 AM
I did come to the conclusion that if you are going to dig a hole to build a large pond (1/2 acre plus) that you should put coils of tubing under the mountain of earth you will be creating and take advantage of the thermal mass.
Since you are piling up a lot of earth anyway.. One can take advantage of a low cost installation of a geothermal heat pump system.
however.. If you are going to use the pond as a geothermal source.. you end up raising the summer temperature in ways that may be OK for something decorative, but is not healthy for a fish pond.
..I may have been exaggerating just a bit..
Good Answers: 39
06/15/2011 5:40 PM
That link you supplied seems like, by far, the best place for the OP to seek the answers to his question. GA
Good Answers: 110
06/13/2011 2:33 PM
Do not use polyester resin, because it is a poor wood adhesive and is absorbs water. Old boat hulls blister underwater because polyester is not a good underwater resin, even when no wood is present.
A waterproof (or fuel proof, etc) tank can be made with epoxy resins on wood. These resins are less likely to kill the fish quickly (than polyester), if you let them cure for about 2 weeks. But fish are extremely sensitive to chemicals, and may be sensitive to some that that can leach out of even epoxy resin (which when cured is nearly inert). You may have read about bisphenols and baby bottles. Note this from wikipedia on bisphenols:
  • Epoxy resins containing bisphenol A are used as coatings on the inside of almost all food and beverage cans,[18] however, due to BPA health concerns, in Japan epoxy coating was mostly replaced by PET film.[19]
You could use food grade epoxy, and be fairly safe, but it would be very expensive.
If the fish are not in the tank long, and if they are robust, then boatbuilding epoxies would work, provided you used at least three coats, so that none of the chemicals in the wood would leach in. Once epoxy is cured, it is remarkably inert, (and a human could probably consume a fair amount of ground up, fully cured epoxy without ill effects). Personally, I'd be comfortable drinking out of one of my wooden boats (although I'd look a little strange doing so).
In typical modern wooden boat building, fiberglass cloth is used in epoxy resin. Without the cloth, some plywood (especially fir) will check (form little cracks). Okume plywood covered with fiberglass cloth (6 oz for your application) would make a very durable tank. Many epoxies cure with an amine blush (and amines can kill fish), so you would want to make sure that you wash the tank before use. (It comes off with ordinary detergent and water.)
Read online about stitch-and-glue boat building.
Of course, you could line a wooden box with a polyethylene tarp (.006" thick or so) and you'd be good to go, I'd think (after washing the poly.)
06/13/2011 5:30 PM
Do you have a supply of fresh running water (from a stream or well etc.) or are you going to filter & recycle, with just top-ups of fresh?
Or then again (thinking outside the pool ), is it pumped seawater?
06/14/2011 3:15 AM
OK, I have seen some pretty good answers on here but not many actually answer the OP's original question.
We are now all trying to give him an alternative solution to making a vessel to accomodate some 'cheap' fish. Which is fine so I will give my 2 penneth worth.
I presume that you are talking of rearing some fish to sell on as they get bigger? Could these be Koy Carp, comets, shibunkins etc by any chance?
Will you site this tank/pond indoors or outdoors?
I still think that you can still make your marine ply box, of course reinforced with the steel brackets. Then if you line it with a sheet of butyl liner (same as for outdoor ponds dug out in the ground) you will have a water tight vessel for not a lot of cost, after all you were prepared to make this structure originally. You will just need to cost in the liner.
As others have mentioned you will need good filtration and possibly UV sterilisation to keep all the toxins from fish excrement etc out of the water.
06/14/2011 7:34 AM
I decide to use timber to build the external "formwork".
I also built one more timber box as a internal "formwork" with a little bit smaller than that of external one.
Then I will pour cement with reinforced steel mesh.
I will jack out the internal one, left the harden cement together with external permanent formwork.
I need a number of this tanks, internal formwork can be used for a few time. Perhaps it is the best way.
Good Answers: 120
06/14/2011 9:31 AM
Make sure you line the wood with a release agent, waxed paper etc.
The inner box must be made in sections you can unscrew and pull away from the wall. In addition, cement has a density of 3 or more times that of water. This means that the internal and external forms must be braced or they will bow in and out, using more cement and making things harder for you.
Forming links
Framing links
In addition, ferro-concrete has no or very small added aggregates. Normal cement has a risk of aggregate bridging on narrow sections = leakage pathway.
Per Ardua Ad Astra
06/14/2011 10:51 AM
You've probably thought of this (or will), but if I were doing that, I'd place some kind of lining plates on the four or five (counting the bottom) sides of that internal form--not fastened to, just placed against. Ideally with fairly smooth surfaces.
Then you can (first) jack out the internal form without fighting the "friction" (sticktion) of the concrete against the form, and afterwards remove the liner pieces to be used again for the next tank.
Good Answers: 11
06/16/2011 12:11 AM
Sounds like my suggestion for the fero-cement ponds. Your walls will be very shallow, compared to concrete, and the more mesh, the merrier. The mesh and the concrete are a one plus one equals 3 situation. They compliment each other.
06/17/2011 5:05 PM
May I suggest using a plastic sheet liner inside the plywood box.
Mr.Ron from South Ms.
09/19/2017 5:55 PM
Sorry I'm late for the party,... but, that's how Avenger Class Minesweepers 1-14 are held together.
Some more info
Register to Reply 51 comments
Andy Germany (7); Anonymous Poster (1); aurizon (2); cuba_pete (6); dbash (1); garth (3); GW (1); JE in Chicago (2); JohnDG (2); K_Fry (3); KJK/USA (1); lyn (5); MACA (2); Oregoon (2); ormondotvos (1); Out of Box Experience (2); phoenix911 (1); rhkramer (2); ronseto (1); roy hammy (1); stevewicks (2); Tobugrynbak (1); youngken (2)
